Question about Samsung Televison & Video
How to change input on an old samsung(picture tube) without a controller i wanna change input from tv to video but i have no controller
    Sergeant:
    Champion:
  • 342 Answers
You press the channel down until it says INPUT or video 1 that should help
Posted on Jan 02, 2011
The colours on my tv screen are all green and distorted can you tell me what the problem is its a samsung and its only 2 years old
YOU MAY HAVE CONNECTED THE RECEIVER TO AN INPUT ON THE TV THAT IS INCORRECT FOR THE SIGNAL OUTPUT FROM THE RECEIVER.
GET YOUR TV BACK ON THE CORRECT INPUT OR CHANNEL...CYCLE YOUR TV THROUGH ITS INPUTS BY...PRESSING THE INPUT, SOURCE, OR TV/VIDEO BUTTON ON YOUR TV REMOTE OR THE TV ITSELF.
IF THE PICTURE IS NOT RESTORED, CHANGE YOU TV TO CHANNEL 3 OR 4 USING TV REMOTE OR THE TV ITSELF.
IF THIS IS A 2ND TV, TUNE YOUR TV TO CHANNEL 60-73 USING THE BUTTONS ON YOUR TV REMOTE OR THE TV ITSELF.
ONCE YOUR TV PICTURE IS RESTORED, PRESS AND RELEASE THE SAT MODE BUTTON ON YOUR REMOTE TO ENSURE YOU'RE IN THE PROPER MODE FOR CONTROLLING YOUR RECEIVER.
YOU CAN ACCESS YOUR FEATURES, SETTINGS ETC, ON YOUR MENU BUTTON ON YOUR TV REMOTE.
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Samsung Televison & Video
When I switch on the unit, i can hear the sound but there is no picture
Hi! Welcome to Fixya!
If you are unable to view video on your television set, the issue may be that the TV's video input selection does not match.
The TV input source must match how the device for example DVD player is connected to the TV. At the back of Samsung's LN40A650A HDTV are three HDMI inputs, plugs for component input, an antenna input for the DTV receiver and a VGA input. Please check on what port the device is plug.
To correct the issue, use the TV's remote control and change the video input selection.
  • Press the Menu button on the remote control and navigate to TV Input
  • Only ones that are actually connected are highlighted and available.
  • If there are multiple device connected please make sure you select the device you want to connect.
You may also check if all cables are properly connected.
Thank you.
Mar 12, 2011 | Samsung LN40A650A LCD TV
My 21" Plano TV , replace the Picture Tube becous
It sounds to me like it has the wrong scan coils fitted to the replacement tube and there is no fix for that. You will need to fit the correct tube or have the old tube re built.
Dec 28, 2010 | Samsung Televison & Video
Samsung DLP TV; Green Lines
If you get green vertical bars or green dots in the picture but not in the menu screen (Digital board symptom)
Feb 28, 2010 | Samsung DLP HL-P5663W 56" TV
Need DTV input channel on Magnavox Model
hello Sofia. The only signal coming to your tv, ever since the country went to digital signals is coming through your direct TV. For that reason you must use the input from direct tv to make the tv work.
Regarding your question about old fashioned tubes, no, very few of the old fashioned tube tv's are still in use.
I hope I have answered your questioins and solved your problem. Regards, Joe.
Nov 07, 2009 | Televison & Video
Toshiba Tube TV 32AF45 Picture Squeeze in middle
Try unplugging TV while it is on and let sit for 20 minutes. Re-connect and see...
It sounds like your horzontal control is bad. It requires a new circuit board.
Mastersage!
Feb 18, 2009 | Toshiba 43H70 43" Rear Projection...
Samsung HLR5067W goes from a normal picture to snowy green color
Greetings!
I hate to be the bearer of bad news, but it is not something that has a quick fix. Without inspecting it myself it is impossible to say, but the last three of these that I have seen have been bad digital boards and can be a real bear to change, even when you have experience.
I would get slightly different video symptoms when I would switch between the coaxial input to the component input to the HDMI input. But in all cases my on screen display and menu were anomally free. Hope this was helpful, even though I don't think it is something you should attack yourself.
Rob
Jan 14, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung Model # HCL5515W S/N 3CET300477H
If you have on-screen display change to video input and try bypassing tv tuner using audio/video cables. If no osd, problem could be shorted picture tube or problem on crt board, often caused by leaking coolant from tube(s). This is fairly common on your model. Hope I've been helpful.
Apr 19, 2008 | Samsung HCL5515W 55" Rear Projection...
Sony KV36XBR200
Picture tube is bad, time to retire this one!.....T.
Oct 22, 2007 | Televison & Video
Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Jun 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Televison & Video Logo
271 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
