Question about Ranger Communications RCI-6900F-25 CB Radio
RADIO WORKS FOR FEW MIN THEN STOPS TURN OFF FOR 10 MIN WILL WORK AGAIN
  • bailenforcer May 11, 2010
    Not sure but has it sat unused for months? When has the internal memory battery been last replaced? If it sat for a long time it might also be the battery in the CPU. That board is located behind the display.
  • 55 Answers
SOUNDS LIKE A COLD SOLDER JOINT OR A BAD COMPONNET WHEN IT WARMS UP THATS WHEN IT STARTS ..TAKE OFF THE COVER SO THAT YOU CAN SEE THE SOLDER SIDE OF THE BOARD PUT POWER TO THE RADIO AND WHEN IT WARMS UP AND SHUTS DOWN TAKE A LITTLE PIECE OF WOOD OR PLASTIC AND PROBE ALL THE SOLDER CONNECTIONS TO CHECK FOR A COLD SOLDER JOINT IT MAY BE GRAY IN COLOR MAY NOT.. SEE IF IT GOES ON AND OFF.. IF SO RESOLDER THAT SOLDER JOINT.......IF THIS DOES NOT WORK ....PICK UP SOME FREEZE SPRAY AND SPRAY IT ON THE COMPONNETS ON THE OUTHER SIDE OF THE BOARD THIS IS WHAT A SERVICE PLACE WILL DO IF THAT DOES NOT WORK NOW BRING IT TO A SERVICE AND LET THEM SCRATCH THERE HEAD GOOD LUCK
Posted on Feb 21, 2009
The radio stop working, The radio intenna come up when radio is not own.
The module that controls operation cud hav issues. But its usually connectd w otherthings too. A car harness wire or bad radio also. Disconnect batt a few min and see if itclears. Or bring vehicle for a scan at autozone
May 30, 2015 | Cars & Trucks
When i turn da radio off then turn the beat on it work n stop
I don't know if your talking about subwoofer or speakers but if they stop while a big loud beat comes in its to much for your amps if you have them to handle and the amps turn of and by turning of your head unit and on again it resets them and works again try turning your gain down on the amps
Aug 01, 2014 | Car Audio & Video
Touch screen not working
is it just the touch that stops working? or all off the computer?
May 22, 2014 | Toshiba Satellite Computers & Internet
I just had my brakes changed on my 2006 passat. Now the electronic parking break sensor won't stop beeping but everything works. How can I get the fault to go away so It will stop beeping
also if u take battery off for 10 mins, hook battery back up again, turn car on, hold in break paddle for 35 seconds, then still holding in break paddle hold in handbrake button for 10 seconds, release all and start car up, press break button a few times, turn car off again take out key, lock and open car then press break button again and now all should b back to normal
Mar 27, 2012 | 2006 Volkswagen Passat
My machine keeps freezing on me. It will work if I leave it off for about 10 min. but only for a few min. and then stops working again. I have to turn it off for 10 min. again before it works...
If the handwheel is tight and difficult to turn, then there is a bind somewhere. Could be debris in the hook raceway, thread caught in the take-up crank or a shaft bushing failure. Consult your instruction book for directions on how to clean out the hook area. If cleaning the hook area doesn't help, take it to your repair person. The more you use it in this condition, the worse it could become.
Jul 14, 2011 | Bernina Activa 140
Car will not start- will crank- anti-theft light flashes - turn switch to on for 10 min. when light stops flashing - turn switch to off - then it will start. Changed to a new switch - worked or started for...
try a diffrent key,your extra one.Could be the micro-chip inside is not comunication with anti-theft-.This happened to me.I used the spare set for a few days .then the other key started working again
Jun 28, 2011 | 2004 Chevrolet Malibu
Stop working. brush was cloged. It there a reset button?
i had a similar thing happen and just got off the phone with dyson. there is a resettable switch on the handle. they told me to start the vacuum in the upright position, put it in the non upright position, then push and hold in the beater bar switch which is located next to the on/off button for 10 seconds and the beater bar should start to function once again
Jul 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Radio CD not working & lights don't flash remote keylock
Sometime the computer in car will shut down a circuit when it sees a problem even if it only occure once. You can try to disconnect the battery for at least 2 min so all sys power off (some have capacitors that mantaine a charge for short time). If a battery disconnect does not clear problem you have go to dealer and have them to clear codes and reset you modules and your preferences
Feb 15, 2009 | 2004 Dodge Caravan
Big sceen tv magnavox
some transistor in the power supply causing this problem
Dec 21, 2007 | Vizio GV42L 42 in. LCD Television
Ranger Communications RCI-6900F-25 CB Radio Logo
96 people viewed this question
Top Ranger Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jon Piercy
Mike Charette
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
