Question about Video Cameras
How much would it cost to replace a corroded capstan motor
    Genius:
  • 1,812 Answers
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Jan 02, 2011
SERVO CAPSTAN MOTOR FOR REAL TO REAL AKAI GX-77
Check power drive circuit and ohm out traces on control board. The glue they used has been known to conduct and corrode through the foil traces that go to the control circuits.
Apr 17, 2014 | Audio Players & Recorders
Capstan makes the reels drag sometimes even stops
Replace with a capstan belt from Marrs Communications it should be a 16.8" IC belt. Fred know which one if you tell him the model.
The capstan motor can also be worn out. These need to be taken apart and examined at to brush life and to see if it has bee overheated. I get a lot of motors that are burned up by customers.
It is a $150 part.
Feb 17, 2014 | Audio Players & Recorders
Reel to reel will not play
You do not mention the brand or model number which to answer the question effectively is needed- different machines are designed in different ways. The function of the fast wind and the play mode only differs in that in play a capstan is involved that regulates the speed and the reel motors just do the take-up of taper and a little back tension for the supply reel. You may have either a sticky Pinch Roller linkage or a non- rotating capstan shaft that might point to a loose or broken capstan drive belt. There are also the condition of the Pinch Roller surface and the surface of the Capstan shaft that can be glazed or rubber hard and non-compliant. The rubber Pinch Roller can be re-rubbered, the capstan shaft can be reconditioned and the Capstan Belt can be replaced. Capstan bearings and motor bearings need oil once a year as well. I hope this helped to some extent- I have been working on decks now for better than 40 years.
Dec 12, 2012 | Audio Players & Recorders
Cassette loads and won't play. Cassette won't eject, or if it does the tape itself hangs inside the VCR. The cassette reels do not turn anthough the head does. I believe the problem lies with the belt...
Hello
There si one belt connected to its capstan motor to reel drive gear assembly to reel up the tape. If this belt has either loose or broken, the fault you described here will occur. To change the belt, you have to buy one new with same diamentions. To get it, you must ahve the damaged belt in hand as sample. Just look at its bottom side, and is there any extra sid screwed into, which can be removed to see and take the belt away from the mechanis. There will be one, with every Toshiba VCR. If so, open it by unscrewing the screws, take out the belt, buy a new one and replace it.
Before doing this, make sure that the capstan motor is rotating or not. Just unplug the VCR from power socket, and replug it again. If capstan motor try to rotate even a single turn, it means that it is OK. Replacing the belt should solve your problem.
If you want anymore asistance, feel free to get me through Fixya. OK.
Feb 25, 2011 | Toshiba M782 VHS VCR
My Teac 4070G reel to reel tape deck rewind and fast forward functions work, but the play function does not. Any ideas? Could it be a circuit?
Without actually seeing your Teac reel deck, i suggest you verify that all fuzes in the deck are good..not blown. Also with a tape correctly installed..ensure that left and right tape tension arms are held under tension/ closed by tape tension, also ensure the capstan shaft is rotating... look in back to ensure the capstan drive motor is running.. if yes, and tape still will not play... problem could be a stuck/failed solenoid, dirty or corroded push buttons, or corrosion on contacts where rear circuit boards/plugs insert into other boards.
Feb 28, 2010 | Audio Players & Recorders
I have TEAC A 4010. Motors are running, belts are ok, but tape does not turn. When I push on the capstan the tape wants to turn, but stops.
Ensure the rubber pinch roller presses the tape against the capstan drive shaft....ensure the capstan drive motor is turning..and the belt to the flywheel is snug, and not slipping. the tape transport engage relay might be stuck...a relay maybe corroded ...may need cleaning. Without seeing it cant say clearly what may be the problem. also ensure the tape tension/shut-off arm is under tension by tape that is correctly installed.
Oct 27, 2009 | Audio Players & Recorders
Capstan motor of NV-M9000 is not working properly
This is not the capstan moto but the belt from the capstan motor to the idler gear. you need to change it with the correct size.
rgds
Luwangula
Mar 03, 2009 | Panasonic Palmcorder PV-GS15 Mini DV...
E06
E06 is a capstan motor problem.The capstan motor needs replacing.
Sep 02, 2008 | JVC GR-D20EK Camcorder
Akai gx-646 capstan motor runs way too fast.
You must replace transistor for capstan motor speed ( transistor code is 2SC2336 ). This transistor it is near power transformer.
Jul 23, 2008 | Audio Players & Recorders
Trouble working sony dcr-trv6 mini dv digital camcorder
( c : cassette : 30 capstan fg ) ; your capstan motor is stalling - try ( other brand ) new tapes and gently ! swaying camera from side while loading - if loads , your tape mechanism is dirty or is going out of alignment ; - - if the camera will not unload tape ? the capstan motor may be failing ( connector is loose , corroded ) or - it is jammed and it needs . . . disassembly . . . to complete checking .
Aug 06, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
