Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
I have a pt5598hdix projection television. the screen showed red and green lines from the top and bottom. the screen showed u at top coming down same with bottom going up. then it came in on both sides. there was a small pop sound in back and the screen shut off and sound came back on. it is a 55" screen. is it cheaper to fix or buy a new t.v.? and could i fix it my self? thank you, robert hopkins
  • 10,515 Answers
Ok, you probably have a failing convergence stage. This is very very common in older projection TVs like yours - maybe the #1 problem.
The TV has three color tubes in the lower half of the cabinet that project an image off the main mirror and onto the back of the screen. The convergence board processes the signals to the tubes and adjusts the light beams so that the red, blue and green images all line up. When the board fails, the light beams don't line up and you get the '3D' image with the separated colors and bowing near the edges.
The board has two main components called convergence amplifiers (some call them STKs or convergence ICs). They can fail. It is also common for some pico fuses or fusible resistors on the board to pop. If all three colors are off, then the STKs are probably bad. If only one color is off, then it could just be a pico fuse or other small component in the signal path.
You have three choices.
1. Some people have fixed the board themselves but it is not a job for a beginner. The parts are only about $70 but you need to know what you are doing. I can point you in the right direction but you need to have a good understanding of soldering and troubleshooting basic electronic components. You would need a DMM and soldering tools. Here is what is involved - it will give you an idea: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
You can buy the kit for your TV here: www.tvrepairkits.com
2. You can try and find a rebuilt board. This would probably cost around $300 and you would need to pull the old one out and put the new one in.
3. You can have it professionally repaired. This would probably cost around $400-$550
I'm sorry it isn't the best news.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 02, 2011
The color was off on the tv i took the bottom back off and there was a box with three screws on top and three screws on bottom that adjusted the colors when i turned the top left screw a little the three...
turn the center dial ( for green) down slightly then turn the other two the red and the blue up slightly to get the best screen without a dominate color screen.
Sep 02, 2011 | Philips 50P8341 50" Rear Projection...
I have a Mitsubishi 55"
This set has a convergence problem. You should only need to replace the IC. Part is STK393-110. It sits on the middle board behind the large heatsink. Use a heat transfer compound to ensure repair lasts. If you have no experience soldering (or unsoldering) please use a professional for the work. The traces are fragile and I have fixed many mistakes local DIYers have committed. Goodluck.
Jan 20, 2011 | Mitsubishi WS-55511 55" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
KP-51HW40 Sony 51" Fades to blue screen
The service manual on page 8 shows how to adjust the Red/Blue/Green screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Aug 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Convergence Problem RCA HD52W59
you need to test all cables then make shure it is not your tv.
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
Tv is messed up
I got a question.
Do you have any stereo speakers anywhere near your television?
This sounds like something a magnetic field could cause from speakers being too close to the tv.
If so try to relocate them and see if the problem goes away.
Jun 15, 2008 | Hitachi 57SWX20B 57" Rear Projection...
I have a phillips rear projection 51PW9303 red and green lines showing in the left corners and red line thru middle of screen, bottom of screen shadows and so does left top corner if numbers and...
sounds like youre describing a convergence problem. Do the letters look like theyre 3D? If so you will need to replace both Convergence ICs STK392-120 you can get replacements at the following link and they include installation instructions with pictures plus gree tech support. heres the link.
http://servicemanuals.vstore.ca/
Apr 24, 2008 | Televison & Video
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
48 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
