Question about Microwave Ovens
Belling E668. Back left ring thermostat has failed
    Brigadier General:
  • 8,909 Answers
PLenty of spares from belling.co.uk or espares.co.uk
Is it the dial or is it the ring itself that has failed?
Straight forward enough to replace after disassembly and reassembly is the opposite.
Make certain the cooker is cold and disconnected from the mains!
Posted on Jan 02, 2011
How to defrost in belling microwave oven del stw25 ?
Visit the companies web site and download the manual.
Sep 16, 2014 | Belling Microwave Ovens
The turntable in my oven has stopped working
Possible that the motor has failed, remove the bottom and check for the voltage to the motor , is present the motor has failed, is not the board is faulty. check the belt drive.
Jan 11, 2013 | Belling Microwave Ovens
The ovens in my belling classic ninety deluxe will not heat beyond 110 degrees. what is wrong with it?
Probably thermostat is faulty.
Employ a Belling Approved appliance engineer to check and replace it if in needs replacing.
Jan 04, 2011 | Belling Microwave Ovens
My belling microwave oven will not heat up even though it still powers up. I bought it 3 years ago and is in perfect condition otherwise. A week before it stopped functioning, I accidentally left it on for...
Leaving the unit on with nothing inside probably was the cause of the current failure. What happens is RF reverse flows into the magetron and causes the power diode on the capacitor to fail or the capacitor itself fails. This is not a difficult or expensive repair. IF by chance you attempt self repair make sure the unit is unplugged and that you ground the capacitor 3 times before prceeding with any testing.
You disconnect one end of the diode and read across the terminals. One direction it will read like a wire and the other it will read open. (Good) If it reads continuity in both directions it has failed. If it reads open in both directions it has failed.
Checking the capacitor you simply probe across the terminals with a meter watching for a jump on the meater EACH time the tests leads are REVERSED. No Jump leads reversed = bad capacitor.
I tried looking up parts for Belling in UK but was unsuccessful. You can get a replacement diode or capacitor from any appliance parts source. They are NOT brand specific. Just take your old part with you if you find one of them defective.
Thanks for choosing FixYa.
Kelly
Aug 24, 2010 | Belling BIM60 Microwave Oven
Instruction manual for Belling Combi oven BEL-CJSS25
Did you try this?
Lines are open Monday to Friday 8am - 6pm and Sunday 10am - 2pm.
Belling Customer Care: 0871 22 22 503
Or maybe this?
Belling Product Helpline
0871 22 22 635
Product Helpline Open Times
Monday to Thursday
9am - 5pm
Friday
9am - 4.30pm
Spare Parts
0871 22 22 506
Nov 24, 2008 | Belling Microwave Ovens
Belling microwave
Turn table motor open circuit/drive shaft damaged
Oct 18, 2008 | Belling Microwave Ovens
Belling Microwave Problem
Apparently this one has a mechanical timer. That lack of electronic controls does lessen the complexity. I don't know about the specific regulations concerning British / EU microwaves, but I'm sure there's a fuse inside. In most cases, just replacing a blown fuse will not be the cure, unless one finds the reason it blew. What made it fail (if it did) is the real question. Loose fuse holder allowed excess heat? Shorted component or wiring? Or, is there a failure in the mechanical timer that's causing an open circuit connection? That can certainly happen. Also, a door switch may have failed. This is most commonly caused by opening the door while it's cooking, instead of turning the oven off first. I would suggest you contact Belling service: http://www.belling.co.uk//CMPage.aspx?pageid=130&subsectionid=85§ion=ContactBelling Good luck.
Oct 11, 2006 | Belling BIM60 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
