Question about Hitachi Televison & Video
Can i connect my hitachi television (hitachi av3000e) on my pc without the "box"?
3 Suggested Answers
SOURCE: hitachi av3000e multimeadia box
can i buy it? i need a av3000e, is it same? my number is 01189 731743
Posted on Jul 04, 2009
SOURCE: My Hitachi AV3000e Plasma tv is fine i think But
Hi. I'm having the same problem. Are there any other boxes available anywhere to replace the origional Hitachi one (AV 3000e) please contact anoteron_b@hotmail.com.
Posted on Jul 20, 2012
How do I disable Power save mode in Hitachi av3000e TV
I have read the user guide for this Plasma tv available free from here http://www.nodevice.com/download/user_manual/hitachi+42pd3000/132819.html
There is no mention of 'power save' mode whatsoever.
If you meant 'sleep mode' that is referred on page 30 of the manual.
Other than that, there doesn't appear much else you can change.
Sep 17, 2014 | Televison & Video
Remote for av3000e
Codes to check with Hitachi TVs are 0382,0762,0825,0624. These are codes to Hitachi TVs with AT&T Uverse remote control. If you wish to get more details, check these sites linked below. Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Two digit, three digit, four digit and five digit setup code list to different models remote controls are given. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window. Check the site and see some remote brands too. Check the code list provided, and see which of them have setup codes to your TV, and bu that one according to availability.
http://electrohelponline.blogspot.com/
Apr 25, 2013 | Hitachi Televison & Video
Hello, I wanted to change the place of my TV. I am not sure if I plugged it correctly. I've got no power with hitachi flat screen spu42pt3. No green light. it is a flashing yellow light. I've...
If the tv was on when you unhooked it there is a cooling fan that didn't get to cool off the picture box and it has overheated and you will have to replace the box you can order it off of eBay it takes a few moments to replace it if you still have your owners manual it will tell you all about the lights on the front of your tv I've had to change mine out a few times hope this helps Merry Christmas
Dec 03, 2017 | Hitachi 42HDT79 42 in. Plasma Television
Hitachi av3000e multimeadia box
Jul 01, 2009 | Hitachi 42PD3000 42 in. Plasma Television
T V Goes on to Green Light Yet Box Stays On Red
I have an AV3000E that developed this symptom following a 5 second power cut.
I downloaded the manul, suspecting a power supply problem. The way the AV3000E works is to have a 5 volt power supply running all the time, this powers the main processor. The main processor then energises a relay (S901) by applying 5V DC between relay pins 3 and 4. The relay contacts switch rectified mains power to the main switching regulator. The replay was being energised but appeared not to be switching. While the AV3000E was connected to the mains, I carefully I connected a short between relay contacts (1 and 2) while the processor was trying to energise the relay coil. The TV burst into life. I removed the short and the TV continued to operate normally and has done so ever since. I cannot entirely rationalise why this has worked as this should not have fixed the relay, what may have happened is that the short power cut may have resulted on the some corruption of the processor non-volatile memory, and that the incorrect operation of the main relay caused the processor to reset it's internal memory.
BE WARNED, WHAT I DID WAS EXTREEMLY DANGEROUS AS THE RELAY CONTACTS I SHORTED ARE CONNECTED TO THE MAINS SUPLY - YOU ARE LIKELY TO KILL YOURSELF IF YOU DO NOT KNOW WHAT YOU ARE DOING - PLUS I TOOK THIS ROUTE AFTER ELIMINATING THE OTHER OBVIOUS PROBLEMS LIKE FAILED FUSES.
May 27, 2009 | Hitachi 42PD3000 42 in. Plasma Television
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
