Question about Nintendo DSi Black Console
What happens if I press 'clear settings' when in internet connection mode?
    Problem Solver:
  • 17 Answers
Nothing!
Posted on Jan 02, 2011
I forgot my admin password for my Dell C1765nfw Color MFP web interface. I changed it from the admin default, but do not remember the pwd. How do I reset it
You could try performing a hard reset. Keep in mind that this will reset ALL settings. Admin password should then be back at the default, which is admin.
Clear NVRAM from Tech Mode
  • Turn off the printer.
  • Turn on the power while holding down Left arrow,Right arrow, and Menu buttons.
  • Release these keys when "CE Mode" and "Password" is displayed.
  • Press Up arrow key twice and press the checkmark.
  • "CE Mode", "Printer" and "FAX/Scanner" are displayed. (Entered the CE Diag. mode.)
  • Press the checkmark key to select "Printer".
  • Press Down button to "Installation Set" and press the checkmark key to select.
  • Press Down button to "Clear All NVM".
  • Press the checkmark key twice to execute the test.
  • Power cycle the printer to return to the regular operating mode.
May 23, 2017 | Dell Computers & Internet
Dns failed error occured in s5620 samsung mobile .. when i use internet through mobil office or wifi
Hello
This sometimes happens in Samsung Cellphones that while connecting to internet via WIFI, DNS failed
To solved it follow the given procedure:
  • Go to browser
  • Then go to setting
  • Then clear cache, empty cookies and delete history
  • Now restart your Samsung S5620 cellphone, then connect to desire wifi connection, then browse after setting up your browser profile
If it doesn't solved then contact to Samsung Service providers and consult with providers of WIFI connection, But i hope it will work.
Don't forget to do Rating by Clicking on Four Thumbs which are given below to this solution if it is HELPFUL
Thanks and keep Using FixYa
Mar 09, 2011 | Samsung S5620 Cell Phone
How can I reset chip samsung scx 4200 all in one laser printer. kumar
I am presuming you want to reset all the systems settings to the factory defaults. Try this:
Clearing memory
You can selectively clear information stored in your machine's memory.
1 Press Menu until Maintenance appears on the top line of the display.
2 Press the scroll button ( or ) until Clear Settings appears and press OK.
3 Press the scroll button ( or ) to select the item you want to clear.
• Paper Setting: Resets all of the Paper Setting options to the factory default.
• Copy Setup: Resets all of the Copy Setup options to the factory default.
• All Settings: Resets all of your settings to the factory default.
• Machine Setup: Resets all of the system settings, such as the display language and save
mode, to the factory default.
4 Press OK to confirm clearing. The selected setting is cleared.
5 Repeat steps 3 through 4 to clear another setting.
6 Press Stop/Clear to return to Standby mode.
Nov 30, 2010 | Samsung SCX 4200 All-In-One Laser Printer
New Konica bizhub C351 copier with only 58 copies. It will make copies but it has a 6 1/8" x 8 5/8" BLACK area in the center of the 8 1/2" x 11" copy if you make a copy from the platen glass. It does not...
Gray box after installation.
Solution
CAUSE: Installation procedures were not completed properly.
SOLUTION: Complete the installation procedures thoroughly:
1. Adjusting Touch Panel - Press the Accessibility key, Touch Panel Adj.
2. Setting Gradation Adjustment - Go into Service Mode, Image Processing Adjustment, Gradation Adjustment. Service mode- ulilty/counter, check details , then(Stop00 stop01)
3. Touch High Compression Mode and press Start [perform 3 times].
4. Touch Gradation Mode and press Start [perform 3 times].
5. Touch Resolution Mode and press Start [perform 3 times].
6. Date/Time Setting - go into Service Mode, Press Stop, 1, 1, 4, 4, Clear.
7. Go into Utility/Counter, Administrator Setting, System Setting, Date/ Time Setting.
8. Install Date - go into Service Mode, System 1, Install Date.
9. Serial Number Input - go into Service Mode, System 1, Serial Number [If Serial Number is already there, Clear and re-enter it].
10. Unit Change - go into Service Mode, System 2, Unit Change.
11. List Output - Please Load 8.5x11 Landscape paper on Tray 1, go into Service Mode, List Output, and Touch Machine Management List and press Start.
12. Press Adjustments List and press Start.
13. Press Service Parameter List and press Start.
14. Press Fax Setting List and press Start.
Sep 04, 2009 | Konica Minolta Office Equipment & Supplies
Psp
You can go online with the PSP system and browse the Internet. To start browsing the Internet
  1. Check your PSP system set up:
    • Infrastructure Mode
      Make sure your PSP system is set up for Infrastructure mode.
      See Setting up Infrastructure mode for details.
    • Internet Connection
      Make sure you have an internet connection and your PSP is within range of the wireless access point (or hotspot).
      PSP®online connectivity requires internet service and network devices, suchas a DSL or cable modem and a wireless router - for example, a Wi-Fihotspot at a café or a wireless local area network (WLAN) in your home.
    • System Software
      Make sure you've got the latest System Software.
      Requires PSP system software version of 2.0 or higher. Visit PSP System Software Update to download and install the most recent version.
    • WLAN switch
      Make sure the WLAN switch on the left side of the PSP system is turned on so that the PSP system can connect to the internet.
  2. In the XMB™ home menu select icn_network.gif (Network) > icn_www.gif (Internet Browser) and press the icn_btnx_color.gif button.
  3. Use the up and down buttons to select the address bar and then press the icn_btnx_color.gif button to display the on-screen keyboard.
  4. Enter the address for the web page you want to display, select Enter and then press the icn_btnx_color.gif button.
    For more information, see Using the On-screen Keyboard.
  5. Select a connection and press the icn_btnx_color.gif button.
  6. The web page is displayed.
  7. To hide the on-screen menu, press the icn_btntriangle_color.gif button.
To close the Internet connection:
  1. With a web page on the screen, press the icn_btncircle_color.gif button.
  2. Select Yes and press the icn_btnx_color.gif button.
  3. The internet browser will close.
If you have issues connecting to the Internet, you may wish to troubleshoot your Infrastructure mode connection.
Sep 14, 2008 | Sony PlayStation Portable (PSP) Console
How can i put internet in my psp?
To connect to the internet;
  1. Check that you have your PSP® (PlayStation® Portable) system set up for Wireless (WLAN) networking in Infrastructure Mode.
  2. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  3. Make sure you are within range of a wireless access point (or hotspot) that allows connections to the internet.
  4. Select icn_www.gif (WWW) under icn_network.gif (Network) from the home menu and press icn_btnx_color.gif.
  5. Use the up and down buttons to select the address bar and press to display the on-screen keyboard.
  6. Use the on-screen keyboard to enter the address for the web page you want to display.
  7. When you have finished entering the address, highlight the Enter button and press icn_btnx_color.gif.
  8. Select a connection and press icn_btnx_color.gif.
  9. The web page will be displayed.
  10. To hide the on-screen menu, press icn_btntriangle_color.gif.
Setting up Infrastructure Mode;
Infrastructure Mode allows you to connect your PSP® (PlayStation® Portable) system to the internet through a wireless network (WLAN) access point.
Required items:
  • A PSP® with system software version 2.0 or later.
  • A wireless network(WLAN) access point with internet access, such as:
    • A Wi-Fi hotspot (such as those at cafés, hotels and airports).
    • A home wireless network, which might include:
      • A subscription to an Internet Service Provider (ISP)
      • A DSL or cable modem
      • A wireless broadband router
  • Settings used for the SSID, WEP/WPA-PSK encryption and WEP/WPA-PSK key, as specified when the wireless access point was configured.
To set up Infrastructure Mode on your PSP®:
  1. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  2. Highlight icn_settings.gif(Settings) from the home menu.
  3. Select icn_networksettings.gif(Network Settings) and press icn_btnx_color.gif.
  4. Select Infrastructure Mode and press icn_btnx_color.gif.
  5. Select New Connection and press icn_btnx_color.gif.
  6. Use the on-screen keyboard to enter a name for the connection, then press the right arrow button to continue.
  7. To set the Service Set Identifier (SSID) for the access point, select one of the following:
    • Scan: searches for and then displays a list of access points (or wireless networks) and displays the SSIDs.
    • Enter Manually: allows the user to enter the SSID using the keyboard. Select this option if you know the SSID of the access point.
  8. If you choose the Scan option in the previous step, select the access point to be used and press icn_btnx_color.gif.
  9. Confirm the SSID and press the right directional button.
  10. To enter security information for the access point, choose one of the following:
    • None: does not set security information.
    • Wired Equivalent Privacy (WEP), WPA-PSK (TKIP), WPA-PSK (AES): all set security information. Press the right arrow button to move to the screen for entering WEP or WPA (Wi-Fi Protected Access) keys. Note: The WEP and WPA key fields display eight asterisks no matter how many characters you enter as the key.
  11. After entering the security information, press the right arrow button to continue.
  12. To select the address setting method, choose one of the following:
    • Easy: the following information is automatically set
      • IP address settings: Automatic
      • DNS settings: Automatic
      • Proxy server: Do Not Use
      • Internet browser: Do Not Start
      Note: Most home networks will allow you to use the Easy address setting, which is recommended.
    • Custom: you can manually enter detailed setting information, such as when you are using a static IP network. For details, see the instructions supplied with the network device or the information provided by your ISP.
  13. After selecting the address setting method, press the right arrow button to continue.
  14. Check the settings, using the left arrow button to return to previous screens to make any necessary corrections.
  15. To save the new connection, press icn_btnx_color.gif.
  16. To test the connection, select Test Connection and press icn_btnx_color.gif.
  17. If the connection is successful, information about the network connection will appear. Press icn_btncircle_color.gif to end the connection test.
You can also check http://www.us.playstation.com/support/psp
for more information.
Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
Internet
its pretty simple really actually, turn ur psp on then go down to settings, then go down to network settings click the x button then click down on Infrastructure mode click on new connection, then press scan, there you should see which connections u are able to get hooked on to. Only to one that will say security NONE, if it has a wep key 4 get it, if you have a wireless router for a laptop then ur wep key is under ur router enter it in press x then adress settings click on the one EASY, the connection name should appear continue by pressing either X or arrow ->. Press the x button to save settings, test connection should appear press X. it will then connect scroll down and chck internet succeeded. then go back by pressing O and go to www.Internet Browser press x and u should be connected. you can chck how to this on youtube. just write how to get internet on psp...
Dec 12, 2007 | Sony PlayStation Portable (PSP) Console
Internet
Go to www.playstation.com and select your country, then select PSP. You can find all kinds of instructions for how to do Internet, download and a whole lot more.
Nov 06, 2007 | Sony PlayStation Portable (PSP) Console
Internet in psp
Getting online with your PSP is very simple. First, you must be in range of a Wifi hotspot (wireless local area network). You can adjust network setting to connect to an access point such as a Wi-Fi hotspot or the router on a wireless home network and save the network connections data on your PSP®. Up to 10 connections can be saved.
Once in range of the hotspot, go to "Settings" menu, >> "Network" Settings and press "X" Button. Select "Infrastructure Mode" or "Ad Hoc Mode" and press X Button. Set up the "New Connection". For details about Infrastructure Mode set up, or Ad Hoc Mode set up, visit us.playstation.com.. hope this helps.
Nov 05, 2007 | Sony PlayStation Portable (PSP) Console
PsP internet
Go to settings, press x on network settings, press x on infrastructure mode, press x on new connection and scan for a internet access or enter your wireless connection by going to enter manually.
Oct 29, 2007 | Sony PlayStation Portable (PSP) Console
Nintendo DSi Black Console Logo
104 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
