Question about Epson Stylus Photo R300 InkJet Printer
In the maintenance section Inkjet Cartridge Repacement does not work. The cartridge does not move into position to be replaced.
    Genius:
  • 1,447 Answers
Hi!
Does it make a grinding noise when you change the button to replace the ink? As if it is trying to move the cartridge holder to a position where you can replace the ink?
If the cartridge holder has like a lock to keep the ink cartridges in place, try to use a flat object that you may insert to push it down.
One or two things- you may have not close that ink latch properly so it won't move, or the mechanism for printer is damaged.
Thanks for your time and using Fixya Online Support. Cheers!
Posted on Jan 02, 2011
How to Replace catridge epson stylus c43sx
Are any of the cartridges empty or not? Always replace the cartridges with the printer on.
If you do not have any low ink alerts, you need to enter the maintenance mode. Press the Maintenance button (has both an ink drop and a paper symbol) and the Power button at the same time. Then open the black printer cover (lift up).
If any cartridges are low or out, just lift up the printer cover. Then press the maintenance button. The cartridge carrier will move the empty cartridge to the replacement position. (If both cartridges are out or you are using the Maintenance mode, the cartridge carrier will move the black cartridge to the replacement position.) Lift up the cartridge clamp (at the back of the carrier for current cartridge to replace; it will rotate towards you.). Then lift the cartridge up; dispose of the empty cartridge. Unwrap your new cartridge and remove the yellow tape (do not touch the IC chip or remove the other tape from the cartridge). Push the new cartridge straight down into the carrier.
Close the cartridge clamp and press the maintenance button to move the color cartridge to the replacement position. Repeat the cartridge replacement steps above for that cartridge. Close the printer cover. Then press the Maintenance button again and wait while the printer charges the ink system.
For pictures to go with the steps, see http://support2.epson.net/manuals/english/ij/stylusc43/REF_G/INK_1.HTM .
I hope this helps.
Sep 11, 2012 | Epson Stylus C43SX InkJet Printer
How to remove the ink cartridges?
r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing. r_2.gif Open the printer cover. r_3.gif Press the fontb1.gif maintenance button. The print head moves to the black or color ink cartridge replacement position, the fontp.gif power light begins to flash, and the fontb1.gif error light begins to flash or remains on. When both cartridges are out of ink, the print head moves to the black ink cartridge replacement position first. After replacing the black cartridge, press the fontb1.gif maintenance button again to switch to the color cartridge replacement position. 98a04.gif r_4.gif Lift up the ink cartridge clamp as far as it will go. The cartridge rises partly out of the cartridge holder. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it. 98a05.gif r_5.gif Remove the new ink cartridge from its protective bag. Next, remove only the yellow tape seal from the cartridge. Do not touch the green IC chip on the side of the cartridge. 98a06.gif r_6.gif Place the ink cartridge into the ink cartridge holder, and then close the ink cartridge clamps. Do not apply excessive force to the cartridge. 98a07.gif r_7.gif Close the printer cover. r_8.gif Press the fontb1.gif maintenance button. The printer moves the print head and begins charging the ink delivery system. This process takes about thirty seconds to complete. When the ink charging process is finished, the printer returns the print head to its home position, the fontp.gif power light stops flashing and remains on, and the fontb1.gif error light goes out. 98a08.gif If you feel that my answer helped you then please give a vote for my answer.
Apr 04, 2011 | Epson Stylus C43UX InkJet Printer
Have an epson stylus nx110 printer and have to replace ink cartridge. the cartridge holder will not go into place so that i have access
Find the NX110 in the printers section of the control panel. Then right click your printer and choose "Printing Preferences" then the "Maintenance" tab. In there you will see a button for 'Replace ink cartrige'. Select that and it will take you through it step by step and even move the print heads to the correct position so you can change the ink.
Mar 13, 2010 | Epson Stylus NX400 InkJet Printer
The cartradge block is blocked at the right handside most likely due to a faulty cartridge. How can I manually move the block to the left and get the cartridge out??
For a forced cartridge change it will either be a quick press of the ink button or by holding the paper feed button for 10 seconds. Or there may be a an Ink cartridge replacement option the Printing Preferences > Maintenance section of the driver.
Jan 19, 2010 | Epson Stylus Photo R2400 InkJet Printer
How do i get the cartridge out
Oct 20, 2009 | Epson Stylus C40UX InkJet Printer
"Print carrier stall"?
Error 0502-Carrier Stall indicates a physically blocked carrier. This condition can occur for many possible reasons. Most often, the carrier is blocked because the ink cartridge lids are open while the printer is on (Figure 1).
Figure 1: Open Ink Cartridge Lids
Reseat the Ink Cartridges and Make Sure the Lids Are in Place
  1. Make sure the printer is turned on.
  2. Lift the printer's front cover.
    new_note.jpg Note: The ink cartridge should be in the up/loading position unless the printer is busy.
  1. Squeeze the tabs on the cartridge lids and lift the cartridge lids up. The cartridge pops up when the lid is fully lifted.
  2. Remove the cartridges.
  3. Make sure that all of the protective tape has been removed from the contacts on the ink cartridge.
  4. Replace the cartridges.
  5. Snap the lids closed.
  6. Close the printer's front cover.
  7. When prompted on the printer's LCD to choose New or Old, choose Old.
  8. Press Select.
new_note.jpg Note: For more information about reseating ink cartridges, refer to the Maintenance or Ink Cartridge Maintenance section in the Online User's Guide.
Back to Top
» Reposition the Encoder Strip
  1. Remove the power cord from the printer.
  2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
  3. Gently slide the ink cartridge carrier to the middle of the printer.
  4. Gently move the top part of the printer belt to the right.
  5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    Figure 1: Inkjet Printer Encoder Strip
  6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
  7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
  8. Once the encoder strip has been re-seated, close the scanner lid.
  9. Re-connect the power cord to the printer.
Jul 18, 2009 | Dell 922 All-In-One InkJet Printer
Dell Printer A940 Hardware error
Back to Top
» Reseat the Ink Cartridges and Make Sure the Lids Are in Place
  8. Press Select.
Back to Top
Jul 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Printer 964
  8. Press Select.
Back to Top
If this information has not solved your issue, then you have to contact Dell. They may need to replace the printer.
Jul 02, 2009 | Dell Photo 964 All-In-One InkJet Printer
How do I make the cartridge move to change position on Epson C44 Plus
To replace an ink cartridge using the maintenance button, follow these steps. Turn the printer on, the power light should be on and not flashing.
Open the printer cover. Press the maintenance button (ink-drop symbol). The print head moves to the black ink cartridge replacement position first. Press the maintenance button again to switch to the color cartridge replacement position.
The on-line user guide can be found here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=FGQ8MBMpKlvPPGPcU002FJ8CcV1DwZfroADi&tc=5
Please take a moment to rate this solution, thanks.
Apr 17, 2009 | Office Equipment & Supplies
Epson Stylus Photo R300 InkJet Printer Logo
75 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
