Question about RCA DRD430RG DirecTV DTV Receiver
The yellow light keeps flashing,and it will not turn on.
My yellow engine light keeps flashing and the engine sounds rough
orange engine light keeps flashing and car seems to want to cut out also making dreadful noise like something has fallen help!!
Jan 18, 2013 | 2005 Renault 181
My ps3 keeps swiching itself of power light turns yellow then flash red
Sucks. You have the yellow light of death. kinda like sonys version of the red ring of death.
Feb 11, 2011 | Sony Playstation 3 (PS3) Console
Why does my ps3 light keep turning orange and turning of
look closer when turned on look for a reallly quick yellow flash before it goes red its yellow light of death which is a critical hardware failure within the console its fixable hope this helps you
Nov 19, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 console wont turn , when i try to it stops and a blue then yellow light flashes , what can i do to fix this.
source: http://www.edepot.com/playstation3.html#PS3_Model_Differences Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 10, 2010 | Sony Playstation 3 (PS3) Console
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
  • Beeps Three Times
  • Red Light Flashes
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Yellow light of deth
  • Beeps Three Times
  • Red Light Flashes
Wont turn on, when i try to the light flashes green then yellow then red and keeps flashing red.
also known as the yellow light of death google it and hopefully u find a solution
Mar 19, 2010 | Sony Playstation 3 (PS3) Console
Ps3 will not turn on
Your playstation is oficially broken and needs to either be replaced or repaired. Sony will fix this problem for $150.00 through their website(under warranty its free). This problem happened because it overheated and the soder melted to the point where the componets shut down and the unit went into safe mode :( :(
Jul 16, 2009 | Sony Playstation 3 (PS3) Console
Well when I turn on my ps3 the green light turns into a yellow light some people call this the yellow light of death after it goes yellow it turns into a flashing red light I try to repaet it but it keeps...
well yes obviously the flashing red light means that if u do not turn off ur PS3 it will die. but depending on how long u have had ur PS3, it may be becuase the life span is almost over.
if u have not had for a couple years it is most likely a manufacturing error
u should send it in to sony before the warranty is up and have them take a look at it
Jul 25, 2008 | Video Game Consoles & Games
RCA DRD430RG DirecTV DTV Receiver Logo
77 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
