FixYa.com
Tags:
Whirlpool RBD245PDS Electric Double Oven
The upper oven door is
posted by pastorcurt on Jul 09, 2008
The upper oven door is locked shut and will not release. All lights are off on the display panel and the oven does not respond when any setting are pushed. I have reset the circuit breaker several times but upper oven remains locked and no panel buttons respond. All other electric is fine in the home. Any suggestions
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 09, 2008
FixYa! (100)
aborcass
Rank:Guru Guru
Rating: 89%, 989 votes
im to assume that this happened while self cleaning, sonds as if you have had a high limit thermostat go bad adn has shut down oven function( depending on model there is also a fuse inline with the main control panel to protect it from the heat/ power surge, unit will need to be pulled out to acess fuse behind the unit
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Ovens problems?
self cleaning power out problem
Hello did you ever figure out... Answer This...
Problem with whirlpool
Beep from Micro-WaveOven
Can you tell me how to stop the... Answer This...
Resetting oven temperature...
In testing our Whirlpool oven... Answer This...
Whirlpool Dbl Wall Oven Mdl....
DSp. panel is blank/ Oven... Answer This...
Repair Service
Find Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
