Question about Indesit W 123 Front Load Washer
The bearing has gone, how hard is it to fix??
    Genius:
  • Indesit Master
  • 1,460 Answers
If you mean the Drum bearings its quite a big job parts around £75 for full kit depending on the model.If more than 5 years old perhaps think new machine........
Posted on Jan 02, 2011
Pedal crank bearing have gone bad is this hard to replace
Not very hard, but you might need special tools. Park tools has excellent tools and good pictures that can be helpful. There are a couple of varieties of how these bearings go together. The old standard style is pretty simple, but you have to fiddle a bit to get the locknut good and tight while keeping the bearing just snug enough to move freely but have very little play. The fancier ones use a sealed bearing which doesn't have to be adjusted.
Aug 17, 2010 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Kenmore oasis washer noisy when spinning
Hi, your probably right about the bearing its usually hard to tell untill they have compltely gone have you tried turning the drum by hand to see if it turns smoothly if it does then it could be the motor thats noisy both can be replaced but the drum bearing is a nighmare trust me you need pullers and its hard work.
So try turning the drum by hand and see if you can feel any roughness or catching this would tell you if the drum bearing has gone.
Let me know the outcome ok
May 01, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
The abs starts without steppin on the brake pedal Hard
One of the speed sensors are bad. They do this when the air gap is too large. You will need a scanner to find out which one. But there are some ways you can figure it out without a scanner. It is usually a front sensor. Check the front bearings for play. Usually the one with play in it is the bad one. If non have play or noise coming from them. Just replace one, then drive it. If the problem is gone, good. If it isn't gone. Take the bearing you just took off and bolt it to the other side. Then it should be fixed.
Jul 31, 2010 | 1999 GMC Jimmy
The bearings of my Dyson are gone. Are they
can it be fixed? yes.is it easy? no not by a long shot.there are two bearings in the drum one you will never get to needs factory tools to take apart. the other is the main steel bearing the drum spins on.now it is possable to get a patten mached bearing from a bearing supplyers but...this is just the bearing not the water seal and 9 out of 10 times its the water seal that go's and washes the greese out of the bearing and the bearing starts to rust and then grinds itself away and collapes!so it may fix it for a while 3-6 months at a push.plus the bearing is pushed into the drum on a large press like a car wheel bearing.i had to use a 50 ton press to fit my bearing back in! and as to getting the old one out well thats another story.lol alot of people don't have the time or skill to do this so they end up as scrap or on ebay.now i paid alot of money and fitted a stainless steel bearing into mine and its not had a problem in 10 months so if you do give it a go to replace the bearing thats the best way to go.
Jan 26, 2010 | Dyson Flowcheck CRO1 Front Load Washer
I have a 51 reg golf tdi gt and just had both wheel bearings and cv bearing renewed now mpg has gone down by about 15 mpg is this related
They have tightened the wheel bearings down too hard causing the car to react as if you were driving with the footbrake on
Jan 24, 2010 | 2001 Volkswagen Golf
ABS light is on, have replaced the sensor in rear end
IF YOU HAVE FOUR WHEEL ANTI-LOCK BRAKES YOU MITE HAVE I FRONT WHEEL SPEED SENSER GONE BAD OR A POSSIABLE WHEEL BEARING GONE BAD (BECAUSE ON SOME FORD TRUCKS THE WHEEL SPEED SENSER READS OFF THE WHEEL BEARING.
Oct 01, 2009 | 2005 Ford F 350 Super Duty
Removing bearing
Sometimes heating the outer ring of the bearing with a propane torch helps to resolve this problem.
Aug 06, 2009 | Garden
Bearings have gone
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Jun 02, 2009 | Hotpoint First Edition WMA12 Front Load...
2001 pt cruiser, right rear, sounds like a chirping noise
sounds like the bearing in the hub assembly has gone bad
May 20, 2009 | 2001 Chrysler PT Cruiser
ABS light came on, and is now shifting hard
need brakes probley to low and locking on
Jul 18, 2008 | 2006 GMC Sierra
Indesit W 123 Front Load Washer Logo
64 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
