Question about Philips 42PFL3704D LCD TV
I need help with the color there is no red or green went thru the manual and the sample colors are ok, went back to regular program and colors are terrible,
    Sergeant:
    Champion:
  • 342 Answers
Check you cables like a VGA monitor you have three colors Red Green Blue on the cable and if one is broken then the color will not come in correct. on your device that feeds video to the tv try some different cables and inputs it might be a bad cable
Posted on Jan 02, 2011
I have an HP7540 monitor that I need to be able to change red, blue and green colors on thru the menu
I hope you know how to enter and navigate through the OSD (On-Screen Display) menu of your monitor.
Enter the menu and navigate to 'Color' menu.
Under that select 'User'.
Now you can select either Red, Green or Blue.
After selecting a color it can be increased or decreased.
Press Exit button to go back, select the next color and set it to your liking.
Sep 08, 2011 | HP Compaq FS7600 17" CRT Monitor
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Wire colors on source unit are incorrect need to know the order of color for a clarion drb4375. or a sample picture of colors from factory top and bottom.
Hello! TOP...RIGHT TO LEFT...Grey/Black...Grey...
Purple/Black...Purple/Blue (antenna)...Red (acc)
BOTTOM RIGHT TO LEFT...White/Black...White...
Green/Black...Green...Black (ground)...Yellow (constant 12)...Four blank...[Grey...White...Purple...Green]... speakers...
Guru.............Saailer
Apr 07, 2010 | Car Audio & Video
Toshiba 62; DLP 720P- Alot more red and green
You have probably have installed the wrong lamp or you installed a third party/off brand Lamp. If that is the case anything other than a Factory replacement Lamp will have a different color temprature. Install a Lamp that is listed from the manufacture.
Jul 14, 2009 | Samsung DLP HL-P5663W 56" TV
No sound on play back using camcorder on technika tv
Looks like you are using Component cables. There are five cables. The first three cables are Green,Blue and Red. These are the ones that are molded next to each other and are the Video signal cables. The other two cables are Red and White and they are the audio cables.
First to correctly hook up these cables you need to Connect (Match) Color for Color. (Green to Green, Blue to Blue, and Red to Red. To tell if you have correctly connected the Video cables is to look at the screen. If the picture looks ok (Normal with no colors missing then you have connected the video cables correctly). If you see a missing color meaning red, then switch the Red cables. The picture should be ok now. The remaining two cables are the Red and White cables. The "Red cable" is for the "Right" audio input and the "White" cable is for the "Left" audio Input". If all is connected correctly then you should have a good picture and Left and Right audio.
Jul 05, 2009 | Televison & Video
Dell 2300mp projector, colors bad
try reseating the vga cable. Try removing the cable, the green tint should disappear meaning that the color or lack of one of the primary colors blue/red/green were missing due to bad connection. or maybe you have a bad vga cable.
Feb 26, 2009 | Dell 2300MP Multimedia Projector
Pixma MP830 is printing things green that should be red
when you change all new cartridges (make sure all cartridge ok, and the cartridge pins connection ok) still red color lost, it is the trouble at print head ink chanel some of that is too dry for longer time less using , most CANON printer head is separated from the ink cartridge, two way you may try:
1) take out the ink cartridge, drop down a little the special cleaner (best clean tools buy from dealer), to the head ink chanel hole, then set back the ink cartridge and waiting minutes
2) try put the print head bottom surface touch a little cleaner or water 1-2 hrs, if you can take out the print head unit. still not fixed for some case that should change the print head unit.
Feb 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
RCA Pearl TH1100A backlight colors
Pp. 16-17 of your user's manual:
http://www.rcapearl.com/pdf/TH11xx_IB.pdf
Settings
Press forward to enter the Settings menu and then
press plus or minus or to highlight an item. Press play
repeatedly to change settings.
Backlight:
• to adjust the time before the display light
turns off (On/10s/20s/30s).
• to adjust the color of the display light
(Red/Blue/Green/Yellow/Cyan/Purple/White).
-Tha Mp3 Doctor
Dec 13, 2008 | RCA TH1101 MP3 Player
Monitor screen changes from regular color to a green tinted screen?
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Hope this helps!
May 31, 2008 | Dell 1503FP 15" LCD Monitor
JVC AV 56WP74 Problem after fix
Will the colors move into alignment controlling them manually?
If you can get the colors to align but they simply won't hold it's a matter of programming. If they won't align you still have a failure in the convergence circuit. If red or blue will only move so far but not close enough to align you have an amp problem.
Bill
Mar 31, 2008 | JVC AV-56WP74 56" Rear Projection...
Philips 42PFL3704D LCD TV Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
