When I connect to the DVD player with a scart connection at the back of the DVD player and the S-Video input on the projector I only get an hour glass symbol on the screen and this gets locked in. Is there some further settings I have to change so that it plays the analog signal from the DVD player?
    Brigadier General:
  • 8,909 Answers
Is the DVD player producing S Video? If not the projector will not work.
Has the projector got a composite video input? if it has try that instead from the DVD player.
Hope that helps.
Posted on Jan 02, 2011
I am trying to copy VHS to DVD [using quality DVD-RW] but keep getting screen message of NO SIGNAL - Please check connections.
Hi try this set up to check if you're scart set up isn't the problem connect 3 rca lead to the output of the vcr into the input of video recorder then plug 3 more leads from output of video recorder into the TV set you're TV to AV INPUT AND set YOURE VIDEO RECORDER TO THE CORRECT INPUT MODE ...good luck
Aug 03, 2015 | Televison & Video
How do I connect a dvd player to tv with no scart connection
Make and model of TV would help.
Very odd TV with no SCART and only a single HDMI. You sure it's not a computer monitor? happy.gif
If the TV really does not have any sort of analogue input you will either need to buy a disk player with HDMI or an analogue to digital converter (the former may well be cheaper!), And if there is only a single HDMI you can but switches to expand the number of HDMI inputs if necessary.
User manual here
http://documents.knowhow.com/TV-Home...nal_120524.pdf
Refer to page 15 which states:
"Use a included SCART adapter cable to connect
between the TV's SCART input socket and a SCART
cable to an external AV device's SCART output socket."
Dec 12, 2014 | Televison & Video
I bought a freeview box, My tv has only one scart socket. how do i connect my dvd player to combine with this?
You need a video switch box, that has two video and audio inputs and a video and audio output that connects to the video and audio connections on the scart cable.
Then you can switch between the DVD player or the freeview box.
These devices are available on the Internet, use Google to search for these devices.
Dec 17, 2011 | Televison & Video
Can I connect my Toshiba dvd-player sd-770sr to a laptop and then make my laptop screen seen on my older tv that is connected with scart to the dvd player?
you can connect you dvd player to your laptop but you need a usb tuner that will accept video and audio input such as products made from razzle as i never heard of a laptop that has an input and scart has an issue connecting dvd/vcr's to tvs because of synchronizing the composite video signal (which is companded into red, green, and blue) from the VCR with the RGB signals needed by the monitor.
Hope that helps answer your problem let me know
Mar 17, 2011 | Toshiba SD770
What cable do i need to connect philips dvp3520/05 to hd tv
The DVD player only has a SCART out and unless you have an European model TV it won't have a SCART input. So you have to buy a SCART to RCA cable and connect the RCA end to the TV's AV input ( Yellow to Video and Red/White to audio input )
Mar 17, 2011 | Philips DVDR3380/05 DVD Recorder
TH-37PE30 - DVD picture now lousy (herringbone?)
Do you have an S Video cable connection on the DVD player? I'd try that If you have one or component (red green blue) cable or even the composite (yellow) connection. The SCART connection on the input PCB of the tv could be damaged. The cost of this board may be pricey so if you can use the other type of connections with the DVD player I'd recommend that or get a DVD player that has one of those. Your model does not have HDMI so those are your only other options. Hope this helped
Feb 08, 2010 | Panasonic TH-37PE30 37 in. Plasma...
Connecting the dvd player via a scart cable
If you select component in on the tv, this should give you a picture,using the current set up. As for audio, depending on the tv, have you used audio in on the tv, or audio out?
It sound obvious but I (even after 5 years+ of installing tv/vcr/dvd) still get caught out with input and out put.
I am unfamiliar with Sansui dvd, if it has a scart connection on the back then yes you can connect to a spare scart on the tv. If it has the single yellow phono for video and the red/white phonos for sound, you can buy a scart to phono lead and use that, not to confuse with the component(blue/green/purple) connections. You cuold also connect the yellow/red/white phono to the same on the tv front/side or rear if available.
Aug 27, 2009 | Televison & Video
How to connect 1 dvd player to copy to 1-dvd -r player
Hello..just try to connect video out from player plus the 2 audio connectors to your recorder video and audio inputs..maybe you must use scart in on your recorder if you have it..than you will need a video copying cable kit...scart -scart if possible is the best...and your recorder must be in "aux" or "video in" mode...please tell me how it went...good luck...Ron
Mar 08, 2008 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
