Question about Kenmore 24032\24036 Top Load Washer
Good advice, but to my surprise, part not broken
Comment by mercfoto, posted on Jul 09, 2008Ok, got through it easy, but here's the thing....the plastic part isn't broken :( But the bolts were not real tight on the transmission. Would that cause the problem? After inspection, coupling looks good too and transmision seems to be turning properly, drive shaft too.
  • mercfoto Jul 15, 2008
    Hi Mike,
    So, mysterously enough, the drum did start working but only after I cleaned out some debris around the top underneith the plastic collar and then physically turned the drum a few times. Whatever that did, seems to have done the trick. Functions great now, but it also has a new life :) Thanks for the advice, repair went really well.
    Ryan
  • 481 Answers
  • if the bolts in the transmission are too loose, then the plastic piece may not disengage the break (rare).
  •  can you turn the plastic piece  and spin the tub? you should be able to do it with your hand, turn it (i think counter clock wise) and you will feel the break disengage and the tub should spin freely.
  • check that plastic piece good because its just a small tabs that breaks off usually.
Posted on Jul 09, 2008
  • Mike Durland
    Mike Durland Jul 09, 2008
    sorry, misspelled word: disengage the BRAKE, not break.
  • Mike Durland
    Mike Durland Jul 11, 2008
    • haven't heard from you, so i guess you got it figured it out.
    Mike
Why won't rear door open?
How to Open Trunk with No Battery. - Bimmerpost
www.e90post.com/forums/showthread.php?t=690147
May 11, 2012 - 22 posts - ‎16 authors If you're reading this, you are probably stuck like I was stuck - hopefully .... I'm actually surprised BMW made this possible - seems like a real ... Does this also apply to the 3 series Wagon (E91 a.k.a Touring)? Mine is a 2005 and there is no key lock in thetailgate. ... Drives: 2006 E91 325xi 6 speed wagon. Trunk won't open???
Jul 31, 2008
Trunk opening by itself - Page 2
Dec 28, 2006
More results from www.e90post.com
Sep 30, 2015 | 2005 BMW 325xi Wagon
86 Dodge W150 5.9L problems(2)
i have a '86 dodge ram w/318 - got it for free , only running on 4 out of 8. rebuilt carb (holley 2280 2 barrel ) still has no power but sounds like it's hitting on all 8. found on web a "power heat valve"between the passenger side exhaust manifold and the down pipe. it's in the haynes manual page 4a-22 illustration16.1 - i can't imagine what it should do when it's working (why choke off half your exhaust-ever) but i am going to check that out.have to get by a lot of rust first. good luck!
Jul 30, 2008 | 1986 Dodge W150
NOT A WASHING MACHINE PROBLEM!! Still can't get past Step 3!
Did you read the solution fully?
So you would need vista drivers for the device? I suppose the cd doesn't have vista drivers. Il see if they are available.
Comment by Ekse, posted on Jul 27, 2008 windows vista drivers are here
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlf/000000/003200/dlf003219.html?reg=us&c=us&lang=en&prod=hl2170w_all&type2=1&os=74&flang=4&dlid=dlf003219
If link broken click here Comment by Ekse, posted on Jul 27, 2008 These are the driver files only, no setup program.
To install these drivers you need todo it manually.
Connect the printer.
Right click on my computer or computer, and select manage.
On the computer management window, select device manager from the left side.
On the right side, find your printer and right click update driver.
No, do not look online -> Next
Install from a list or specific location (advanced) -> Next
Don't search. I will choose the driver to install -> next
Show all devices -> next
Have disk ->
Go to the folder where you extracted the files and click ok.
Choose the correct driver. next , install ,finish.
Comment by Ekse, posted on Jul 27, 2008 here is the full driver & software package for vista this one should be easyer to install http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlf/000000/003100/dlf003193.html?reg=us&c=us&lang=en&prod=hl2170w_all&type2=1&os=74&flang=4&dlid=dlf003193
Jul 27, 2008 | Washing Machines
Not printing 9
Instructions please for brother AX-25 typewriter electric
Jul 13, 2008 | Office Equipment & Supplies
Quark for mac
Just downsave the document and it would take care of the issue as well
Jul 13, 2008 | QuarkXPress 4.1 for mac
Refrig and freezer won't cool
if it is not cooling at all then i would suspect the compressor is not running. this could be caused by the start switch on the side of the compressor not working. as a first step i would take off the start switch and inspect it. sometimes you can tell just by looking at that it is bad (melted plastic or burn marks or pieces rattling inside). let me know the results so we can go to the next step if needed.
Jul 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Sony Ericsson V580i
okay so you continued the wotan, did you get pass the update after installing the client?
Jul 08, 2008 | Cell Phones
Did you get a chance to
Yes, I have tried plugging it into the charger with and without the battery and no it does not turn on. If the advice of this website is to take it to a repair shop then I am extremely disappointed in this service (I have never used it before). It is obviously not under warranty or I wouldn't be looking for a site to help me with repairs. I have contacted Sony and AT&T who is unable to help me with the problem. Sony will repair it for $185 which is ridiculous. If the solution I am receiving from this site is to take it to a repair center then I do want to use the money back guarantee.
Trouble playing the songs
Convert the songs to mp3 format, and you will never have this problem again.
Jun 03, 2008 | iLO (2 GB) MP3 Player
Kenmore 24032\24036 Top Load Washer Logo
24 people viewed this question
Sal De
fordexpert
Robert Rankin
