Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Not steaming as much as it used to- not as good at cleaning:(
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Posted on Mar 05, 2011
Model sk410. how do I disassemble it?
Shark Steam & Spray Mop: How to Assemble - YouTube
? 1:27
https://www.youtube.com/watch?v=iH2NVXVA4-U
Sep 6, 2013 - Uploaded by Shark Cleaning
Assembling the Shark Steam & Spray Mop is easy. You'll ...Shark Steam & Spray Pro Mop: Using Steam and Spray Mode - Duration: 5:34. ... Shark Steam & Spray: How Do I Use My Mop In Steam Only Mode - Duration: 3:45.
Shark Steam & Spray Pro Mop: How to Assemble - YouTube
? 1:31
https://www.youtube.com/watch?v=I3thGlk2GdU
Assembling the Shark Steam & Spray Pro Mop is a breeze. ...Shark Steam & Spray: How Do I Use My Mop In Steam Only Mode - Duration: ...
Shark steam mop S3601 disassembly. - YouTube
? 3:38
https://www.youtube.com/watch?v=zq07GHhbJkI
Jan 07, 2016 | Shark Professional Steam and Spray Mop
Shark S3501 steam mop - How do I use the purple nubby (dusting?) pad?
It's good for wood floors. Just put it on and you'll be doing dusting and steam cleaning at the same time. hope that helps!
Nov 25, 2014 | Shark Vacuums
How do i clean off hard water deposits off the bar inside so that steam will come out again?
there are iron cleaning products available fro small goods retailers or repair shops that will break down those deposits
while it easy to fill from the tap , if you read the user manual it is recommended to use de-mineralised water for irons not tap water
Sep 13, 2017 | Scunci SS1000 Handheld Steam Cleaner
How to hook up tool to clean upholstery
Keep your upholstered furniture looking fresh by vacuuming it regularly with the upholstery tool attached to your vacuum's hose. Prevent the fabric from fading (or at least delay this) by keeping your furniture out of direct sunlight -- close blinds, shades or curtains when the sun shines most directly through windows closest to the upholstery. And remove stains by blotting them with a dry cleaning solvent. Before steam cleaning your upholstered furniture, read the piece's cleaning code label to determine whether or not it is safe to do so. Then rent or buy a steam cleaner (also called an extractor) and follow the directions below.
  1. Rent a steam cleaner or purchase one; buy steam cleaner solution.
  2. Step 2 Vacuum the upholstery on the furniture you wish to steam clean; use the upholstery attachment to most effectively **** up loose debris.
  3. Step 3 Test the steam-cleaner solution on the upholstery in an inconspicuous place to ensure the color won't be steamed out or drastically altered.
  4. Step 4 Attempt to remove any stains with a stain removal or dry cleaning solution. Follow the directions that come with the product you choose for the best results, and allow the stain remover to dry before you begin steam cleaning.
  5. Step 5 Remove cushions and, if necessary, arm covers.
  6. Step 6 Gently apply the steaming water and cleaning solution in straight lines across the upholstery one section at a time.
  7. Step 7 Use the cleaning extension on the steam cleaner to **** up as much water as possible. The dirt will come out with the water.
  8. Step 8 Clean one side each cushion (then allow it to dry) before cleaning the other side. If the cushions are permanently attached to the furniture, clean them last.
  9. Step 9 Allow the furniture to dry completely before repeating the steam-cleaning process or replacing the cushions.
Jun 19, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Streaking
you maust have some type of wax build up on ur porceline tiles that has not been removed, and should never been used to begin with as poceline is its own finished luster...or you may have used a strong concentration of cleaner that has left behind residue and needs more water clean up.....try looking to see what type of lines,and size the streaks are and decide if they are created by the cleaning pocess or are left behind by the cleaning solution.....good luck...hope this helps..
Feb 26, 2010 | Euro-Pro Ultra Steam SharkTM II Hard...
Steaming very little. The mop used to have strong bursts of steam, but now will steam very little. I use distilled water in the tank. Should I clean it with vinegar and water?
It will not hurt it to try and clean it...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Dec 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Does it matter what kind of cleaner I use on the Deep Cleaner Model F5821
Yes it does matter which cleaning solution that you use in your steam cleaner. If you use the wrong cleaning solution it may cause problems with the cleaning solution dispensary system. Different steam cleaners use different cleaning solutions. You should always use the steam cleaner solution for your specific cleaner. I have learned this the hard (and expensive) way.
Hard to recommend this but it will work in a pinch. You can use a small amount of liquid laundry detergent diluted with hot water (about 2 table spoons to a gallon) as a stand in for the real deal. DO NOT put the laundry soap solution into the cleaning solution reservoir (the wax content will clog the soap dispensary system). Lightly apply to the area to be shampooed (do not soak). I have used a plastic coffee can with holes poked in the lid like a watering can to apply the soap solution. Use the shampooer to do the scrubbing and remove soapy water from the shampooed area. Fill your soap reservoir with clean hot water. The laundry soap does most of its job during the rinse. Go over the shampooed area with the shampooer moderately soaking the shampooed area to with the hot rinse water. Remove as much of the rinse water as possible. Liquid laundry soap has a high wax content (makes your cloths soft) and if it is not rinsed thoroughly after it is dry the remaining wax will attract dirt faster than the surrounding areas. Other than that it works for a good stand in for the proper detergent in a pinch. As a bonus it smells great.
From what I understand as unorthodox as it is, it works well in small doses, and I don't believe that it causes any damage to the other parts of the steam cleaner as steam cleaners survive drawing up worse things into them than laundry soap.
I hope that you find this helpful
Good Luck!
Jul 28, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Shark Steam mop won't steam
heatman101
zsd
Nov 16, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam and spray
the heater may be clogged. You will have to take it aprt, pull the hoses off, using somothing small, clean out the prots that the hoses hook to. After that, blow thru it if you can to see if air comes out. Then after it is put back together, put a mix of vinegar and water in and let it run thru until it works good again. Calicum and such plug up the works and just need to be cleaned out.
Feb 13, 2008 | Sharper Image Turbo SM420 Handheld Steam...
Black & decker steam buster
Step 1 - fill the rear tank with water. Clip the tank onto the back of the unit.
Step 2 - plug the unit into the wall.
Step 3 - move the switch to "steam". You should hear the unit 'ticking' at the rate of about 120 clicks a minute (2 clicks a second). The clicking should be "kind of" loud until the water makes its way into the pump.
The clicking will get quieter as the water moves through the pump and into the heater. The book says that you should start getting steam in a couple of seconds. My experience is that you don't get a good head of steam up until the unit has been going for about 20 seconds.
Another recommendation: don't use "Spray" until the steam is really rolling out of the unit. It just overpowers the heater and slows your steam production.
Step 4 - Steam the spot you want steamed. If you want to soak the spot, use "Spray". Most of the really good cleaning power of the unit is through the steam, so use that more than spray.
Step 5 - Switch to Vacuum and **** up the moisture from the steaming.
Repeat Steps 4 and 5 until you're happy with the cleaning.
Step 6 - Empty the front tank, rinse it out. Empty the rear tank; you probably won't get all of the water out, but that's not a problem. If you use tap water, put in a couple of teaspoons of vinegar and let the unit run until you've sucked the last of the water/vinegar solution out of the tank. If you use distilled water in the rear tank, you might be able to skip this step.
Step 6 is intended to reduce the amount of lime scale that will build up in the pump over time. You should probably avoid stronger chemicals, since they are going to sit in the pump until you use the unit next, and the first few seconds of steam on the next use will have whatever chemicals you are using.
Aug 31, 2007 | Black & Decker SV1000-4 SteamBuster Vacuum
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
