Question about Car Audio & Video
No sound from my ipod
I have a new unit and have returned it once, everything on my unit works properly but i have no sound when i use my ipod. The deck displays the song thats playing but no sound. i have it set to aux off.
  • bashelton Jul 22, 2008
    IPod Classic 30 Gig. No sound, looks like its playing and you can adjust the sound settings but no sound. You can put in in the freezer for 15 or 20 minutes and it will play for about 5 minutes.
This is a big issue, but Apple will not acknowledge it. Have a look at this :
http://discussions.apple.com/thread.jspa...
and also:
http://www.aqua-soft.org/board/showthread.php...
Good luck in your quest with Apple .. and wish me the same>
Posted on Nov 06, 2008
New ThorensTD-190-2. When stylus hits the vinyl it sounds like its grinding. You can still notice the grinding once the music starts.
try another newer Vinyl
check the stylus is fitted and resting in the proper place
the stylus may be faulty
if new unit return it
may need to replace the stylus head
Apr 29, 2016 | Audio Players & Recorders
I have no sound on my ipod and apopup say generic volume running
Damaged hardware is responsible for the most obvious iPod sound problems.
In such cases, Apple may be able to help you fix the problem, depending on the status of your warranty.
All iPods have a one-year warranty according to Apple's website.
Software problems can also affect your audio.
For example, downloading a non-certified Apple application can stop your sound from working correctly.
Returning your iPod to its original factory settings fixes many of these software glitches.
Plug in a different set of headphones and test the sound.
If that set works, your old headphones were the cause of your audio problems.
If your iPod still doesn't work, proceed.
Remove an application on your iPod Touch if you installed it right before your sound stopped working.
Hold your finger over the top left corner of the application.
It will shake.
Touch the "X." Touch the "Home" button.
Restore your iPod to fix other potential software problems.
Open iTunes. Plug the iPod into your computer with a USB cord.
Click on your iPod on the left-hand menu.
The iPod will be listed under the name you assigned it when you first set it up.
Click the "Restore" button on the menu.
Leave the iPod alone while it restores.
It may take several minutes.
Test the sound once the restore is complete.
The iPod syncs after restoration.
Once the sync is complete, the process is over.
Contact the Apple Technical Support line at 1-800-275-2273 if your audio still doesn't work.
Have your iPod with you.
Aug 01, 2013 | Apple iPod Audio Players & Recorders
Generic volume
Damaged hardware is responsible for the most obvious iPod sound problems. In such cases, Apple may be able to help you fix the problem, depending on the status of your warranty.
It will shake.
Open iTunes.
Leave the iPod alone while it restores. It may take several minutes.
Ipod classic has no sound
Damaged hardware is responsible for the most obvious iPod sound problems. In such cases, Apple may be able to help you fix the problem, depending on the status of your warranty. All iPods have a one-year warranty according to Apple's website. Software problems can also affect your audio. For example, downloading a non-certified Apple application can stop your sound from working correctly. Returning your iPod to its original factory settings fixes many of these software glitches.
Plug in a different set of headphones and test the sound. If that set works, your old headphones were the cause of your audio problems. If your iPod still doesn't work, proceed. Open iTunes. Plug the iPod into your computer with a USB cord. Click on your iPod on the left-hand menu. The iPod will be listed under the name you assigned it when you first set it up. Click the "Restore" button on the menu. Leave the iPod alone while it restores. It may take several minutes. Test the sound once the restore is complete. The iPod syncs after restoration. Once the sync is complete, the process is over. Contact the Apple Technical Support line at 1-800-275-2273 if your audio still doesn't work. Have your iPod with you. Hope it helps
b>
b>
Jan 22, 2013 | Apple iPod Audio Players & Recorders
My iLIVE mod# IT188b will not turn on.... reset button not working either??? this is the second unit I have had(first one did the same thing)but was able to return without reciept...not the case this time!...
This particular unit has issues with bad solder connections on the main audio board which come loose because the woofer speaker vibrates them loose. I've repaired unit myself with a soldering iron.
Dec 02, 2009 | GPX 2.1 Speaker Bar with ipod Dock ...
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
KCA- 420i and an alpine 9854r Can't change the volume for Ipod
There is a small switch on the unit's housing, switch it to "Norm" position.
May 08, 2009 | Alpine CDA-9847 CD Player
Apple icon always on new ipod touch and session could not start
if that happened, then yes. then you could just buy a new one. but trust me, that's probably a defective ipod.
Apr 03, 2009 | Apple iPod touch
ILive docking station not working properly
Omg i have the same exact one and the exact thing happens with mine---blue light no longer shows up and music will not play through the speakers---my ipod still charges and the clock still works but yeah---i also got mine 2 months ago!
Oct 24, 2008 | Audio Players & Recorders
Car Audio & Video Logo
845 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
