Question about Microsoft Computers & Internet
List of DOS commands - Microsoft Computers & Internet
  • 98 Answers
If by DOS you mean CMD, then use the HELP command. Most of the available commands that you can use will appear. Other commands are used by external programs.
Posted on Jan 02, 2011
2 Suggested Answers
  • 26 Answers
SOURCE: dos commands in linux
Ooohh. A command line fan!
Here's some basic commands for you
cd - Go to previous directory
cd Go to $HOME directory (cd dir && command) Go to dir, execute command and return to current dir LS Linux version of dos's DIR Dir will ALSO work though.
FDisk Manipulate the partition tables
CP copies one(or more) file to another location
Eject Ejects cd/dvd media
Exit Leaves the command line goodness, and returns to GUI
Man Important reading for linux newbies
MkDir make new directory
MV move or rename files and folders
rm delete a file
Rmdir remove(aka delete) directory
Umount unmounts a device("safe removal" for thumb drives)
Posted on Jun 01, 2009
Need a list of commands
what do you wish a list of commands to ?
for the dos prompt in windows ?
what is your p.c. running is it Windows 8 ,
Apple IOS ? Ubuntu ? Linux, Unix, ?
Jan 01, 2015 | Computers & Internet
What happens wen rtc Batt is unloaded
Hello. batt files or batch files are used by your operating system to run a list of commands created by ms-dos or by you. A good example of a batch file is the autoexec.bat which is loaded each time the computer boots to MS-DOS. Batch files are like shortcuts on your desktop, when they are run they pass information through the command line and these sets of instructions run commands or programs on your computer. Did that help?
Feb 09, 2014 | Acer Predator G3620-UR308 - Core i7 3770...
Format.....
To format a hard drive, You can simply use the Fdisk command from DOS -
C:\fdisk
This will bring up a list of commands and useage.
You can also use the format command from within DOS -
C:\format c:
This will prompt you "all data on disk C will be lost, are you sure?"
Type 'Y' and hit enter.
From within a windows/linux/unix environment, you can right click on the disk you'd like formatted and select "format".
From within Mac OSX, open disk utility, and select the disk you'd like to format. Click on "unmount disk". Once unmounted, you may format the selected disk.
Hope this helps.
Jul 18, 2012 | Gateway Computers & Internet
Check list utility on Windows 7
Check Disk Utility???
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 13, 2012 | Dell Computers & Internet
What is the mean auto exe c bat in dos files??
An AUTOEXEC.BAT file contains MS-DOS commands which are executed automatically when a Personal Computer boots. This file is usually located in the root directory of the hard drive or floppy from which the computer boots (or starts) up. The AUTOEXEC.BAT file is used to set various default settings and to run programs that should be executed upon startup. Below you will find a list of executable statements (commands) that typically go into an AUTOEXEC.BAT file, along with explanations their.
The AUTOEXEC.BAT file is one form of a batch file, and it is used to automate functions in MS-DOS. In their simplest form, batch files contain MS-DOS commands (batch file language) which includes commands for such things as loops and execution branches and the like.
ECHO
Example: @ECHO OFF
This optional command will suppress the display of subsequent commands while the AUTOEXEC.BAT file is being executed
Dec 09, 2010 | Computers & Internet
Looking for a list of Dos Commands the old ones one c:/dir c:/dir/p and so on.
dear friend here is the link for dos commnads that your looking for .......http://www.computerhope.com/overview.htm.........rate me if its helps u.............
Nov 28, 2010 | Computers & Internet
Good day, pls. help me, how can i install network ip address for konica 7035. thanks alot
Using arp command (Windows 95/98/NT/2000)
From Windows 95/98 MS-DOS prompt or at Windows NT/2000 command prompt, you can use the arp
command to assign the IP address to the network interface card. It is necessary that TCP/IP is set up
correctly on the computer that will execute the arp command. Perform the following procedure:
1. At Windows 95/98, select [MS-DOS prompt] from the [Start] menu. At Windows NT/2000, select
[Command prompt] from the [Start] menu.
2. Execute the arp command. For example, if the MAC address of the network interface card is
00:11:22:33:44:55 and the IP address to assign is 192.168.0.128, then input as shown below,
and then press [Enter].
(Example: C:\>arp -s 192.168.0.128 00-11-22-33-44-55
3. Execute the ping command for the assigned IP address. In this case no response is returned
from the network interface card.
(Example: C:\>ping 192.168.0.128
4. Turn off the main power supply to the print controller and the main body printer, then turn it
back on.
Chapter 2 Setting Up the Network Interface Card
2-4 Konica Network Interface Card INSTRUCTION MANUAL
A Status Page will be output. Check that the IP address is correctly set in the list. Or, when about 5
minutes have passed after having restarted the print controller and the main body printer using the
ping command, check that the network interface card responds correctly. The ping command is also
executed at Windows 95/98 MS-DOS prompt or Windows NT/2000 Command prompt. The example
of executing the ping command is shown below:
Aug 31, 2009 | Office Equipment & Supplies
Dos commands in linux
go to http://www.pctechguide.com/articles/gettingDedicated12.htm you will find all the commands you need in there.
Jun 01, 2009 | Microsoft Computers & Internet
Run dos command through vb 6.0 without showing it
visual basic, on windows, right? jumping to dos, implies a command line, no? how else would you access a command line interface, if not through cmd?
Mar 20, 2008 | Computers & Internet
Computers & Internet Logo
1,387 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
