Question about Intel Motherboard
GA M68M-S2P: Does not recognize boot HDD as SATA after "Load Defaults" done in BIOS. Shows HHD as IDE. Shows "hal.dll" missing report will not boot.
SOURCE: same problem
try changing the IDE cable, if this does not work enter BIOS setup utilityand ensure HDD detection mode is either aouto select or IDE depending on your BIOS you may have to look for a setting that allows you to use IDE not SATA or both.
Posted on Feb 26, 2008
  • 16 Answers
SOURCE: Connecting an IDE HDD to a SATA port using an IDE to SATA converter
Not complete product...need to buy additional adapter for IDE to SATA power source.
IDE drive will have to have the power source hooked up as well as the adaptor hooked up.
Installing the adaptor only will not work. Your computer should have the 4 pin plug for the power to the IDE drive, other wise you will have to buy another adaptor.
Posted on Mar 23, 2008
colliewob
  • 781 Answers
SOURCE: Cannot change cmos settings.
Try this.
Open case somewhere on motherboard will be (reset BIOS) or word to that effect. it will be a small 2 pin connector with a jumper on 1 pin connect the jumper across both pins for 30 seconds remove jumper fit back over 1 pin (not get lost) reboot your BIOS should have reset to default hope this helps post comment if does please
Posted on Jul 27, 2008
  • 3 Answers
SOURCE: IDE motherboard gsvr845, trying to install sata2 hard drive
sir
i need intel 845 audio driver download
Posted on Mar 17, 2009
tolexade
  • 81 Answers
SOURCE: bios problem
remove your motherboard battery for some times and restart your computer. thanks
Posted on Jul 19, 2009
I can't install win xp pro. on my G41MT-S2P..i always get "a disk error has occured" prompt
This model motherboard does not use IDE/PATA hard drives.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive. http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Sep 08, 2011 | Gigabyte Giga Byte Technology Ultra...
Just bought a brand new Gigabyte M68M-S2P and im getting a Disk Boot Failure on my HDD which uses an IDE connector. Not sur whats going wrong, and going into the BIOS its not recognising the hard drive as...
Is this a new HDD? Disk Boot Failure means it cannot boot from the HDD. Plus you mentioned that it is not detected on the BIOS. You need to have this HDD replaced. Not even a reformat can help at all. It is a hardware problem you have there.
Aug 01, 2011 | Intel Motherboard
Transfered XP to internal Sata disk with controller . MOBO A7V8X-X, BIOS version 1014. Disk is recognized during boot. Disconnected all IDE drives. System won't boot from sata disk. Booting from CD results...
get to the bios boot section
( on starting the computer hold down the delete key until the bios screen shows
in that section you will see boot preference
organize the sequence that the unit will boot from save and esc
so sata hard drive =1
cd=2
external hard dive =3 etc
Sep 11, 2017 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Serial port does not work on GA-M68M-S2P
Did you go in the Bios and turn it on. Here is there web site for driver downloads:http://www.gigabyte.com/products/product-page.aspx?pid=3270#dl
Feb 07, 2011 | Intel Motherboard
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
    Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Nov 09, 2010 | Acer Aspire 4720 Notebook
BIOS will not let me change boot sequence of hard drives. It lists both of them (one SATA and one IDE). Trying to recover info off IDE, primary OS is on SATA. How do I get BIOS to let me change sequence?
check the the jumper pins on the back of the HHD, SATA should be set to master & IDE to slave read the top of the HHD first coz some HHD's have master without slave presant.
boot up as normal then go into "computer" & get the data off the IDE drive.
Oct 20, 2010 | Intel D102GGC2 Motherboard
Gigabyte 945 gzm s2 doesn`t recognize HDD Western Digital 320 GB
You might need to change your bios settings from ide to sata. Have you already checked the bios settings? If everything is in order you might have a bad board. What have you tried so far?
Nov 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
HP Cpmpaq Presario V6000
XP wont be able to detect your hdd as you are using a SATA drive. You have two options here
1. Disable SATA function in the bios (easier to do) and use again your XP cd to install the software, it should be able to detect the hdd this time around
2. You have to slip stream the SATA driver to your XP CD and recreate another CD from it. (harder to do). Google "SATA driver slipstream XP" you will be directed to the proper sites
Apr 05, 2008 | HP Compaq Presario V6000T Notebook
How to format SATA drive
Hi, the setting will be in the BIOS menu. switch on and hit F2 or whatever it is for your motherboard (it should say on screen). then go to the HDD settings and enable SATA
Feb 20, 2008 | ASUS P4V8X-X Motherboard
Intel Motherboard Logo
245 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
