Question about Dell PowerEdge 1800 Server
HARD DISK NOT DETECTED - Dell PowerEdge 1800 Server
Hola yotengo el mismo error
cuando lo reinicie y quiso arrancar el sistema
me marco este error
porfa una solucion no estoy segura de ke sea el disco pero help!!!
please
init:ureadahead main process (266) termitate with status 5
Posted on Feb 11, 2011
My Computer use windows XP Operation System. hp 540 laptop when I turn on windows, it show black screen with cursor. It cannot continue log to windows. I check in bios cannot detect hard disk. How to solve...
Open your laptop and and fix the hard disk cable.After this start laptop and check the bios if HDD detected then select boot device and select first boot device is Hard disk.Save the setting and restart the window.You are able to open your window. But If Hard disk drive is not detected change data cable,power cable of Hard disk.If hard disk is detected in bios follow upper rules. And if it is not detected again you should walk into Hard disk repairing center and check hard disk there.
Jun 07, 2011 | Computers & Internet
When my laptop boots up it says operating system not found
Not good. Check your bios for correct drive for boot up, but it sounds like yoru hard drive is not being read....
Oct 26, 2010 | Acer (ACERMOTHERBOARD)
Not detecting hard disk
first thing to do is to remove and reconnect the hard disk to the system. devices like hard disk not detected often is just a result of loose connections. if this will not work, may be a good idea to test another hard disk with your computer or test the hard disk on another computer to isolate if the hard disk will need to be replaced.
Sep 04, 2010 | Computers & Internet
A disk read error occured and keep on re-start
Please check that the hard disk is connected properly. If you know that the hard disk is working, check whether it is detected or not. If it's not detected, you'll need to recheck it again with the power supply. If possible, try it to another Laptop so that you can make sure that Hdd isn't the culprit. In case it's detected and the problem still persists, repair the operating system installation, this will definitely solve your problem. Good luck.
May 26, 2010 | Dell Latitude D600 Notebook
My dell latitude says no bootabble devices and no drive what should I do to fix this
Dear sir...
3.remove the battery first,then press the on/off button 20 seconds.then replace the battery.
--------------------------------------------------------------- Check the hard disk is detected in the BIOS(follow the below steps)
1.on the laptop,immediately press Del. (F2 or Del or F10 these are common to display the BIOS setting)
2.Check the menus one by one whether the hard disk is detected or Not detected.
if the hard disk is not detected then remove the battery,remove and replace the hard disk .(See the laptop manual) -------------------------------------------------------------------------
if the hard disk is detected then set the BIOS with Basic Default configuration.
press F10 Press Y Press "Enter"
All the Best sir... Thank you........
May 16, 2010 | Dell Latitude C510 Notebook
Hardrive not detected
You may have a hardware fault.
Try re-seating the hard drive.
Then check the BIOS to see if the hard disk is detected.
If the hard disk is not detected then either the hard disk is faulty or the disk controller on the motherboard is faulty.
To further test the hard disk, remove the hard disk and connect it to an USB hard disk adapter and plug it into a working computer's USB port. If this computer cannot see it as an external hard drive nor can you open the various folders and files, then the hard drive is faulty.
Then you need to replace the faulty hard drive, install Windows on the new hard drive, together with the laptop's device drivers and your programs to get a working laptop again.
Feb 25, 2010 | Asrock 775i65G Motherboard
Boot missing
Go to CMOS and see the Hard Disk is detected or not. If it has been detected, reinstall the operatin system using recovery option. If the hard disk is not detected, replace a new hard disk.
Jan 18, 2010 | Lenovo IdeaPad S10e Netbook
Hard disk not detected in bios
yes get another pc that has a hardisk. then make your disk slave and install it on that pc. you'll recover your data
Jul 18, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Won't boot off of the external drive
when u power on your system start tapping F2 key
you wil get system setup screen
it will be somthing like this
Boot Sequence The computer attempts to boot from the sequence of devices specified in this list.
Default Setting:
  • Onboard or USB floppy drive
  • Onboard SATA hard disk drive
  • Onboard IDE hard disk drive
  • Any add-in hard disk drives that are detected (listed in the order that they are detected with USB device usually being detected last)
  • Onboard or USB CD-ROM drive
  • Any other bootable add-in devices that are detected (listed in the order that they are detected with Onboard Network Controller usually being detected first)
Apr 12, 2008 | Dell Latitude X200 Notebook
Ibm hard disk not detected
do u want to install the hard disk or do u want to setup raid? getting the hard drive to be detected has nothing to do with setting up RAID.
Dec 24, 2007 | ASUS Intel 440BX Chipset CUBX-L...
Dell PowerEdge 1800 Server Logo
175 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
