Question about RCA F25645 25" TV
I've connected my new Sony Blue-Ray Disk Player to my RCA F25645 TV via the three (Red, White, Yellow) composite cables but the screen only says "unusable signal" and will not display the Blue Ray Disk Player's setup screen. Any trouble-shooting advice would be greatly appreciated.
  • 70 Answers
The output from the blu-ray is probably component video, where the brightness, blue and red difference signals are the three outputs. Sounds like the TV only has composite video input so won't work. Check the manuals, if you can get a composite signal from the blu-ray then your TV will display it but not high definition. A HD LCD or plasma TV is needed to show the blu-ray films in high definition.
Posted on Jan 02, 2011
2 Suggested Answers
gopakumarg43
  • 74136 Answers
SOURCE: I've connected my new Sony
Hello
There is no RGB connector input at the rear of your RCA tv. There is Video, Audio-L, Audio-R and S-video inputs. You won't get any response from your TV, if you connect the RGB connector to the above said audio video connections. You can connect the Blu-ray player with S-Video connector. After connecting it with specific S-Video cable to your TVs S-Video input and Blu-ray players' S-video output, assaign the input of your TV to S-Video, by going to its Menu, and sufing through it. OK.
How do i connect a Blu-ray player to my TV
It should connect best to the one with blue,green,red and then the two for sound--red and white---This is component hookup.
once connected you select the input via the remote or menu..
The ones with the yellow, white and red are composite (yellow is video and color and red/white are audio---doubt it will work off blue ray unless similar outputs on that.
Mar 19, 2012 | Toshiba 36A60 36" TV
What cables go from my 55 inch hitachi tv to connect on the back of the dvd player . I have two monster cables red and blue together and three cables red blue and green together.
I have never herd of a red and blue combo but, The three, red, blue, and green are "component" cables. Hopefully your DVD player has a red, blue, adn green component out, not to be confused with red composite out. Composite cables are yellow, red and white, and, your tv has componenet in. The component cable will give you the best video quality. When installing make sure they are inserted all the way but twisting and wiggling or you will have a bluish, grenish, etc. picture. The composite cables give you the video only, so you will have to provide the audio. Audio can be achived using composite red and white or digital optical.If you second monster cable is red and white you can probably use those To go from "audio" red and white out on DVD to audio in red and white on tv. You must use the same audio input that corresponds to you video input.
Apr 09, 2011 | LG BD550 Blu-Ray Player
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
My dvd player only plays movies in black and white. When I watch tv, it's in color so I know its not the tv.
I suspect you may have connected a COMPOSITE cable (red/white/yellow RCA type) to the COMPONENT video input sockets on the back of the TV.
COMPONENT requires 3 RCA type video cables - the plugs and sockets are usually colour-coded red, green, and blue. COMPOSITE only uses one RCA type video cable - the plugs and sockets are usually colour-coded yellow.
If you connect the yellow video cable to one of the three component inputs you will get a black and white picture although you will still have audio if the red and white cables are correctly connected.
If you are using a COMPOSITE cable (red/white/yellow RCA type), please check your connections. Make sure you have not connected to any sockets - either on the TV or the back of the DVD player - under the heading of "COMPONENT" - or individually marked "Pr", "Cr", "Pb", "Cb" or "Y".
If you have verified that you are using the correct sockets on the TV and it still doesn't work or if you are using any other type of cable, please let me know which cable you are using and the model number of the TV and the DVD player. I will then be able to assist you further.
Regards,
BElectric
Jan 14, 2011 | Insignia DVD Player with MP3 Playback/JPEG...
Why original DVDs appear in Black and white only when palyed on the Sony DVP-NS57P player?
Usually, when you get a black and white version of the film, either the cable connection is messed up or the dvd signal and the tuner are mismatched (say NTSC TV getting a PAL signal from the dvd).
The cable mismatch would be connecting composite video output (using the AV cable that came with the unit) to one of the three video jacks of the component video input on the TV. The obvious first thing to check is that the cables are good and in the correct configuration (yellow to yellow for composite or red, green and blue to red, green and blue). Try a new cable in case there is a damaged cable, particularly with a component video cable.
The tuner mismatch is more common with the handheld dvd players.
I hope this helps.
Jan 08, 2011 | Sony DVP-NS57P
I've connected my new Sony Blue-Ray Disk Player to my RCA F25645 TV via the three (Red, White, Yellow) composite cables but the screen only says "unusable signal" and will not display the Blue...
Hello
Jan 02, 2011 | RCA F25645 25" TV
How do i connect my dvd rv32 to my sony tv?
It will depend on your TV's inputs. The included cable is a composite A/V cable. This will work. Match the RCA plugs on each device (yellow to video out on the DVD player, video in on the TV; white and red audio go similarly). Alternatively, you can get and use an S-video cable.
For a better picture if your TV has Component video, get a Component video cable (this has three RCA jacks colored red, green and blue on each end) and then use that. You can get a separate audio cable that only has the red/white RCA jacks (or use the composite video with the yellow video jacks dangling).
If your TV doesn't have Composite video inputs, you need a RF modulator (Composite to RF converter). These are available at many sites, including Radio Shack.
I hope this helps.
Sep 06, 2010 | Panasonic DVD-RV32 DVD Player
There is no colour on the movie
Make sure you have the cables hook up right. If you are running component mode it takes three for video blue red and white ends. If you are running composite it takes red, white, and yellow.
Nov 20, 2009 | Toshiba HD-A20
I'm a senior citizen and bought a very simple DVD Player by you, but can't get it connected correctly. I am not a stupid person but beginning to feel like one. Please HELP>
This player has the typical composite and component TV connections. If you have an older standard TV, you will need a composite to RF TV adaptor. If you have a newer widescreen HD Television, you should be able to connect the composite or component cables to it directly Composite is the 3 video cable bundle (Red, Green, Blue), and composite is the yellow single connection. Audio connects via the standard white/red connectors. If your TV is newer and supports multiple inputs, make sure you can switch to the input you are connected to via the TV remote! Check your manuals.
Sep 05, 2009 | Sony DVP-SR200P DVD Player
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
RCA F25645 25" TV Logo
153 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
