Question about Maytag Neptune MAH5500B Front Load Washer
RING OF BLACK ON NEPTUNE WASHER- ORIGINAL GASKET WAS REPLACED YEARS AGO BY MAYTAG WHEN PROBLEM WAS IST DIAGNOSED- NOW IT HAS RETURNED=CAN I USE A SAFE RINSE OF WHITE VINEGAR TO REMOVE IT? ANY OTHER EASY SOLUTIONS-
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Many people use 40 degrees washes almost exclusively these days and the current trend is to use even lower temperatures to save energy ( Do you save as much as you think? Washing at 30 degrees ). Remember that a non-biological powder, doesn't work as well at lower temperatures so washing at low temperatures requires biological detergent for best results. It's also worth noting that bed bugs (or their eggs) are reported to be able to survive washing at lower temperatures and therefore it is recommended that bedding sheets should be washed at 60 degrees ( Related Whitegoodshelp Blog article: Bed bugs don't drown in the washing machine - but at least they get cleaned )
Also, (as mentioned in detail later) a regular 90 degrees maintenance wash is needed.
Washing machines now commonly suffer from a build up of a greasy deposit and bacteria that causes bad smells, rots hoses & door gaskets and blocks the pressure system causing overfilling or spin failure. An even more serious consequence of this problem is that the aluminium based drum spiders can be corroded by this grease and in serious cases can cause one or more arms to break. This is often fatal to the washing machine. Replace the door gasket with this part and wash the inside of the machine at least once a month with a GOOD HE washer cleaner like this one.
Posted on Jan 02, 2011
Ou Maytag Neptune Washer MAH-3 will not drain.
This problem was answered a couple of years ago in detail. A search should produce it. Search the name Scruggs.
Sep 02, 2014 | Maytag Neptune MAH5500B Front Load Washer
Water is filling the tub when not in use
One of the water inlet solenoid valves is faulty -- it's not closting when the "water-fill" function is off. The solenoid valves are the parts the hoses on the back of the wahser are connected to. There are two -- hot and cold.
Cleaning them and replacing wahsers / O-rings / gaskets may solve the problem or may need to be replaced. More info, let me know.
Charlie
Feb 12, 2011 | Maytag Neptune Washer
I have that moldy/mildew smell in my Neptune TL. I called about three years ago and they told me to run cascade through it. Now it is back and worse than ever and nothing seemed to help. My husband took...
yes there was a huge class action against maytag they are building rubbish we have machines here that are 4 months old and maytag wont cover there warrentys .. and they were the best washers you could ever buy till they were bought out by china. but they settled in 2004 but there are still many going on here is a link to get you strated.
good luck with it next time buy lg. how do we know there good? we have fixed 2487 washers this yr alone and only 4 of them were lg they are great machines.
http://www.consumeraffairs.com/news04/2005/maytag_lawsuit.html
Aug 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Mold on rubber gasket on Maytag Neptune washer -- how do I get rid of it?
you can not the door boot has to be replaced there is a black commercial one available although unsightly it will not cause any harm
Aug 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washer smells musty. what is
I owned a maytag neptune washer and had to run dishwashing liquid thru it occasionally to get the smell to go away. Finally we learned about a new gasket retrofit that they were doing which was covered by the maytag company we called and they installed it for free and the smell stopped. I had that washer for about 10 years and probably spent as much fixing it over the years as it cost. I now have a whirlpool duet front loader and love it. no smell and not problems. Try the electric dish washer soap.
Aug 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
Apr 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washing Machine
hi randy,
call 1-800-MAYTAG
they will have recall notices and hopefully any info. on service issues in the field.
Sep 19, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
83 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
