Question about Sony DCR-DVD755/E DVD Camcorder
My Sony DCR-DVD106E Handycam sometimes during recording gives an error message "Disk cover open, Accidentally. Turn power on again" and on doing so, sometimes couple of times, it shows "Recording on disc disabled".
SOURCE: DCR-DVD108 Problem
It's the disc not the camera......I purchased a 3 pack of Sony DVD-R discs. I put the first disc in and it recorded once. The next time I tried to record I got the message "movie recording disabled". After calling Sony, searching online, resetting the camera and reading through the manual I replaced the disc with another from the 3 pack and it is recording just fine. I read that recording straight to DVD has many problems, and I believe this is one of them. SONY SUCKS!!!!!
Posted on Dec 20, 2008
SOURCE: "Movie Recording disabled"
guys hope you all found the solution like me who had same issue. if you noticed, it says about the aspect ratio and that means the formated disc aspect ratio is not compatible with the aspect ratio your camera need. so re-formating the dvd with right aspect ratio solved the problem quickly and we have peace.
bayaraa
Posted on Jul 05, 2008
SOURCE: Sony Handycam DCR-DVD108 - Carl Zeiss Vario-Tessar Optical Zoom 40x
Please, I need support of camera technical carl zeiss vario tessar with otptical zoom 40x
Posted on Oct 09, 2008
SOURCE: Disk cover open, accidentally. Turn on power again
Haha, yes finally what a pOS!, But I got it!!
So I got to thinking well the sensor or something be messed up a bit. I found that the cover a very slight amount of play.
So hell , I put a C clamp on it. I started to record. Sweet, it worked!!! The cover was stuck so the sensor wasn't tripping.
Well that worked, but I didn;t want a c clamp on my camera all the time, so I had some Automotive Amazing Goop,
I lined the cover edges with the sealent and let it dry. Now when I close it , it stays closed and records without a problem.
The only thing is its tuff to open, I use a skrew driver, or small nail.
But it was unusable before, and at least I can use it.
Good luck.
Posted on May 16, 2009
welcomejee
  • 10594 Answers
SOURCE: i have a sony handycam dcr-dvd 340 which is displaying recording
Format mini DVD disk with camera Menu format option.
This will solve your problem.
Posted on Jul 03, 2009
Dcr dvd106e handycam sony
non replacable builty in rechargable
Nov 22, 2013 | Sony Handycam DCR-DVD108 DVD Camcorder
Why do I see MEMORY STICK ERROR on my Sony camcorder?
Check the memory stick for a little slide lock on the side. Make sure that is not in the locked position. This feature is there to prevent people from recording over special memories, like weddings. But sometimes during handling (or just not knowing) people accidentally switch it to "lock"
Good luck
Oct 03, 2012 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
Good luck.
Sep 25, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Error Message: Disk cover open, accidentally. Turn on power again.
When you open the door you will see 2 metal tabs that are sensors to that are pushed by 2 plastic tabs on the door that push on the metal tabs to let the camera know the door is shut. For whatever reason these tabs are not pushed up enough and I triggered them by sticking something in there to make contact. I used the end of a toothpick for now. May be primative but it works for now and I may look for a method to make it permanant but at least my camera works now
Jun 20, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
SONY HANDYCAM DCR-40
Lens cover error message comes when its not opend. There is a switch inside Front Cover (where lens and mic mounted) got bad contact. Open that Front cover and unscrew the circuit board, put 1 drop of W-40 cleaner oil and fix back all things.
Apr 27, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Error message + disc opened acidentally + recording disabled
1. cleaning the laser lens with isopropilic alcohol and q-tip
2. Try the reset button on the bottom of the camera. Tilt your camera and look below the LCD Display Backlight button on the bottom edge of the curved portion of the camera. You will need a paperclip or tip of a ball point pen to push the recessed little button. Place the camera on a level surface and try again. We find that the camera is very sensitive to tilting, as it gets older.
3. Make sure you format format at was FAT not fat32
4. All you need to do is "Quick format" the disk with the CAMERA rather than the memry stick plugged into the computer drive.
5. For sony error c:1301 using mini cd's: there is a program that recovers data from cd's that works with disk that have this error. It called "cdroller" Homepage is : www.cdroller.com
6. just take the memory stick off and re-insert it lot of times.. just keep doing it.
Apr 12, 2007 | Sony Handycam DCR-DVD205 DVD Camcorder
Sony DCR-DVD755/E DVD Camcorder Logo
145 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
