SRAM ERROR MSSING E problem: We have OKI C7350 Printer in our office and when I put off the said printer, the window displayed SRAM ERROR MISSING E. I tried putting off and on several times, but they same thing happened. Please help ASAP.
samkong
  • 106 Answers
SOURCE: priter trouble
Please uninstall the printer driver and it's application completely after disconnecting the printer. Clean all the Temprorary files if any(Start>Run>"temp">Enter>Delet All. Then Start>Run>"%temp%">Enter>Delet All) Restrat the Computer and reinstall the driver. It should solve the Problem.
Posted on Oct 06, 2007
  • 3 Answers
SOURCE: Error LED blinking after paper jam, won't print
I have a similar but different model B4300. Several others, & I have found that a small piece of paper 1/2 square may lodge under a plastic guide, holding open a switch. This is very difficult to notice if you don't know where to look.
Open top lid
Remove the ink cartridge/roller drum as a single unit.
Look in the printer at the metal roller in front.
A Plastic strip on top & in front of the roller covers 2 square holes which should look dark. On your LEFT, as you face the unit, there is a small magnetic switch, to the LEFT of the LEFT square hole, under the plastic.
In my case, the paper was seen as white in the hole, and extended under the switch. I was able to grasp it with a small medical forceps, next to the switch. By gently twisting, I pulled it out without taking the unit apart.
The printer then worked perfectly after the paper under the switch was removed.
Posted on Feb 28, 2008
  • 32 Answers
hi lorraine3 -
I hope you didn't 'throw it out the window!' just for a future quick ref, here are a couple fast links to hp support docs about paper jams and blinking lights that might help:
-paper jams
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00491031&dlc=en&product=501369
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00489775&dlc=en&product=501369
-blinking lights
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00496863&lc=en&dlc=en&cc=us&product=501369&rule=34731&lang=en
-JW50
Posted on Oct 08, 2008
frenzy19
  • 258 Answers
SOURCE: Emty error with new toner. Oki B410
first option is to reinsert it second option is to try resetting the machine
Posted on Mar 06, 2010
  • 97 Answers
SOURCE: I have attempted to install 3 different black
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Posted on Mar 29, 2010
134 error
134 error is led head missing , the fault is either ( if your lucky) the k led ribbon cable has become unseated or the k ribbon pins are damaged (you can trim them with scissors.
Alternatively more often than not someone has nicked the led bar off and tried to put the cable back in without turning the printer off blowing the fuse on the maintenance board. The holders for that model are prone to cracking also.
Apr 10, 2014 | OKI Office Equipment & Supplies
How to fix error 491: Tray Empty on Oki c5400
printer oki b411dn put out of the balcony, unsatisfied by his work, too many error codes, to lost time, to failed
Feb 27, 2012 | OKI C5400 Laser Printer
My OKI B4600 is displaying error 134
It means the printhead [laser] is "missing" - but usually it's just the data cable at the end of the printhead has popped out. Very common - we have hundreds of Okis at our corp and I've fixed this many times. Turn the power off, pull either the left or right plastic clip AWAY from the printhead, and carefully insert the data cable back into the connector on the printhead. Put one end of the printhead nearest the data cable back into its plastic clip, and make sure the spring is seated on its little post on the bar, and then click the rest of the printhead into the clip on the end opposite of the data cable, again making sure the spring is seated on its post. Turn the printer on - your error should now be gone.
Mar 01, 2011 | OKI Electric Industry B4600 Laser Printer
Toner sensor error
Hi
This error comes up when the printer detects that the toner of particular color is missing. This indicated that the indicated color toner is missing from the printer(eg-- C = Cyan, Y = Yellow, M = Magenta, K = Black).
C5150 may face a toner sensor error after installing used sets of toner cartridges and sometimes even after installing new toner cartridges as well. This error can be bypassed. This can be disabled by following these steps---
1. Turn machine on while pushing and holding the (+/-), menu buttons at same time.
2. Menu window will show OKI USER.
3. Scroll to Engine Dialog Mode is indicated Push Enter button.
4. Diagnostic Mode xx xx xx S Mode is indicated.
5. ( = 2 ) . Press (- or +) button until “ENGINE - PARAMETER SET =2” is displayed.
6. Push Enter button.
7. TONER SENSOR - ENABLE is displayed.
8. Push Enter button.
9. Press (- / +) TONER SENSOR = DISABLE is displayed.
10. Press ON LINE CANCEL buttons at same time.
11. (*) is displayed.
12. Restart the Printer.
Daniel Scott
Jun 22, 2010 | OKI C5150n Led Printer
What's different of oki c7200 and c7300 cartridge?
They are different and can not be interchanged
C7200 work with C7200/C7400
C7300 work with C7350/C7300/C7550/C7500
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 14, 2008 | OKI Office Equipment & Supplies
356 BELT ERROR
Please Google your problem.
The method in the following link helped us to solve our same problem.
<OKI C9300 Code 356:Belt Unit Life>
http://www.fixyourownprinter.com/forums/printer/53306
There is a shortcoming, however, in this method:
The reset process resets the usage stats of toners, drums, fuse and belt. After reset it displays on Print Supervision as if all the a.m. parts have been replaced with new ones.
Aug 16, 2008 | OKI C5200n Laser Printer
Error message
Cause:
This message is related to the on-board SRAM on the Print Engine Control Board Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Replaced the Print Engine Control Board,
Dec 19, 2007 | Xerox Phaser 7300DN Laser Printer
Sram error missing E
Better if you have other person to help you.
Turn off the printer, hold 0 3 5 6 7 buttons, turn on the printer, wait until the *s disapair.
Jun 07, 2007 | Xerox Phaser 7300DN Laser Printer
How to correct error message sram error missing E?
Hate to say this but most likely the Print Engine Control Board has failed.
May 09, 2007 | Xerox Phaser 7300DN Laser Printer
369 people viewed this question
jasbo
jasbo
