Question about Nakamichi SoundSpace 5 Shelf System
1 of the loudspeakers has no ability to reproduce low sounds without giving a distorting flabbering sound when given a bit of volume. Appeared 1st. time after the family mooved premises.
  • 70 Answers
Speaker is damaged, take front grill off to check for damage to cone. Would probably need new speaker.
Posted on Jan 02, 2011
Speakers have a crackle in the sound also rear speakers not working
can mean several things. The crackle is subjective and can mean distortion. Distortion most of the time comes out of the amplifier. Could be you have blown a capacitor in the power supply of the amplifier, making it work with quasi half the voltage. There is no need to change the polarity on a speaker, because when one is not working infuse, it won't distort the music. You only could have difficulty with the stereo sound. It could be a bit unclear where the sound is coming from and could sound a little less powerful.Check the speakers on a different amplifier, to hear if I'm right. Only if you switched on sound while the amp was giving full power, you could have blown the speakers, but most of the time they don't give any noise after that.
Jan 16, 2015 | Ranger Communications 1998 1999 2000 Ford...
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
Low output with high volume
sounds like distortion is being caused by trying to amplify a low volume level from the input device. try putting the ipod volume at a medium level and try again to see if the distortion goes away/reduced
Dec 23, 2013 | Pioneer Avic-940bt Car Navigation Cd/dvd...
I have the tascam 144 interface With a perception 120 mic, And at 1st everything sounded Great bit the last couple of tracks I recorded sounds really distorted It sounds like I'm singing thru a...
I'm no expert in sound cards but I know some stuff about music recording, when sound is distorted you can see the wave you recorded as a flat in both top and bottom parts of the wave, this happens when the inpu to mic or "mic volume level" is too high, try decreasing the volume level of your mic via recording software or use the small speaker icon in the lower right part of windows taskbar to get to the windows default sound card's properties, get to the mic lever and lower it at will to get the desired volume level you need.
See if this solves your problem, if not don't hesitate to reply with some more info to see if I can help.
May 13, 2011 | Tascam US-144 Sound Card
What's the output of the speaker system in watts ?
Hello
Audio power is the electrical power transferred from an audio amplifier to a loudspeaker, measured in watts. The electrical power delivered to the loudspeaker and its sensitivity determines the sound power level generated (with the rest being converted to heat).
Amplifiers are limited in the electrical energy they can amplify, loudspeakers are limited in the electrical energy they can convert to sound energy without distorting the audio signal or destroying themselves. These power ratings are important to consumers finding compatible products and comparing competitors
Do rate, if got help
Dec 04, 2010 | Logitech Z523 2 Speakers
My peavey 218 subs are crarking or sound dissorted.How can I check them out
Hello Sir, Hi, distorted sound can be caused by several factors, one would be that the source, overdrives the power amps. You need to lessen the signal, if the source has a volume control set it to half. Another is the power amp itself is defective, The likely culprit it the Integrated power amp. this should be checked by a technician. and lastly the loudspeakers, to test just simply swap the other channel driver unit to the questionable one. check If the sound returns to normal. Several factors also are low voltage supply, leaking capacitors. there are no user serviceable parts here.
Aug 13, 2010 | Peavey 1808-4 SPS BW Car Speaker
Dropped Tea in E63 loudspeaker not working...Kindly Help
I think your mobile ringer no working it need to be clean. So if you have any Mobile repair worker to near your home go to over there & tell him to make it clean but carefully then check your mob. ringer.
I hope than it will work very fine as working before...
Jan 25, 2010 | Nokia E63 Cell Phone
Volume
Volume control
• When you have an active call or are listening to a sound, press o) or (o to
increase or decrease the volume level, respectively.
Voice volume icons:
- for earpiece mode,
- for loudspeaker mode.
Loudspeaker
Your phone has a loudspeaker for handsfree use. The loudspeaker allows you to
speak and listen to the phone from a short distance without having to hold the
phone to your ear, for example, having it on a table nearby. The loudspeaker can
be used during a call, with sound and video applications, and when viewing
multimedia messages. Sound and video applications use the loudspeaker by
default. Using the loudspeaker makes it easier to use other applications while in a
call.
Apr 02, 2008 | Nokia 6600
Problem with amp?
Give that new sub a chance to "break in". New speakers require a few hours of use before the voice coil(s) and spider break in and began operating at their best performance. Is the box within the operating specs of the sub? Is this a ported box; if so you will here some turbulance type noise from the port. What type of distortion are you hearing? Alternator noise(dentist drill like sound) would only be noticable through a sub at lower volumes due to the frequency response of a sub. Is the amps lowpass crossover turned on?
Mar 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony erricson speaker problem k750i
turn of your auto volume in the settings.
Jul 26, 2007 | Sony Ericsson K750
Nakamichi SoundSpace 5 Shelf System Logo
123 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
ELECTRICLAW
Level 1 Expert
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
