Question about Canon MultiPASS MP360 All-In-One InkJet Printer
How do you change the language?
When i go to printing settings the language is not in english..... how do i change it?
  • jubernez Oct 29, 2008
    Thanks for your solution... but it still did not work
I had the same problem with my Canon Smartbase MP730. Printer properties was in Portuguese, no matter how many times the driver was uninstalled and reinstalled.
By running Filemon from SysInternals I realized that when showing the printer properties files in the
C:\BJPrinter\CNMWINDOWS\Canon MP730 Printer\LanguageModules\0409\
folder were created. One of those files was CNMmhya.hlp. When clicking on it a Help-window with Portuguese text shows up - even though the code 0409 means English. This is a symptom of the problem. This file was copied from somewhere in the Windows folder.
To fix this annoying problem, the following worked for me:
-> Unplug the printer
-> Uninstall the driver
-> Rename the following folder with the portuguese language driver stuff which still remains, even after uninstallation of the driver:
C:\WINDOWS\system32\spool\drivers\w32x86\3
(if you cannot rename it, reboot and try again). You should first check that there are indeed portuguese help-files in this folder. To do that, click on one of the .hlp files. If they are not your problem could be a different one, but it could also be that the files are stored nearby in the file system.
-> Reinstall the driver with the language of your choice. This time there won't be Portuguese files blocking proper installation of your new files.
-> Replug the printer to finish the driver installation
Now you should have finally gotten rid of the Portuguese (which may seem Spanish or Italian to some) text in Printer related windows.
Posted on Dec 07, 2008
You sir, are a damned genius. Solution 2 FINALLY fixed the problem. Thanks!
Posted on Jul 18, 2010
On installation the drivers should setup in the language of the operating system being used. I downloaded driver updates for my Canon MP 360 and found that all the language was gobble-de-gook.
I tried loads of things to get it to change back but was unsuccessful. What I did was uninstalled all the drivers for the printer then went and searched all files and folders in the system with Canon in them. These I deleted to the recycle bin, this included the backup Canon drivers. Restarted and reinstalled the printer from scratch. The drivers picked up the operating system language and bobs your uncle, everything was hunky dory again. Hope this helps.
Posted on Oct 07, 2008
How to change my camera language to english
Search Results
    How to change the mystery language 'back' - Sony's ...
    https://community.sony.com/...Cameras/...change...language...English.../...
    Aug 12, 2013 - Solved: Today I turned on my Sony camera ( I've owned for 8 months )... How to change the mystery language 'back' to English as I can't read it ...
    Re: how do i change the language back to english? - Sony's ...
    https://www.community.sony.com/...Cameras/...change...language...engli...
    May 23, 2014 - Someone has gotten into the setting on my camera and changed the settings from english to chinese. I wouldnt have a clue how to change it ...
    Re: Change language Ilce Alpha 5000 Japanese - Sony's ...
    https://community.sony.com/t5/...Cameras/Change-language.../352042
    May 19, 2014 - Since your camera is most likely a Japan model, English may not be... However, you may try to check the language setting of the camera to confirm. ....So I should learn japanese or sell my camera to someone who knows?
    Change kanji to English - Sony's Community Site
Feb 08, 2016 | Sony Cyber-shot DSC-WX50/B 16 Megapixel...
My printer language has been changed accidentally, pls help me to change it to english language. send me how to change using the control panel.
Hi vivekchat18,
The instruction below will help you put back the display language you desire for your printer. You may use the procedure below to print out reports or to show messages on the all-in-one control panel. Here's how:
1.First you need to press MENU.
2.Then, select SYSTEM SET UP.
3.Afterward, select LANGUAGE.
4.Now, choose the language that you prefer. In your case, ENGLISH.
5.You have to SAVE your settings.
6.Finally, wait until your system automatically restarts.
Hope it helps.
Thank you for using Fixya.
Mar 29, 2011 | HP LaserJet 3050 All-In-One Printer
I can not print, the error is: LANG=ENGLISH, please help
Changing the Control Panel Display Language
The default control panel display language is set for English.
Supported languages are: English, French, German, Italian,
Spanish, Finnish, Danish, Dutch, Swedish, Norwegian, Turkish,
Polish, and Portuguese. Follow these instructions to change the
display language.
1 Switch OFF the printer.
2 Press and hold Select while switching the printer ON until
SELECT LANGUAGE appears in the display.
3 After the power-on self test, LANG=ENGLISH appears. Press
[Value+/-] until the desired language appears in the display.
4 Press [Select] to save your choice. An asterisk (*)appears next
to the language to indicate it is now the default.
5 Press [Go]. The On Line indicator is lit, and display messages
are now in the language you selected.
Sep 21, 2009 | HP LaserJet 4 plus Printer
Change language Japanese to English Canon MP600 printer
when ur give the order of printing. it shows various options related to ur print on screen such as font style,paper type ...
in those u can find ur language setting.Just change it toENGLISH.
if it doesnt work then reinstall the printer setup & that time choose the ENGLISH language.
Jul 05, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Language change
You can change the language by using the control panel on the top. Go to Settings/Device Settings/ Language.
Apr 19, 2009 | Canon PIXMA MP960 All-In-One InkJet...
All the setting pages have changed language
My guess is that you have a language specific version of the driver that does not contain the English language files.
I suggest getting the latest driver version from Epson and then uninstall the old version before installing the newest.
If this still doesn't work, contact Epson...
Feb 16, 2009 | Epson Stylus Photo R1800 InkJet Printer
It prints in bad language format
It's not the printer that determines the language that is printed. It is the operating system and/or the program that is printing. Also, what you type.
In computers that run Windows operating systems it is chosen in the Control Panel. Use the Start button. Choose Control Panel then Regional and Language Options. Select your language in the pulldown menu. The entire system, including prompts, titles, etc. will now revert to that language. It will not, however, do a translation. If you have documents that were written in English they will still be English. If you want to type in English and print in French it will not happen. You must type in French to print in French...Comprenez-vous ?
A simple translator is available at http://www.reverso.net.
Nov 21, 2008 | Office Equipment & Supplies
Would like to change Language settings for Epson Stylus Photo R290 Series Printer... Currently when printing a Test and when I go to the Print Preference, its showing as a foreign language... How can...
1. First of all, you must completely uninstall your current driver (with foreign language).
2. Download Epson R290 English Language Driver from here :
http://www.epson.com.sg/epson/drivers/driver_download.htm?dc=1&mode=3&mfalse&catid=1&pid=1259
3. Unplug your printer USB Cable from your PC
4. Run : Setup.exe
5. Follow the instruction, and thats it. You've English Language now :)
I have tried this and it worked :)
Aug 28, 2008 | Office Equipment & Supplies
Change Windows XP language from Chinese to English
If the menus are all in Chinese then you will need to install an Enlgish version of Windows XP.
Mar 31, 2008 | ASUS Eee 4G Notebook
I cannot change the language setting
To return the base announce language to english press and hold the skip button for two seconds. To change the display language in the handset press the flash button, then use the CID button to sellect english, then cycle thru the rest of the menu by pushing the flash button until done. Hope this helps!
Apr 21, 2007 | GE 27995GE2 Cordless Phone
Canon MultiPASS MP360 All-In-One InkJet Printer Logo
392 people viewed this question
old marine
old marine
