Question about Panasonic TCP50S2 50 in. TV
No picture, but sound on cable.......................no problem with picture or sound when on satellite or dvd screen us just blank
    Sergeant:
    Champion:
  • 342 Answers
There seems to be a problem with either one or two things have you tried the cable connection on another tv if it works there then the tv tuner in your tv has gone bad and the tv will be easier to replace than repair
Posted on Jan 02, 2011
Have a element tv some of the stations now are either all jumping squiggly or just outright blank, no sound either, whats wrong? Its only 3 months old.
Can you play a DVD ok in it? If that displays ok, then the problem is whichever way you get your television signal, cable, satellite, to air etc. Bad connections is the main culprit of a weak or confused signal.
If the picture is bad on DVD, take the set back.
Feb 02, 2016 | Element Televison & Video
Turns on just blank screen it is lit but no picture
no sound either? Also is this set connected to a cable or satellite box for signal?
Dec 21, 2012 | LG 37LG50 37 in. LCD HDTV
The screen is blank,needs to change the lense
If this is a warranty item, the DVD player should be returned to the place of purchase, if not! and you do not see the screen logo, the LCD panel is bad or the video cable is loose that attaches to the main board. But if you do see logo, the laser pickup assembly is bad, not cost effective to repair, far cheaper to replace.
Mar 12, 2012 | Venturer PVD730 Portable DVD Player
I'm trying to record movies with my DVD recorder but it's only recording a blank screen.
If you are watching digital cable (or satellite) TV your DVD player most likely doesn't have access to that image. You'll probably need to connect a cable box to the DVD recorder or only record on normal or expanded cable.
Mar 13, 2011 | Toshiba Televison & Video
N o picture just static noise
The symptom sounds like a dead tuner and the screen blanking may be due to missing video synchronization signals which may cause either blanking or 'blue screen' on some sets.
This could also still be because of a failing power supply although they will generally just cause no turn-on at all.
I would first substitute another TV just to be sure your signal source (cable or satellite) isn't causign the loss of signal.
May 25, 2009 | RCA R52WM24 52" HDTV Projection Television
No picture on tv just blank screen
Sounds like you lost your High Voltage Power source which lights up your screen. If you don't know anything about TV's do not attempt to fix this problem. The High Voltage Power Supply is around 40,000 Volts!
Mar 26, 2009 | Mitsubishi WS-65315 65" Rear Projection...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Sound no picture on cable
sweetkiss, if it works through the dvd player and not on cable/satellite box then the tuner is bad, if you have any type of cable/satellite box try running A/V cables out of the box to video input on the back of the tv and switch the tv to that video input, ie; vid 1, vid 2 etc. (your using one of those inputs for the dvd) this will give you your picture back, you can of course also replace the tuner in the set, good luck, BMW Rider
Feb 10, 2008 | Sony KV-27V22 TV
Dell 32 LCD Flat Screen multiple problems
I have checked all the connections and replaced all the cables with the highest quality I could buy.  I think the problem is in the TV tuner itself.  I live in a MDU so I am stuck with a rooftop satellite/master antenna.
Oct 23, 2007 | Dell W1900 19 in. HD-Ready LCD Television
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
Panasonic TCP50S2 50 in. TV Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
