Question about Wolf Range fs-0-27-ft36 Gas Kitchen Range
Wolf model AS36KI-7. Oven ignition misalignment and flame buring outside of oven area. Stove was converted to LPG when new. I had the recall kit installed part #801653 several years ago. The repair lasted over seven years. Now the oven flame will still burn outside of the confined area once every ten times when we lite the oven. We have a tile floor in the kitchen. I contacted Wolf, no help. Thank you. Joe Lallande 989-356-9816.
3 Suggested Answers
SOURCE: Wolf Model R364G has a delayed ignition in the oven
yes it will applie to to second owner.
Posted on Dec 06, 2008
SOURCE: Wolf oven won't light after only 3 years since last repair.
You could try a new thermocouple and/or cleaning the pilot assembly. The thermocouple is the tube that screws into the pilot safety valve and runs to the actual pilot and is heated by the pilot flame. If you change this part be sure not to over tighten the thermocouple into the safety valve as it can break. You should go finger tight plus a quarter turn. Also you should check to see if the pilot is solid, not weak. Thermocouples can be purchased from your local equipment service company, sometimes Home Depot has them for water heaters, be sure you get on with proper length. Hope this helps.
Posted on Apr 30, 2009
Kenmore model 66575775890 oven. broiler and bake burners don't work. the igniters do work, they both glow VERY bright and hot
Hello Malibro,
You converted it to LPG. Did you also convert the oven nozzles?.
Because they need to be converted too.
Kind regards, Dik
Mar 27, 2018 | Kenmore Kitchen Ranges
OVEN FLAME TOO HIGH ON A A GE CONVERTED TO LP
You should have a pressure regulator between your stove and your propane bottle. It's probably delivering too much propane at too high of a pressure to the stove.. If you don't have a regulator, THAT would be your problem. A regulator set to too high a pressure makes flame too high and flame may even try to blow itself out. I've remedied this by taking a small cover off the center of the regulator and adjusting a screw.. (Not all regulators can be adjusted.) If adjusting isn't possible, I'd suggest a new pressure regulator (for LPG). Note: A regulator for LPG is NOT set up the same as a regulator for natural gas.
Oct 28, 2013 | GE Profile JGSP44 Dual Fuel (Electric and...
Having just converted my Vulcan Endurance G36L Range from Nat. Gas to LPG Using the following parts recommended by Vulcan : New 1/2 psi pressure regulator, 6 size 51 hood type top burner orifices,1 size...
The oven safety valve has to be cranked down for propane.themobilian_815.jpg
Get a good fitting wrench and tighten this spud down and open the air shutter on the burner.
This video shows how to tackle a crank down and flip type LP conversion whilst yours might be a bit more fancy it still must be adjusted like any other stove:
Jan 10, 2011 | Vulcan G36L Gas Range
Wolf 4 burner stove developed a non stop ignitor clicking
If you have Wolf model AS30KI, most cases the top burners are misaligned or one of the electrode is bad.
Aug 31, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Igniter on Wolf Stove clicks continuosly
Depends what Wolf model you have, if you have model AS48KI and the flame looks really high, (it supposed look like a flower), most cases the top burners are misaligned, you can try to re align the burners by turning them around. afterward if the burners are still clicking it may be ignition problem. Have fun.
Aug 14, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Natural gas to LPG conversion kit for old new world gas stove
Silver solder up all burner jets and redrill to .6 mm then reset adjusters so you get a nice blue flame with small orange tips.and oven burner to .8mm i have just done a new world 75 last week.Works perfect
Apr 14, 2009 | Ovens
Oven gas turns off
If your Wolf has pilot light, most cases dirty pilot light (flame looks yellow, normal flame looks blue), you have to disassemble the pilot light to clean it, thermocouple connection is loose, bad thermocouple or bad oven safety valve. you can try change the thermocouple first, if it did not solve the problem, then it will be bad oven safety valve. You can buy thermocouple thru Hardware store. Have fun.
Dec 17, 2008 | Wolf Range CHR-10-229-FT11 Kitchen Range
Wolf oven - oven clicks continuously
This sounds like you have a flame switch getting ready to go out. The reason you are hearing the ticking noise is that after the ignition is satisfied the flame switch is not detecting and sending a signal to continue to try for ignition.
Nov 02, 2008 | Ovens
Low flame
so you stove was converted from natural gas to LP using WB28K10043 KIT-CONVERSION L.P. ? is this correct?
Aug 23, 2007 | Hotpoint RGB745 Gas Kitchen Range
Wolf Range fs-0-27-ft36 Gas Kitchen Range Logo
513 people viewed this question
Top Wolf Range Kitchen Ranges Experts
Ismael Rodriguez...
John Rodgers
John Rodgers
Dan Webster
Dan Webster
Are you a Wolf Range Kitchen Range Expert? Answer questions, earn points and help others
