Question about Candy CNW136 Front Load Washer/Dryer
Candy trips out house mains power when turned on
    Genius:
  • Candy Master
  • 1,466 Answers
Has short circuit some part try disconnecting wires to the Heating element as this is common ,Could also be several other this , process of Elimination to locate this problem .happy new year from Glasgow.
Posted on Jan 02, 2011
No power on washing machine (candy go1482) it blew the house trip then since then wont turn on ive tried an extension lead and still does not work
Sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 10, 2011 | Washing Machines
Model is Candy Alise 1200 SE fault is, trips house earth leakage breaker as soon as washer power switched on!
Short circuit on machine Disconnect the heating element located at the back of machine pull off the two wires then try switching on for fault, hope it clears......
Jun 13, 2011 | Candy Washing Machines
Hi my candy retro r43 oven tripped the main rcd to the house, now it wont heat up. I'm guessing the element has gone? do I just replace element or does other things blow aswell? thanks dan
Most likely this will just be the element. This is generally the most common part in the oven that will need replacing from time to time, depending on use.
Mar 30, 2011 | Ovens
When i switch the oven on the oven trips the main circuit. the oven used to work normal then it started to trip out after it had been on for a long period. you could leeave it off for 10 mins then it would...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Feb 15, 2010 | Candy F248P Electric Single Oven
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
One of our lights blew and the main trip switch is now stuck on
those stips are just on there by pressure its is easy to change them but if you never done it call some one
Oct 26, 2009 | Electrical Supplies
Keeps tripping the main breaker on the electrics
Sorry if this is stating the obvious, but this is a sign of an electrical fault. Specifically, what trips the main breaker is leakage to earth (ground). You need a qualified electrician.
Feb 18, 2009 | Candy CPCA240FFK Bottom Freezer...
Candy cs455 m dishwasher tripping out power
if what you mean is that it trips the circut or fuse in your home then the circut that you have it pluged into is not sufficent to hold for the elctrical load that the dishwasher needs. you can do one of two things. change the circut that the dishwasher is on ( plug it into a circut that has nothing else on it or verfiy that the circut can handle a higher amperage .. if thats the case change the fuse / circut breaker to a higher amperage.
peace ... jk
Mar 19, 2008 | Dishwashers
CANDY AQUAVIVA WASHER/DRYER
its either the motor or element gone, remove the back of the machine and remove the wires from each component mentioned. try the element first , MAKE SURE U TAPE UP THE REMOVED WIRES BEFORE TURNING THE MACHINE BACK ON , U WILL GET A SHOCK IF U DONT!!!. if it does not trip , then the element is gone. like wise do the same to the motor. just one more item to check is where the mains cable enters the inside of the machine. good luck
Jan 22, 2008 | Candy AQW130 Front Load Washer / Dryer
Candy CNW136 Front Load Washer/Dryer Logo
137 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
