Can i change pal from pal50 to pal60 - Televison & Video
    Brigadier General:
  • 8,909 Answers
The TV should do that automatically as you play the video/dvd.
Posted on Jan 02, 2011
Game will not play as it requires pal50 to pal60
The region locking on the game doesn't match your console. For example, you have a USA 360 and a European version of the game. There's no fix for this, so you'll need to buy a copy of the game that is compatible with the region of your 360. Hope that makes sense...
Feb 15, 2011 | Microsoft Xbox 360 Console
How do i change it from Pal 50 to Pal 60, our power is 240 volt as i live in australia
60HZ or 50HZ will make no difference to the power supply and the TV should be able to produce good results on either. The voltage may be an issue but most powersupplies are multivoltage. (100 - 240Volt). If you have an external adapter producing the low voltage for the TV and it won't work on 240V, check out ebay for a replacemet.
Hope that helps.
Feb 13, 2011 | Televison & Video
How do we covert our panasonic TH- 42PWD7B to HD?
Replace it if you want true HD. The TV has 640 × 480 pixels (dots) in use for 16:9 or 852 × 480 dots for 4:3. This translates to 480p or SD resolution.
You can watch an HD signal with downconversion. You will also need a digital to analog converter for OTA signals since the TV doesn't have a digital tuner (ATSC in the US) It reads NTSC, PAL, PAL60, SECAM, Modified NTSC signals in the following formats: 525 (480) / 60i · 60p, 625 (575) / 50i · 50p, 750 (720) / 60p · 50p, 1125 (1080) / 60i · 50i · 24p ·25p · 30p · 24sF ···· SMPTE274M, 1250 (1080) / 50i.
I hope this helps.
Jan 11, 2011 | Panasonic Televison & Video
Chicken wafflez
change your pal setting from 50 to pal 60 go to my xbox , then system setting , thencounsel setting, then pal display setting select pal60 , confirm let me know bluchevy20042000@yahoo.com
Apr 04, 2010 | Microsoft Xbox 360 Console
My tv runs on pal50 but some games on xbox360 run on pal60 , how do i play these games on my tv
Standard definition TVs loadTOCNode(2, 'moreinformation'); If you connect your Xbox 360 console to a standard definition TV, follow these steps to set the Xbox 360 display settings to PAL 60 Hz:
  1. Turn on the Xbox 360 console.
  2. In the Xbox Dashboard, select System, and then press the A button.
  3. Select Console Settings, and then press the A button.
  4. Select Display, and then press the A button.
  5. Select PAL settings, and then press the A button.
  6. Select PAL-60, and then press the A button.
  7. When you are prompted to keep these new settings, confirm the settings, and then press the A button.
Note Some older TVs do not support PAL 60 Hz. If you do not know whether your TV supports PAL 60 Hz, contact the manufacturer of your TV or see the owner's manual.
Mar 07, 2010 | Microsoft Xbox 360 Arcade
Tv works on pal50 how can i play pal60 games
if tv only works on pal50 the simple answer is you cant play pal60 games
sorry
Mar 01, 2010 | Microsoft Xbox 360 Console
Dvd player causes the tv screen to roll when trying to play a dvd. tv works finf when the player is off
Have you ensured that the dvd player settings are set to pal and that if the disc in use is an ntsc disc that the dvd is set to ouput pal60 or pseudo pal
Dec 29, 2009 | Insignia Televison & Video
Change 360 to pal60?
once on the dashboard go to system settings,console settings,display,pal settings and change it between pal50 and pal60 hope this helps you out
Jul 18, 2009 | Microsoft Xbox 360 Console
Trying to import analogue video from VHS
I _assume_ you're feeding PAL video into the MV500i... one of the simplest ways to lose color information is to feed an NTSC (or PAL60) source to a standard PAL display.
Another possibility is that you're losing the chroma signal. I believe this camcorder has a composite (CVBS) analog input. If you're tapping off a SCART connector, make sure you use a SCART to composite cable, not SCART to Y/C (luminance/chroma). Are you using the same cabling with the camcorder as with the TV?
Jan 19, 2008 | Canon MV500i Mini DV Digital Camcorder
How to change from PAL-50 to PAL-60?!
i have a xbox 360 and a television that opperates at PAL-50
my xbox is telling me, to play a game i must operate at PAL-60.
when i change the xbox settins to PAL-60 the televison goes all fuzzy, can i fix this.
Apr 14, 2007 | NEC MultiSync LCD1550VM 15" LCD Monitor
Televison & Video Logo
Top Televison & Video Experts
