Question about Denon RC-8000 LCD Touchscreen Remote Control
Backlight does not work, very dim - Denon RC-8000 LCD Touchscreen Remote Control
Samsung TV backlight is very dim on LN40B530P7N Television
Check if the sensor of the ambient light in the room is dirty (bottom of TV). If so, the TV thinks its playing in a dark room and so sets the screen to dim.
If that doesn't improve things, turn a flashlight on the sensor to fool it into thinking its a brighter room.
Aug 26, 2017 | Samsung Computers & Internet
After changing the converter on satellite M305D-S4830 the backlight still very dim
i'm sure you ment inverter..if its working on external screen? it would seem. that you still need it replaced have u checked the ribbon cables?
Nov 23, 2013 | Toshiba Satellite M305D-S4830 Notebook
204b backlight getting dim
change the inverter if it does not work ,you will have to change the backlight bulbs or you change the screen
Jun 22, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
Dim backlight
you need to contact the manufacturer and ask to replace the backlight...
May 20, 2010 | Toshiba Satellite 15" Flat Panel LCD...
Very dim light on my pro 2052.
Display or backlight? If it's the backlight, you need to replace one solder-in bulb. Radio Shack part number 272-114 (5v, 25mA) will work. If it's the dispay you need to contact the Shack for a replacement.
Bill B
Feb 26, 2010 | Radio Shack Pro-2052 Scanner
Dim Laptop screen
It could either be your power settings dimming it (battery saver mode), or more likely when you replaced the screen, you replaced the backlight with the one that came with it. The replacement backlight is probably not as good as the one you had. You can try putting your other backlight in it (the backlight is that circuit board near the hinge that you plug in when you switch the screens out). Since it's going in and out, I'd check the power settings first though.
May 04, 2009 | IBM Computers & Internet
MacBook screen dims
first there could be many meanings of dims with a laptop screen one is backlight has turned off and it is difficult to see.  if that is the case use you brightness key to check if it is up, if it is more likely your inverter has gone up and in worse cases the screen. it may also start bright then change dim while loading
there is also the feature on mac to automatically dim the screen a little when unused for a set time.  to change this go to system preferences, go to energy saver, click show details, then move to options, and uncheck the the box that says "Automatically reduce the brightness of the display before display sleep".
i hope this is what you are talking about.
Mar 14, 2009 | Apple MacBook Mac Notebook
Raymarine smart pilot st6002 backlight is too dim
Get a new backlight, inverter is probably ok.
The way to check that the inverter is ok:
disconnect the backlight and if you hear a high pitched noise, the inverter is still good.
replacement backlight is available from a company called Being Seen Technologies.
there website is www.beingseen.com
Mar 12, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
HP Pavilion ze2000 Monitor is dim
Yes, this is what happens when the backlight goes out.
This will give you an idea of what is involved in replacing the backlight. You can find a replacement backlight here, or on ebay, just take your current backlight(s) out, measure it or them, and buy replacements of the same measurements. It doesn't have to be for the same model laptop as long as the CCFLs (cold cathode florescent lamp) are the same size.
Aug 11, 2008 | Computers & Internet
Denon RC-8000 LCD Touchscreen Remote Control Logo
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
