Question about Beko Televison & Video
Hi Have a Beko 32"
  • Beko Master
  • 19,396 Answers
Hi.
In case we are talking about an LCD TV, try to understand if the problem is related to connections and/or connected devices.
If prolem is not input-related, then you may have an inverter board that is starting to fail.
Also ensure that problem is not input source selection. This is done using the remote.
To check if problem is input-related.
Test the TV with only one of the two connected device. Test for one day or two (depending on how often the problem occurrs). Test for example with only Virgin box and HDMI connection.
If problem does not occurr, then replace cable and check devices connection settings. Test using different cables and change the way you connect the devices.
If the problem occurrs with different devices (stand alone) and cables, then the problem is the TV.
When an LCD has sound but no picture, and problem doesn't depend on input signal, that usually means that you have a defective inverter board inside the TV.
In that case the inverter must be tested and replaced.
Here Beko parts: Beko TV Parts ' ShopJimmy.
Regards.
Ginko.
Posted on Jan 02, 2011
My TV will not stop switching itself off
Hi, The first thing to do is troubleshoot your TV independent to any other service provider that has a box that probably connects to your TV via a HDMI cable or old version scart.
Simply turn off your TV and turn off the socket that the TV is plugged in for 20 mins. Also turn of any Virgin media boxes.
After 20 mins turn on the TV. Do not worry if you get a message saying no signal detected. Wait and see if the TV stays on with no messages such as auto-standby. If the TV remains on with no problems then turn on your Virgin Media Box. The box will need to initialise ( about 30 seconds ) and then the TV should recognise the HDMI signal and you will see the Virgin TV.
If your TV turns off at any point during this process you have a fault with the TV, If when you turn on the Virgin box and no signal is detected you have either a cable connection problem or a Virgin Box problem, so using your TV REMOTE turn your TV back to ARIEL input to receive the normal television broadcasts via your Ariel that give you the normal freeview television that all modern TV's can receive, if you can get the normal reception contact virgin support who will troubleshoot your problem.
Nov 07, 2017 | Internet Computers & Internet
I have a JVC RM-C60 TV. I'm trying to tune it in to my Virgin Media HD box using a standard SCART lead but having no joy. It's completely failing to find the cable channel (or any other for that matter)....
Tuning of the TV not required when using scart lead, just select external input that the scartis connected to, ie AV1,AV2 (EXT1,EXT2) etc. The problem is possibly to do with the Virgin box, it may be set to HDMI out in which case it will not output anything via the scart lead, you would need to connect via an HDMI lead (small socket on the rear of the unit looks a little like a USB socket). Problem is if your TV is a CRT television its unlikely to have this socket. Your Virgin box can be reset to output via the scart but you would need to contact Virgin for this process.
Feb 17, 2011 | JVC Televison & Video
Hi there! I have a 19" Beko Tv about 4 years old. The sound has gone altogether. Picture good though. We have it attached to a freeview top box. Husband saying its the topbox that's faulty. ...
I assume that you have attached it via SCART cable...since SCART plugs have 21 pins, and carry video, audio and switching signals ,sometimes a bad connection on either TV side or Top Box side ,the sound goes off first..Make sure your SCART plugs securely fit to either side.
If it does not help pls visit the URL below for further advise before going to blame the Top Box....
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Set-top Box Connection Advisor This page is designed to help you with connecting your Freeview, BT Vision, Virgin Cable, Freesat or Sky satellite set-top box to your home TV system. http://www.radioandtelly.co.uk/connecthelp.php
Feb 02, 2011 | Beko 324250WN 28" TV
Tv connected via scart cables through dvd and virgin media box. Picture sometimes goes yellow the flickers then back to clear.Other times it can go red. Plays dvd's okay though. Is this a connection...
This will be a problem with either the Scart leads (9 times out of 10) or the virgin media box. Not a problem with the signal coming from Virgin Media. Try checking the scart leads are not loose, or looped through the wrong way.
Hope this helps
TV_Doctor
Jan 03, 2011 | Sharp LC-32P50E 32 in. LCD Television
My Samsung TV picture is supplied via a HDMI lead
yes you need to connect audio out from the tv to audio in on the dvd surround. you need the red/white phono to phono leads, simply connect together and select audio (av,au) on the input selection.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
No sound with HDMI cables. I've connected a Virgin cable box and XBox360 to a Panasonic 32'' TV via an HDMI adaptor but it takes 30 minutes for the sound to come on. If I connect them individually the...
I am so confused and so is the main computer in your TV.
HDMI adapters can cause all kinds of issues.
So the best advice is not to use them.
Jan 16, 2010 | Televison & Video
No sound when plugging a Virgin Media V+ box through HDMI
have you tried a hd cable this could be the answer if not get back on to virgin as they supplied the box etc they should sort this for you
Sep 03, 2009 | Hyundai ImageQuest HLT-3270 Television
Problem with tv sender
Hi,i learned on another forum that if you connect an hdmi cable apparently it disables the functions of the scart sockets,especially where the remote control is concerned.This is something to do with virgin media's setup and not any equipment fault.If you want to go back to two room viewing try unplugging the hdmi lead.
Jun 22, 2009 | Philips Televison & Video
No picture on Bush WS6667 TV
hello make sure the scart lead is connected tight
Jan 20, 2009 | Bush WS6671 28" TV
Televison & Video Logo
187 people viewed this question
Top Beko Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Beko Televison and Video Expert? Answer questions, earn points and help others
