MY APACER USB FLASH DRIVE CAN NOT DETECTED BY ANY SYSTEM. I USE VISTA OS AND MSI MOTHER BOARD G31 CHIPSET.HOE CAN I REPAIR THE PROBLEM?
SOURCE: need mother board driver
burn it baby
Posted on Apr 20, 2008
  • 1257 Answers
SOURCE: usb flash drive write protected
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
http://www.howtogeek.com/wp-content/uploads/DisableUSBWrite.zip
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 11, 2008
SOURCE: problem with sony USB 2.0 8GB flash drive
My Sony USB 4 GB flash drive will not work on my XP Microsoft OS. It had been working fine for about 3 months, now when I go to open it, it asks with what program do I want to us. However, it works just fine when I put it on a computer with VISTA. Got any suggestions?
Howard
Posted on Oct 19, 2008
ashishd19
  • 35 Answers
SOURCE: Need Windows ME Driver for PNY USB 2.0 Flash Drive Attache
Here's what you can do,
Download the files using the these links,
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbauth.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbhub.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbmphlp.pdr
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbntmap.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbstor.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbui.dll
Put all these files in one folder and when windows ask for the drivers, select the option to manually serach for the drivers. And point the search to the folder where you saved these files and it should fix the problem.
If this does'nt work, please let me know.
Posted on Nov 26, 2008
Chinthakaj
  • 416 Answers
SOURCE: booting from usb flash drive
a step by step guide to create a boot disk
http://www.csd.dficlub.org/forum/showthread.php?t=1136
Posted on Jan 08, 2009
Power failed during MSI P67A-C43 B3 bios update
Download the latest BIOS update from your computer manufacturer's website onto a USB flash drive. Refer to your user manual to obtain the manufacturer's website address. If the downloaded BIOS file is a zip archive, unzip the contents onto your USB flash drive. Jumper settings may need to be reconfigured on some motherboards to enter BIOS recovery mode. Most Intel-based motherboards have a jumper setting or switch near the on-board CMOS battery. The procedure for setting the jumpers will vary depending on your motherboard make and model, so refer to the motherboard documentation for specific instructions. Power on the computer and press "F2" to access the Setup Mode menu. If you are unable to access the setup menu, you will not be able to proceed with this repair. Take your computer to a repair shop, as the motherboard may need to be replaced. Use the arrow key to select "Boot Priority" or a similarly named field. Press the "Enter" key. Scroll down until "First boot priority" or "First boot drive" is selected and press "Enter." Select the USB flash drive as the first boot priority device. Press the "F10" key to save this setting and exit from the setup menu. Connect the USB flash drive to an open USB port on your computer. Then let your computer fully reboot. The USB flash drive should be detected and the BIOS should update automatically. When the update is complete, you may be prompted to restart your computer, or it may reboot automatically. If you are able to use your computer without any further problems of overheating or failure to recognize drives, your failed BIOS update has been resolved.
Apr 05, 2013 | MSI P67A-C43 B3 Desktop Motherboard -...
How to download msi sahara mother board ms6787 ver:2
Hello download the drivers here at msi:
http://www.msi.com/product/mb/P4MAM-L.html#/?div=Driver&os=XP%2032
Start with download and install the chipset driver.
Any file from this site needs to be unziped before you install.
Good luck
Jan 07, 2013 | MSI PM8M-V Motherboard
A75a-g35 hdmi
You should download the chipset drivers for your motherboard. Here is a direct link to the drivers you need for your motherboards chipset. It's a large file but it will have the exact drivers you need for your board:
http://www.msi.com/service/download/driver-2592.html
Here is a link to the rest of the drivers if you need any others:
http://www.msi.com/product/mb/A75A-G35.html#/?div=Driver&os=All
May 28, 2012 | MSI A75a-g35 Fm1 Amd A75 hudson D3 Sata...
MSI K7 MAINBORD USB DRIVERS
Hello visit msi here:
And enter the ms xxxx number from the mainboard.
When you find the mainboard, click on the download tab, and select drivers.
Remember to select your windows system.
I suggest to download them all, and unzip the files in one folder.
Install the chipset driver first, and reboot.
The usb function is available, with at least service pack 1, for windows xp.
Good luck
Feb 21, 2012 | Mercury P4VM800M7 Motherboard
Every tym i insert my pendrive it says insert disk into the drive...???removable disk appears..but it doesnt opns...is there any solution...plz do help me
Assumption 1
Flash drive is damaged, the normal operating system.
Solution
If the flash drive is detected (eg; detected the flash drive in drive G), but it says "insert the disk into the drive ..."
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download).
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
If the flash drive is not detected (not detected as drive G),
the above solution can not be used.
Assumption 2
Normal flash drive, the operating sytem is corrupt
Solution
Flash drives do not require drivers (plug and play). Because flash drives plug and play, it should be, when the flash drive inserted detects the operating system without installing drivers. But, if the operating system does not detect, the possibility of operating systems corupt. The cause is a virus corrupt your operating system.
1. Download and install anti-virus Avira or AVG (free).
2. Update anti-virus
3. Scan your computer.
4. Repair the operating system.
5. If no virus is detected, the possibility of operating system is corrupt.
I hope this information helps.
Oct 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Biostar Mother Board: BIOSTAR G31-M7 TE OS: Windows 7. The Intel Graphics Media Accelerator 3100 On Board Graphic does not boot on Windows 7 with Intel G33/G31 Express Chipset Family downloaded and...
Hi, you can download the driver here:
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=363
Its not for windows 7 but it will probably run on your system.
X86 is for 32 bit and X64 is for 64 bit system.
Try the xp or vista driver.
Hope this will help you.
Aug 20, 2011 | Biostar G31-M7 TE Motherboard
I got win7 installed on my desktop computer ( mother board msi k8mm-v V1.3) when i want to play games it gives me error message "windows media accelerator"
You need to install all the mainboard/chipset/graphic card drivers.
For the mainboard/chipset drivers, please check
http://www.msi.com/product/mb/K8MM-V.html#/?div=Driver
MSI is not prividing the Win7 drivers yet, but you can use the Vista drivers. Select the Vista version (32 bit or 64 bit) to be the same as yout Win7 type (32 or 64 bit)
Mar 01, 2011 | Computers & Internet
Procedures how to recover my files from defective mother board
If you have a flash drive or a thumb drive, put it in the usb port and then the files you don't want lose copy them over to the flash drive. After you do that then go ahead and restore your system and after the restore you can go ahead and copy those files from the flash drive back onto the hard drive again.
Jun 07, 2009 | Intel Desktop Board D845GERG2 Motherboard
Need XP drivers for the MS-7525 Compaq mother board
Almost any drivers will work off the site. MS motherboards are weird like that.
Try this one:
Motherboard driverd are available here:
http://mxdtr.com/index.php/category/msi-ms-7525-ms7525-motherboard-boston-gl6-xp-audio-sound-video-chipset-driver-drivers-download/
Feb 06, 2009 | HP Compaq Motherboard
Computers & Internet Logo
246 people viewed this question
David Payne
David Payne
