Question about Panasonic Heating & Cooling
My Panasonic DH-3CS2M water heater is not working. ELCB didn't light up. What wrong with it?
2 Suggested Answers
  • 351 Answers
SOURCE: Machine does not start and trips the ELCB
most of the time its the element but check to see if theres any water leaks onto the motor element or pump.it could also be a worn wire touching the frame.hope this helps.
Posted on Mar 19, 2008
Water works on electric but not on gas it will light but will not keep running
It sounds like your thermal coupler needs to be replaced or maybe just cleaned. P.S. have you tried a different LP tank If its new or the person didn't pressurize the tank when filled you may not have pressure enough to keep the water heater lit.
Apr 10, 2012 | RTO Suburban Rv Water Heater Dsi Gas Valve...
Common Issues with Canon P23-DH Calculator i have a e
The same thing happened to me. Wouldn't feed paper and the printer function didn't work. The E was in the lower left of the screen. I tried the reset button on the back, but that didn't help.
I took the ink cartridge out and reseated it and that fixed the problem. It was installed incorrectly direct from the factory as my calculator was new out of the box.
Feb 17, 2012 | Canon P23-DH Calculator
Dishwasher is 'tripping' electricity to the house fuseboard as soon as water heating begins in any cycle - cannot locate thermostat to test ?
This can be due to the fact that the heaters draw up more current than required and so trips the circuit. it will be important to remove and check the heaters, check if the contactors are faulty that feed supply to the heaters. Also if the trip is a ELCB- then with some leak in the circuit , motor, heaters, the circuit will trip. Hence check the electrical, check the ground on your dishwasher. Use an external ground and check
Apr 15, 2011 | Dishwashers
My bosch wvt1260 washing machine start normally after 10 minuts Elcb will off then i switched off the program selector switch and elcb on agai selector switc on suddenly bracker off,after some times it...
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that you only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Mar 05, 2011 | Washing Machines
I HAVE AN ERROR CODE dH on my Kenmore Elite bottom
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 14, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Kenmore Elite Refrigerator error er dh
Sep 21, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
Jun 13, 2008 | Refrigerators
Mar 19, 2008 | Washing Machines
Heating & Cooling Logo
264 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
