Question about Whirlpool GEW9868K Electric Dryer
Dryer will not turn on. it stays on the sensor light. husband thinks it might be a sensor bulb or something i don't know.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
If the sensor light is illuminated, the motor relay on the control is likely bad or the solder connection to it is burnt. Remove the control and inspect the rear of the control board for signs of damage. The new board is available at www.aplusapplianceparts.com.
Posted on Jan 02, 2011
Solar post light sensor has power but won't stay on.
Is the bulb near the sensor. Is the bulb's heat heating up the sensor? Is there something reflecting light from the bulb back into the sensor? All these situations will make the sensor turn off the light.
Mar 19, 2016 | Cars & Trucks
I can't remember ever seeing a light inside my dryer, but my husband thinks we need a new bulb.
Hello Michelle, thank you for your inquiry!
I understand that you are unsure if your Frigidaire dryer, AEQ6000ES2, has a light inside of it. I have researched your dryer and it does have a light inside of it. The part number for the light is 131843500. Unfortunately there are not instructions on how to replace the light. We would recommend contacting a professional technician for proper repair and replacement of the light bulb. I hope this information is helpful to you. -Matt
Dec 06, 2015 | Frigidaire Dryers
Samsung model dv5451 cooling light stays on
I am assuming when you turn it on, after couple of minutes goes off.
If you are on sensor drying and have no load or too little, then clothing might not touch the sensor enough (to show it is wet), and therefore microprocessor shuts unit down "thinking" everything is dry already. Try time dry.
Alternative: defective main board, sensor, wire harness.Call for service.
Dec 22, 2014 | Samsung Dryers
Gas dyer not staying on, all the light are flashing
Does your model have sensor strips inside? Wash them with windex to remove any moisture barrier on them. They sense wetness and if they don't feel any wetness they make the control think them clothes is dry and it shuts down the dryer thinkin them clothes is dry.
Jul 09, 2012 | Frigidaire Dryers
I have a 2 year old Kenmore HE3 electric Dryer. Model 110.8708. The drum light never worked. I opened up the door and found a broken bulb. I replaced the bulb. the light stays on all the time,...
the door switch has something wrong with it,it's keeping the bulb on all the time and that's why it burnt out the first time,also you're missing the last four numbers on the model number
May 15, 2011 | Dryers
DRYER WILL NOT HEAT UP. "COOLING" LIGHT STAYS ON CONTINUOUSLY.
You dry by sensor???
Clean your sensor. The machine thinks the clothes are dry because the sensor is covered with who knows what???
Check your owner manual for the proper way to clean the sensor.
I hope this works for you
a
Sep 25, 2009 | LG DLE7177 Dryer
Gas Dryer Problem
I would change both coils anyways,they can go bad after they heat up.
Nov 02, 2008 | Whirlpool Dryers
LG Tromm DLE5977W Dryer about 1 1/2 yrs old. Running small load on normal and we heard a funny clunk noise and than the dryer shut off. When i went to look, power was still on with 20 min. left on timer....
3 screws on back of dryer to remove the top. Top slides back about 2 inches and lifts off. Dryer drum should have a thin drive belt around it. Pull on belt. If broken you will know. If loose, then it's off pulleys. Sounds like a broken belt. Check repairclinic.com or appliancepartspros.com for dyi videos on how to replace.
Mar 27, 2017 | LG Dryers
Won't start, just beeps - sounds like door switch problem others have had
The three short beeps could be part of the fault code. Check the owners manual and there are diagnostic sheets on the inside of the machine. I cannot find this fault code in my data base. What is the Model and Serial Number of your Dryer. Check the Power inside the machine at the power cord power connections. You should have 120V from both power terminals to the common terminal. There should be 240 Volts across the main power terminal. Another quest replaced the power cord. Hope to hear some good news soon.
InMrFixIt.
Aug 12, 2008 | Kenmore Elite HE4 Electric Dryer
No power to dryer
Does your Husband have a meter to check voltage? if not any good hardware store, Sears or Radioshack will sell you a meter for checking voltage at the outlet. I cant give him a lesson on electricity he has to feel comfortable with that.
I have witnessed many dryer installations where they blame the dryer and come to find out its the house wiring, oh bye the way here is my bill and you need to call an Electrician to replace this and he will bill you also. My service stops at the power cord! Make sure when your husband checks for loose wires he has the power off, if you are not sure of the correct breaker turn the main off. then he can check for all the loose wires and he wont fry himself.
I would also ask that you turn the breaker off and on several times to reset it, the dryer could still run but not heat if one side doesnt work.
Let me know if you have any further questions.
Jul 03, 2008 | GE DBSR453EBWW Electric Dryer
Whirlpool GEW9868K Electric Dryer Logo
250 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
