Question about Sony Bravia KDL-46VL130 TV
My Sony Bravia KDL-46VL130 is approximately 18 months old. When we turn it on, regardless if we use the cable signal, blue ray signal, or wii signal, we see that the left side of the tv displays distorted sections that seem to move as the color varies and it is blurry. After approximately 20-30 minutes the tv then seems to clear-up and looks better, however it still may be a bit dark, depending on the device and signal. Is there a bad component we should replace or is it more than a component issue?
3 Suggested Answers
tvhelp-Dave
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
joeguest2
  • 2080 Answers
SOURCE: i have a sony bravia
With the lights in the room turned off, does your TV screen still glow when it is turned on even though there is no picture signal there?
If your screen stays completely black, then most often, this symptom is a result of a failing POWER SUPPLY, but a faulty BACKLIGHT INVERTER BOARD can certainly cause very similar symptoms. Unfortunately, without a donor TV to swap parts with or a dedicated test rig, it can be very difficult to differentiate between these problems.
One way to quickly test this is to remove the rear access panel on the TV and replace the power supply circuit board with a new one, since this is the most often the source of the trouble.
You can usually find replacement circuit boards online by searching for your TV's model number.
Here is a link to the SHOPJIMMY.COM parts supplier website with all the replacement circuit boards available for your model of TV:
http://www.shopjimmy.com/sony-kdl-40s2000
And here is a link to a POWER SUPPLY CIRCUIT BOARD for your model of TV currently available online from SHOPJIMMY for about $68 US plus shipping:
http://www.shopjimmy.com/sony-a-1144-543-e-g2-power-supply.htm
And here is a link to a replacement BACKLIGHT INVERTER BOARD for your TV which is unfortunately currently out of stock. The online inventory does tend to change pretty regularly so if you do end up needing this part, you can always check back later to see if one becomes available:
http://www.shopjimmy.com/sony-1-789-500-33-backlight-inverter.htm
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
The repair / replacement procedure is not extremely difficult if you have some basic electrical safety knowledge and some basic electronics / mechanical repair skills.
You will need to unplug the power cord from the unit, lay the TV screen side down on something soft and flat like a bed, and then remove the rear access panel or the entire rear cover as required in order to access the circuit boards inside.
When you remove the rear cover and access the circuit boards inside, just check the part number that is printed right on your circuit boards and confirm that they exactly match the ones provided in the online listing. Also make sure that any part you order is labelled "TESTED WORKING" in the condition description. Any part with a condition description of "AS IS" is probably faulty itself as well.
Then unclip and remove the various electrical wire connectors leading to the power supply circuit board. Then remove the screws securing the circuit board to the TV frame and then remove the power supply circuit board. Be sure to avoid touching any large capacitors on the circuit board which can retain a nasty charge even after the unit is unplugged.
Then just screw in the new circuit board and connect all the wire bundles to their appropriate connectors on the new circuit board and then replace the rear cover. Then plug in the power cord and test.
Here is a link to another Expert's solution to a similar problem which includes links to his excellent and informative set of LCD TV / MONITOR TROUBLESHOOTING GUIDES:
http://www.fixya.com/support/t10008425-when_turn_tv_picture_flicks_off
These guides will give you some idea of the various problems with LCD monitors and the associated repair procedures.
If you choose to rate BUDMRTN's troubleshooting tips by clicking on the YES THIS WAS HELPFUL icon on his solution page at the above link, then I thank you very much for your time and consideration.
Please comment back here to this page if you have any details to add, have any questions, have difficulty with the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
Joe.
Posted on Sep 03, 2011
Bright light ghosting and vertical and horizontal line on Sony Bravia 40
This is a problem with the inverter cable. It either needs to be re-seated or replaced.
Aug 21, 2011 | Sony Bravia KDL-46VL130 TV
Have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
May 06, 2010 | Sony Bravia KDL-46VL130 TV
I cannot get a video signal from my sony blue ray--the tv acknowledges the HDMI hookup to the tv but no signal is going thru
first run a yellow cable to tv (AV) if does work it maybe a setting in blu-ray or TV look for any settings in the TV and blu-ray menu that says HDMI communications or something like that and turn it off. try to connect HDMI cable again.
Jan 12, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I can't Tune my V32XBR1 in Australia
Greetings...
Are you connecting to a digital signal from a cable box using an HDMI cable?
Ed
Apr 03, 2008 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony bravia lcd tv-
If you are using a HD cable box or satelite with component outputs, be sure that all 3 cables ( green, red, and blue ) are making good connection.A loss of red or blue will cause color shift. Usually,if the tv menu comes up as the correct color but the picture dose'nt, it is most likely a signal problem.
Jul 01, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL-46VL130 TV Logo
80 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
