Question about Garden
Sstrimmer running very slowly - Garden
  • 7,482 Answers
Check your fuel filter in the fuel tank, if you have one.
It may need replacement or cleaning.
Also check your fuel tank for debris/trash and clean it out if necessary.
If the mower/weedeater is over a year old, then I recommend that you buy
and install a new carburetor repair kit,because the diaphragm will get hard
and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor
internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small
rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid
and letting it run a few times like that and it will flush the gunk out of
the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to
reassemble the carburetor or follow the instructions you get with the
carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need
to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes
to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first
and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Jan 05, 2011
Was runing fine then lost power still runs
disconnect the MAF SENSOR located before the throttle body on the air intake. the car should run better but not perfect. if the car runs better change the sensor
Mar 14, 2014 | 1999 Ford Explorer
Running very slowly at start-up and accessing file
Look into Upgradeing your ram (memory) also if you hard drive is full you computer will boot up slowly and the computer it self can run very slowly.
Aug 25, 2013 | Computers & Internet
Need to make carbertor ajustments
mainly while engine is running turn both set screws one by one slowly all the way in the back off one and 1/4 turn that is a good start then slowly with the one on right slowly keep turning until engines runs smooth
Oct 24, 2012 | Cars & Trucks
RUNNING VERY SLOWLY
you might have a virus check in your task manager look in process and shut down some process look to see if the cisvc process is running if it is shut it down this will totally make your computer run better
Sep 28, 2012 | ASUS Eee 2G Surf Notebook
Rosetta stone farsi running slowly on iMac
The only thing I can see from your machine specs is that you only have 256 MB of RAM. This is quite low for running the system and also programs.
Jul 12, 2012 | Rosetta Stone 3 Farsi Level 1 2_3 Set Full...
I have 1995 Mits Lancer glxi matic. I observed that at normal idle or running condition, the engine rpm is slowly, slowly dropping to zero. Im just pressing the gas in order to keep running. otherwise will...
Try checking the codes. You can do this at part stores like auto zone for free. It might be the maf sensor or if it says lean o2 sensor than it's the fuel filter.
Jun 29, 2010 | Mitsubishi Lancer Cars & Trucks
Cold water run into washer slowly. Pull off cold
water may flow fine through the hose itself, but you prob. have a damaged water inlet valve on the washer.. ( what the hoses are conected too... hope this helps...
Oct 27, 2009 | Washing Machines
GAMES BECOMES RUNNING VERY SLOWLY
mmm do you have an antivirus running in the background? that would explain a lot, when it starts scanning it slows down your computer, see if you can disable it before starting any game
alex
Mar 25, 2009 | Computers & Internet
Computer runs too slowly and ''grinds''
Depending on the situation, It could be you need more ram. If your running Windows Vista, 2-3 years old computers are probably coming with about 512mb-2 gb's or ram. In which case grab at least 3 gb's or ram and you'll be ok. If it's an xp system. grab at least 1gb or ram. Internet delay though could possibly be due to your ISP or perhaps a virus/spyware. There are certain viruses and spyware that slow down internet connection while leaving your pc running fast.
Mar 18, 2009 | HP Computers & Internet
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
