Question about Parrot SA Parrot Ck3100 Lcd Handsfree Bluetooth Cellular Kit With Display
On my parrot 3100 the connect code 1234 does not work with my new nokia mobile 6300
Try this code 0000 as pass key ! I am sure it will help !
Posted on Feb 13, 2011
NOKIA 6300
Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Master Default Security code:1122
Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Dec 06, 2012 | Nokia 6300 Cellular Phone
This is my Nokia 3100 IMEI no. plz help me to unlock my memory protected code Its impossible for me to recall it 355396007040663
are you asking for security code for your nokia 3100? if you forgot your security code then try default code "0000" or "1234" and if it does not work then go for master reset..try unlock-free to get master reset code for your mobile and reset your mobile..
Sep 25, 2011 | Nokia 3100
Just boughta car with parrot in cant connect to phone do i need a code number
Your your phone to the Parrot, but this should be started automatically. If not check your phones manual on how to pair. The pairing code for the 3100 is '1234'. Enter that in when requested.
I would also suggest seeing if there's a firmware upgrade for your device. You can download the updater here. The updater will walk you through the process of downloading the firmware and flashing it to your device. The only requirement is that you need a computer (preferably a laptop) with bluetooth. These firmware updates will often fix syncing problems especially as new devices come out.
Hope this helps
Ray
Mar 08, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Cannot connect new Sony Ericsson to parrot C K 3100 it worked perfectly on my old phone still using the same sim card but i am getting a message saying connectivity failed
try deleting all the old phones from the parrots paired devices, then try again passcode is 1234. if this still dont work you may need a software update on the parrot.
Nov 13, 2010 | Sony Ericsson J220a Cellular Phone
Code for nokia 6303i / parrot ck3100
code is 1234 but you may need to delete any existing devices from the settings menu on the parrot before it will allow new connections.
Jun 19, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Cant pair nokia 6300 with parrot minikit handsfree
hi
remove the 6300 battery then re-fit, then try to pair with kit, code should be 0000 or 1234.
hope this helps
Jan 28, 2010 | Parrot MINIKIT Bluetooth Hands-Free Kit...
My Nokio E52 'sees' the CK3000 Evol parrot, but will not connect.
Switched on the E52 the blue tooth option External SIM Modus to On and kept on trying. And then finally the phone asked for accepting the arrot connection. Entered 1234 and it worked.
Oct 12, 2009 | Parrot Par Ck3000 Evolution Ck3000...
Pairing CK 3100 first time with HTC touch
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Parrot device and click add
6) You will be required to enter in a pass code which is standard ‘0000’, but try '1234' again if that doesn't work
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
Dec 24, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Pass code parrot ck3100
what is the code for my parrott ck3100 for my sprint phone
Apr 28, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Parrot SA Parrot Ck3100 Lcd Handsfree Bluetooth Cellular Kit With Display Logo
166 people viewed this question
Top Parrot SA Cell Phones Experts
Al
Al
Miroslav Rusev
Miroslav Rusev
repairphone
repairphone
Are you a Parrot SA Cell Phone Expert? Answer questions, earn points and help others
