Question about Sharp Microwave Oven Microwave Oven
The food in the microwave is not heating up I have tested the fuse (F8AH250V) and found that it has blown. Is it safe to replace this fuse (F8AH250V) on my microwave.
I recently had the same problem with the F8AH250V fuse blowing, all functions :- grill, convection, turntable. light etc were working but no heat from the microwave, the problem was Magnetron failure
Posted on Mar 05, 2011
    President:
  • 2,992 Answers
Fuses seldom just go bad on their own, but it's safe to replace. Before you replace the fuse, squeeze the tabs of the fuse holder clips together a bit. Sometimes they don't grip the fuse tightly enough, and this can cause heating which damages the fuse. If the fuse blows again there is a bad part in the oven that will need to be located and replaced. For a small countertop oven, it's probably more economical just to replace the oven than to repair it.
Posted on Jan 02, 2011
Testimonial: "Thanks very much for your help I will try your suggestions."
  • Mark Wain Feb 28, 2011
    Thanks i will try a replacement fuse and let you know if i find the reason for it blowing. D.I.Y.MAN
Whirlpool over the counter microwave stopped working
SEE THE steps and fix it. and diagrams attached.use the DVOM.God bless you
Line Fuse
Every microwave oven has a line fuse. This fuse is designed to blow if too much current is drawn through the microwave circuitry. The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.
Main Control Board
If the microwave is not working the main control board may be defective. This is not common. When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Thermal Fuse
If the microwave is not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown2_6_2013_8_43_03_pm.gif2_6_2013_8_43_37_pm.jpg
Feb 06, 2013 | Microwave Ovens
250v20a fuse blown just no heat
If there is spark please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground. As you have mentioned it was stored, it is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Now switch the microwave power on and use a cup of water to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. Replace with same type. If not check the waveguides within the cabin for food particles that can burn and spark, check for rust that can corrode and spark when the ceramic paint has worn out.
If there is heating without any issues, you can use the microwave safely
Click on replacing waveguides: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Jan 30, 2013 | Magic Chef Microwave Ovens
Microwave oven not heating
This a good indicator the magnetron is gone, sometimes leaves odour that is destinctive.
Jun 19, 2012 | GE Profile PVM1790DRCC Microwave
Microwave light comes on and turntable revolves when food is put in, but it doesn't heat food up. Food remains cold, can you help? thanks Dee
9 times out of ten it is the magnatron that has gone bad, that is the device that creates the microwaves for heating the food. Check inside the cabinet for fuses and if none found or blown then it is the magnatron. These are available widespread but most cost about as much as a new oven, so do a google search on your make and model of microwave and search for a magnatron for that unit. This will bring up parts suppliers and their prices and you can decide if it is worth fixing or replacing
Apr 04, 2011 | LG Microwave Ovens
I have kitchen aid microwave modelkcms185jss starts runs fine but does not heat food at all.
Does not heat food means a problem on magnetron tube and fuse blown in high voltage area. Have it replaced and it will heat again.
I hope I answer your problem.
Mar 30, 2011 | KitchenAid KCMS185J Microwave Oven
Microwave Fuse
you can use any 8 amp fuse of that caliber even a bit larger if you had to.
Phil
Apr 14, 2009 | Daewoo KOG-867T Microwave Oven
PanasonicNN-K627M micro & browner
it is obvious that nthe microwave side of the unit is not working.
microwaaves have a terrible habit of blowing fuses for the most stupid reasons. No not the fuse in the plug but the ones the manufacturer hides inside the case, you will have to look hard. if one is blown replace it with a direct replacement. and do not test the machine with the cover removed
Feb 19, 2009 | Panasonic NN-S753 Microwave Oven
Cuisinart Microwave won't heat food
open the casing and replace the blown fuse.there are several so check them all. probably why the machine was in the auction
Feb 05, 2009 | Cuisinart CWM-100 Microwave Oven
Microwave arced, wont heat now
I'm assuming that it doesn't microwave either. If it does...then the heater is bad. Sears parts sells them. Second guess is a blown fuse or thermosensor. Inside the pad housing, locate the internal fuse and replace it if blown. The thermosensor is a black plastic bit about the diameter of a dime and 3/8 inch thick and clamped to the side of the unit inside the control area. Test it for continuity and replace if open. If not either of these, then you have power supply issues or control panel problems. My bet: the heater blew out. Often, this is caused when you heat greasy foods.
Dec 16, 2007 | Kenmore 69642 Microwave Oven
Not heating the food
sam..vane...two different problems.
Sam...find out if you've got power in the outlet you're using. If not, you've got to check to see if you've got a blown fuse in the unit. Also ...see below.
vane...chances are you have a power issue or the thermosensor which is used for a safety has blown. It is the size of a dime and 3/8 inch thick...black...two wires. You'll probably find it has opened. Found attached inside the control area to the side of the microwave heating area.
Dec 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp Microwave Oven Microwave Oven Logo
1,185 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
