Question about Daewoo Heating & Cooling
Split unit airconditioning DSA099L. Trips and displays F6 error
  • 2,133 Answers
F-6=High discharge temp/overheating compressor.
Due to condenser block (Clean it),/less RPM of fan motor (Replace capacitor)/Noncondensable gas( Remove gas flush out system, vacuum and do gas charging..
Helpful?
Posted on Jan 02, 2011
Solution for f6 code in voltas split ac
Indoor unit fan motor is defective - good luck
Read more: Voltas saplit ac not working error c ode in display f6? - F6 error code in split voltas air conditioners :: Ask Me Fast at http://www.askmefast.com/Voltas_saplit_ac_not_working_error_c_ode_in_display_f6-qna8442437.html
Jun 05, 2016 | Heating & Cooling
Electrolux split A.C. display F6 error and trips immediately after starting the compressor.
Anti high temperature protection.
Check the outdoor coil for airflow obstructions.
Check the outdoor fan motor for correct operation.
May 23, 2016 | Electrolux Heating & Cooling
My aircondition shows f6 error code starts outdor unit for few seconds and stops. Vox asw-h12a4/qb
Hi Marija, F6 error code is....I hope this helps.................CHEERS..
1?Check whether the resistance of sensor is normal, otherwise replace it.
2?Check whether the sensor wire is short circuit or open circuit, and whether the plug is well contacted, whether there is welding off or rosin joint on the electric control board, repair it if there is any above.
3?When the 1 and 2 are both normal, then the components or integrated circuit is damaged, the electric control board should be replaced.
http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
May 08, 2016 | Heating & Cooling
F6 error code first time star unit show f6 code
good day I have a problem with my aircon its ECOAIRE aircondition with error F6
Sep 09, 2014 | Electrolux Heating & Cooling
How to start air conditioner in f6 mode
i need assistant , when i on my ac .after 1minute it shows f6 and off
Apr 17, 2012 | Heating & Cooling
My onida split ac shows F6 . What can I do?
onida 1 ton split ac F6 earror how problem retified
Mar 10, 2012 | Heating & Cooling
How to solv f6 in voltas split ac
F6 error code PCB Display voltas vertis plus.?
Jun 20, 2011 | Heating & Cooling
What is error f7 that show in my split aircondition
Code F7
Error detail Reverse phase detection circuit (p.c.board)fault. Check your neutral wire loosen or not pinned. Rectify neural connection and restart the unit.
Dec 16, 2010 | Heating & Cooling
Carrier Air Conditioning error code 5
Carrier A/C split Model # 38KCL112313GP has error code E1 What is that?
Aug 09, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
388 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
