Question about Hotpoint Ultima WF860 Front Load Washer
How to remove child lock on a aqualtis hotpoint washing machine
noffie
  • 10 Answers
SOURCE: how do you replace a
The belts that come on a hotpoint aqualtis washing machine is a stretch belt there is no adjuster for it but there is a little trick. TO HELP YOU SOLE THIS YOU NEED A BOWL AND A KETTLE. FIRST FILL THE KETTLE WITH WATER THEN PLACE YOUR BELT IN THE BOWL AND ONCE THE WATER HAS BOLIED POOR THE HOT WATER IN IT LEAVE IT FOR 5 MINS THEN TAKE THE BELT OUT BUT BE CAREFUL NOT TO BURN YOUR SELF NOW GRAB THE BELT AND PULL IT BY THE BOTTOM AND THE TOP BY DOING THIS BELT STRECHS ENOTHGH TO FIT ROUND THE FLYWHEEL AND MOTOR ALWAYS HOOK THE BELT FROM THE MOTOR FIRST THEN ROUND FLYWHEEL I RECOMMED WEARING GLOVES WHEN DOING THE JOB KEEP ME INFORMED ON HOW IT GO'S NOFFIE......
Posted on Apr 08, 2008
SOURCE: how do you remove the child lock off the washing machine
hold the child lock button down for a few seconds.
Posted on May 09, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint aqualtis aqxxd169 washing machine
The m/c will not normally spin if there is a lot of water in it.
You need to check the pump to see if it is working o/k, and check the filter also.
The filter is located behind the bottom kick strip at the front.
Undo screws ,remove strip and unscrew the pump cover anti- clockwiwse to remove, be care ful as there will be some water run out.Clean filter and try again.
Plz rate my solution.
Thanks.
Posted on Dec 31, 2008
SOURCE: My Hotpoint Aqualtis washing machine
My Aqualtis just stopped mid program with F-05 on the display. This is apparently a failure to drain properly. I was luckily able to hold the power button to cancel the current program drain the water out (very slowly) and empty the machine.
THIS IS HOW I RESOLVED MY PROBLEM.
Disconnect the machine from the mains. Turn off the water supply to the machine. Disconnect the cold water pipe from the machine at the top corner.(Watch out for some water) Remove the drain hose from where you have it going to.  Pull the machine out and lay it gently down on the left side panel (use a towel to protect the side and absorb any water). Then, from the now exposed underside there is a black rubber pipe connected to the pump (black) coming from the main drum. Use some pliers to pinch the steel spring that clamps the hose in place and remove. Then using your fingers (there is nothing sharp in there) see if you can find any blockage.
I REMOVED: A pound coin, a dairylea slice wrapper and a piece of kinder bueno packet.
Carefully replace the black hose making sure it is fully on. Replace the drain hose, reconnect the water pipe and turn the water back on. (check to see it's dry with no leaks). Plug it in, turn on and that for me was it. Job Done.
Posted on Feb 01, 2009
SOURCE: machine won't wash because 'child lock' is on
Holding down the Start button for over 5 seconds turns the child lock on and off.
Posted on May 15, 2009
How to remove child lock on hotpoint washing machine
With most hotpoint washing machines you hold the 'Child Lock' button down for 4 seconds. You will then hear a bleep and the child safe icon will go out.
Alternately interrupting the power supply (switching it off at the wall) will usually disable the child lock.
Dec 29, 2016 | Hotpoint Washing Machines
My hotpoint aqualtis model number aq9f 492 u is showing f6 what does this mean
F06 Door lock fault
Issue: Washing machine door cannot be opened or closed / when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
Dec 29, 2015 | Hotpoint Washing Machines
How do i unlock the door manually it's locked with the washing inside
do you have the manual I found this answer but have no idea if your machine is like the one described .Then opened the door (if locked use yellow tab behind kicked panel to open
Feb 19, 2015 | Hotpoint Aqualtis AQXXL129PM Washer Front...
Washing machine door wont open on hotpoint aqualtis after wash.The door locked sign os still on no matter what i do.
remove the front kick strip, on the LHS you will notice a yellow tag. with the power on on the machine pull down twice gently on this tab. this should unlock the door.
if you now notice the drum is full of water its more than likely your filter is blocked and this is what caused the door not to open.
Jun 25, 2011 | Hotpoint Washing Machines
Hotpoint aqualtis giving H20 error, looks like fill problem, but cannot see anything stopping the water flowing into the machine.
i have hotpoint aqualtis, it washes & empties but then starts flashing when ready to rinse. any suggestions?
Dec 04, 2009 | Washing Machines
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
165 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
