Question about Kodak Office Equipment & Supplies
How to I open rear access cleanout area . printer it saying clear all paper
SOURCE: How to clear internal paper jam on CLX-3160FN Samsung Multifunction Printer
I found another site that suggested these steps:
1. Check that all of the black plastic pieces turn freely when paper is fed through.
2. Take a fine grit sandpaper and gently sand the rubber spool/wheel in the bottom center of the pritner to re-texture it.
3. Clean all rollers with isopropyl alcohol.
Step 2, Sanding the rubber roller seemed to fix the problem completely.
Posted on Sep 15, 2008
frcs68
  • 1605 Answers
SOURCE: rear access panel open
open the rear panel, check all path is clear. close the rear panel, mkae sure that the sides of the rea panel is locked in place. there is micro switch that detect the door panel. if the door is close correctly the micro switch os actived then you will get the error.
Posted on Jan 13, 2009
SOURCE: how do you get to the jammed paper in this device
Dell 5100cn - what in the heck does load MPF mean? I can't find a definiation anywhere. Thank you
Posted on Mar 31, 2009
shockwave727
  • 262 Answers
SOURCE: I have a paper jamb. Page 45 of the manual says to
Gently press and hold the tab on the left side of the rear access door assembly. Carefully pivot the left side of the rear access door assembly toward you to remove it.
Note: Before you remove the rear access door make sure to remember the original position of the rear access door., base on my experience its really hard to reinsert the rear access door. GudlucK
Posted on Nov 05, 2009
  • 1044 Answers
SOURCE: There is a foreign object in my printer and I
A crude method but works sometimes is to lift the printer shake it ans then turn it up and down and side ways. May be the foreign object gets displaced/dislodged and then it can drop out from any of the openings when you are shaking it or turning it up down. Otherwise I will not advise you to open the printer yourself. Please have it checked and serviced by a company technician.
Posted on Apr 11, 2011
How can I clear a paper jam on Kodak all in one printer?
www.kodak.com/go/aiosupport
Getting help on the Web
For more troubleshooting information:
Paper jam
• Check for paper in the rear-access cleanout area.
• Open the printer access door and gently remove any paper from inside the printer.
• Make sure the paper in the tray is free of tears or creases.
• Make sure you do not overload the paper tray.
For more information, go to
www.kodak.com/go/stepbystep
Jan 03, 2015 | Kodak ESP Office Equipment & Supplies
Unable to locate rear access cleanout area
It will help if you give the make & model
Jan 11, 2014 | Office Equipment & Supplies
I had a paper jam in my ESP 5200 printer. Now I can't figure out how to get the light gray back piece back into the printer. There are no pictures for how it fits. HELP!
Good Day Auntbigsis!
The gray piece at the back is the cleanout assembly.
To Install the cleanout assembly back at the rear of the printer after removing paper jam, just follow the procedure:
  1. Insert the right side of the cleanout assembly into the back of the printer so that the tabs fit into the slots on the right side of the cleanout area.
  2. Rotate the left side of the cleanout assembly until the latch snaps into place.
  3. Pull on the cleanout assembly to insure that it is seated.
Jun 28, 2011 | Office Equipment & Supplies
We have a esp 3250 all in one printer. We had a paper jam. We removed the paper jam and now the printer is telling us that there is still a paper jam. Please tell me what to do next. Thank you.
Reset the printer:
  1. Turn off your printer.
  2. Wait 30 seconds.
  3. Remove all paper from the paper input tray(s).
  4. Make sure the paper output tray are open and free of any paper.
  5. Turn on your printer
Clear paper jam:
  1. Open the paper tray and remove any paper.
  2. Remove any foreign objects.
    autourg01093003id2991643
  3. Remove the cleanout assembly from the rear cleanout area:
    • Gently press and hold the tab on the left side of the cleanout assembly.
    • Carefully pivot the left side of the cleanout assembly toward you to remove it.
  4. Check the inside of your printer for a paper jam. If necessary, slowly pull the jammed paper from your printer.
  5. If paper is not visible, check your printer for foreign objects, such as paper clips or staples. If necessary, carefully remove the foreign objects from your printer.
  6. Check under the printer for obstructions. Remove any debris. If necessary, relocate the printer to a flat, hard surface.
    IMPORTANT: If the cleanout assembly is not installed and seated correctly, paper jam or paper tray empty errors may occur.
  7. Install the cleanout assembly:
    a. Insert the right side of the cleanout assembly into the back of the printer so that the tabs fit into the slots on the right side of the cleanout area.
    b. Rotate the left side of the cleanout assembly until the latch snaps into place.
    c. Pull on the cleanout assembly to insure that it is seated.
  8. Go to Upgrading all-in-one printer with latest firmware and follow the instructions to download the latest firmware version.
  9. Open the printer access door.
  10. Remove any debris or obstructions.
    autourg01093007id2994051
  11. Connect:
    • any cables that were disconnected
    • Power cord
  12. Wait 30 seconds, then turn on the printer.
hope this helps
Dec 04, 2010 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
Paper problems
First thing you need to do Turn off the printer and Open the rear access door or cleanout area as we call that (back door) and clean all the rollers on the back. make sure also that you are using the deskjet paper and if you put 20 pages of paper on the paper tray make sure to fan it before you put it in. the alarming sounds or blinking on the printer indicates that the paper is jamming on the printer
-The ink is normal to move to center or left to right, But if you open the printer access door the ink or the printhead should stay on the middle for you to able to replace the ink cartridges and remove the printhead
Nov 08, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a paper jamb. Page 45 of the manual says to open the rear access area and pull out the paper. There are no drawings showing how to access this area. How do I open the rear access area?
Nov 03, 2009 | Kodak ESP 5 Printer
How do I clear a piece of paper jammed in my Kodak ESP5 All in one printer
1 Lift the output tray.
2 Open the paper trays and remove any paper.
3 Turn OFF your printer.
4 Wait 30 seconds, and then disconnect the following from the back of your printer: USB cable, Ethernet cable, Fax cable, AC power cord.
CAUTION: Do not use force when removing the paper from the printer.
5 Check inside the cleanout area for a paper jam. If necessary, remove any paper or debris.
6 If paper is not visible, check the printer for foreign objects, such as paper clips or staples. If necessary, carefully remove the foreign objects from your printer.
7 Open the printer access door.
8 Remove any foreign objects from the printhead access area, and then close the printer access door.
9 Connect the following to the back of your printer: USB cable, Ethernet cable, Fax cable, AC power cord.
10 Wait 30 seconds, and then turn ON the printer.
11 Squeeze and move the paper-width guide on the paper tray to the left.
12 Load the paper into the upper paper tray.
13 Squeeze and move the paper-width guide to the right until it touches the paper.
14 Close the paper tray.
Best of Luck
saj
Nov 02, 2009 | Kodak ESP 5 Printer
I have connected up all leads , cartridges and instalation as per manual. the printer turns on but will not get the paper moving.
Hello
here are the steps.
1. Remove the paper from the paper tray.
2. Fan the stack of pape
3. Open and fully extend the paper tray.
4.Load paper into the paper tray.
5.Align the paper with the dotted alignment lines on the paper tray, then adjust the paper guides until they lightly touch the paper.
If issue persists,
1.Disconnect the following from the back of your printer:
* AC power cord
* USB cable
3.Remove the paper from the paper tray.
4.Remove foreign objects or debris from the paper tray. 5.You may need a flashlight to view the back of the tray.
6.Open the access cover for the printer
7.Remove foreign objects or debris from the paper path. 8.You may need a flashlight to view the paper path.
9.Remove the cleanout assembly from the rear cleanout area:
a.Gently press and hold the tab on the left side of the cleanout assembly.
b. Carefully pivot the left side of the cleanout assembly toward you to remove it.
10.Lightly moisten a lint-free cloth with water, then gently clean the surface of the feed rollers. Advance the feed rollers with your thumb, and continue cleaning.
11.Allow the feed rollers are completely dry.
12. Install the cleanout assembly.
a.Insert the right side of the cleanout assembly - 1 into the back of the printer so that the tabs - 2 fit into the slots on the right side of the cleanout area.
b.Rotate the left side of the cleanout assembly until the latch - 3 snaps into place.
c.Pull on the cleanout assembly to insure that it is seated.
13.Connect the following to the back of your printer:
* AC power cord
* USB cable
14.Wait 30 seconds, then turn on your printer.
15.Pull the paper tray all the way out until the paper 16.Squeeze and move the paper-width guide to the left.
17.Fan the stack of paper and load it into the paper tray.
18.Squeeze and move the paper-width guide to the right until it touches the stack of paper.
19.Lift the small gray paper stop until it is perpendicular to the paper tray.
20. Make a print
If issue persists, the printer itself needs to be replaced. Call 1.800.421.6699
Thanks
Sep 25, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 7 has a paper jam I cannot remove the paper
If you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below.
1. Open the printing area of the printer (containing the ink cartridges).
2. The Ink cartridge holder should be to right side of track.
3. Look on left side, below the track for the cartridge that is used to
clean the print heads.It can be identified by a square black pad
approx. 1" sqaure that appears to be made of "felt".
If it is visible this is most likely your problem.
4. To correct problem locate the flat latching lever approx. 3/4" wide that
sticks up about 1/2" above the cartridge. It is locacted just behind
the "felt" square. Gently push lever toward rear which should free the
cleaning cartridge and allow the entir cartridge to move slightly
backward.
5. Close the top of the printer and cycle the printer off and back on.
If this is the problem, the "paper jam" error will now be gone.
This is such a simple fix I do not know why kodak does not inform
customers of this problem and how to fix it.
May 09, 2009 | Office Equipment & Supplies
57 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
