Question about Philips 50P8341 50" Rear Projection Television
Shadow issues The picture has a shadow, right now it appears the blue color does not line up, there is a wave at the bottom of the screen and a shadow upper left corner and bottom of the screen. How can we fix this?
  • Philips Master
  • 8,617 Answers
You need to replace both convergence ICs they are both STK392-110 you can get replacement ICs at the following link with free instalation Instructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Jul 09, 2008
Tip
How to Put on Eye Shadow
Achieving Smoky Eyes.If you're looking for a way to play up your eye color, go smoky. A smoky effect makes eye color pop and creates a dramatic evening look. Read on to learn how to create a flawless smoky eye. <br /><br />Create a smooth canvas for eye makeup. First, you'll want to apply a primer to your entire face, including the eye area. Then apply a concealer to get rid of redness and dark circles. Finish off by applying a moisturizing foundation to create a flawless canvas. <br /><br />Apply eyeliner. Use a black liner and draw a line across the upper lash line. When you get to the middle of the eye, make the line a little bit thicker. Choose a lighter-colored eyeliner and line the bottom of your eye. Smudge the liner with your finger to create a smoky appearance. <br /><br />Apply two colors of eye shadow. In order to select the right products, check out eye shadow reviews. You'll want a color palette that has both a light and a dark color, such as L'Oreal Paris HiP Concentrated Shadow Duo. Use the lighter color as a base and blend the color all over your upper lid. Then, apply the dark eye shadow, starting at the lash line and blending upward.
on Nov 22, 2010 | Health & Beauty
I just replaced the color wheel on my samsung hln5065w. Picture is great but there is a shadow on the right side of screen from top to bottom. The shadow on the top of the screen is wider across the screen...
Its a Good Possibilty that its the New Color Wheel causing this,if the colors are not complete on the color wheel then that will be why you are seeing shadow on right hand side of screen.
I know I ordered color wheel for mine and had to send it back,it did the same thing.
I compared it to the old color wheel and the new one did not have Solid colors on it.
Can you see picture behind the shadow? or is it shadow and no picture?
Mar 06, 2011 | Samsung HLN5065W 50" Rear Projection...
There is a blue shadow (especially around on screen graphics, lettering etc.) when in HD mode. I attempted to align the colors through the color convergence but the blue alignment did not work. I also...
No.This tv have a convergence problems,it dead.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board,must be repaired by repacling 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 14, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi TV Model #WS65903 - Green Shadow Lines on Screen
Something is not right here--The green is adjustable in the TECH menu--did this person adjust or try to adjust in the customer or the TECH menu?
If you confirm actual model number I can tell you how to get into the TECH menu--yes--green will not adjust in customer menu--it determines geometry and is only adjusted in the TECH menu.
Also, this set requires any convergence adjustments to be done in 480 and then in 1080--if only adjusted in one mode the other will still be bad.
Let me know if you know how to adjust in TECH menu or not--with exact model number I can tell you how to get there.
If this helps you rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Model 50UX58K - picture has distortion & shadow on right side of screen
Hi, if the shadow is colored lines then you probably need the convergence ICs and possible reisitors near them replaced .
If the shadows is just like a ghost of the image or a bar from top to bottom, then check if it does it on every input (dvd for example) , there are blanking bars that you can't see past the edges of the picture and when you have a bad cable signal you can see the ghost of the blanking bar sometimes. if it does it does not show the shadow when watching a DVD then its a signal issue with your cable/satelitte .
If your convergence is the issue, try the adjustments first and if that doesn't correct it, you can replace the ICs using kit # x480293 or stk392-110 (2 ICs) soldered in very technical for even a technician.
repairman cost about $250-$350
hope this helps
Eric
Sep 01, 2009 | Hitachi 50UX58K 50" Rear Projection...
Distorted Color and geometry of Picture
replace stk 392-110 ( or stk 392-150 same number) , check resistor 2.2 ohms for open or burn beside STK IC's
Apr 13, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Philips 50P8341 50" Rear Projection Television Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
