Question about Refrigerators
Pool of water constantly forming on floor at front right corner of fridge. Can't identify where it's leaking from. Door seals are new. Fridge and freezer operating well.
  • 29 Answers
Make sure there is no lint or dust in the fan motor located on the lower back of the fridge. If you clean the fan of lint and dust it should help evaporate water in drain pan.
Posted on Jan 02, 2011
We have a Kenmore Elite 795 fridge. It is constantly leaking water from the bottom right corner of the unit onto the floor. There always seems to be a build up of ice at the bottom of the unit.
Usually the result of CONDENSATION due to eithr bad door seals allowing air and moister in to condensate. or a plugged or clogged evaporator drain line which causes water to back up and freeze or leak out the lowest point the bottom?
Mar 19, 2015 | Kenmore Refrigerators
Ice inside my fridge
Check door seal intact and sealing ok, clean rear compressor section of all dust/ dirt/ fluff and check drain hole on rear of fridge.as water should not pool inside but run away outside rear. Lift/ adjust door to make sure it closes properly.
May 17, 2012 | Samsung Refrigerators
Leaking under neath front of refrigerator
Usually any defrost water sits in a plastic pan and evaporates away in normal operation. If the pan becomes brittle it cracks and leaks water. Pull the fridge out and look on top of the black pot (compressor) Is there a plastic drain pan sat on top of it?
Sometimes if the fridge is working hard a lump of ice can form on the pipework going back to the compressor which melts causing some water at the front of the fridge.
Lastly, the insulation under the fridge may have broken down, allowing condensation to form and drip. If the drain was blocked, the water would be inside the fridge, not underneath.
Apr 20, 2012 | Kenmore Refrigerators
Kfcs22evms ice under freezer door and water leaks out onto floor
Check for a clogged drain line at he bottom rear.
Oct 30, 2017 | Refrigerators
Kitchenaid kbfs25ewms2 freezer leaking water
Normally I would agree a water line is the issue however on this particular fridge this is not the case. If you open the freezer door, notice the placement of your hand. Unless it is dead center of the handle this is the cause of the problem and what I believe is a major design flaw. Depending if left or right handed, every time the door is opened the metal tracks that hold the door are being bent. If you remove the bottom freezer basket you will notice the back support bar that is attached to the metal rails is not longer straight.What ends up happening is, certain times when the door is pushed closed it seals completely and other times it does not. The times it does not, there is inch gap between the rubber seal on the door and the fridge itself(left or right side). The freezer warms up and items start to melt. As the cycle of freeze and thaw continues you end up with the entire basin full of ice. Eventually when the door does not shut properly and the ice melts it has nowhere to go expect your floor. This is why sometime you will have a pool of water and sometimes you won't but it always leak from a corner. Learned this first hand and ending up ruining 30sq of hardwood floor
Feb 02, 2012 | KitchenAid KBFS25EW (24.8 cu. ft.) French...
I have a Frigidaire model number FRT18G4AWA refrigerator that leaks water from the top of the refrigerator part and has trouble keeping cold.
Make Sure Your Fridge is Properly Sealed
One of the most common causes of a "leaking" fridge isn't a leak at all. It's the direct result of your fridge not sealing properly, and as a result running overtime to keep things cool. A fridge that runs excessively will build up extra condensation on the coils, which in turn can lead to the pool of water on the floor that's causing alarm. Check the rubber door seals on your fridge and freezer to make sure you're getting a proper seal. If you find a problem, wash the seals with warm water and soap and apply a thin film of lubricant (petroleum jelly works best). If this doesn't solve your problem, you may need to replace the gaskets. Also, check the adjustable legs on your fridge and make sure the fridge tilts a little to the rear. If it's leaning even a little bit forward, a proper door seal can be compromised.
Check the Drain Pan
Your leaking refrigerator may just have a cracked or damaged drain pan. Your fridge regularly drains water into this pan to prevent water pooling in the fridge itself. Evaporation takes care of the rest. Look underneath your fridge where the drain pan sits and pull it out for inspection. If it has a crack or is otherwise damaged, contact the appropriate retailer about getting a replacement as soon as possible.
Check the Defrost Drain
If your leaking refrigerator is draining inside as opposed to onto your floor, you're probably dealing with a clogged defrost drain. Your fridge is constantly producing condensation inside the freezer, and that condensation drips down the defrost drain into a drain pan underneath the unit. This defrost drain can become clogged with debris or, more often, it freezes shut. Look in your refrigerator manual to locate your defrost drain, and take the appropriate steps to unclog it (inundating your drain with warm water will often do the trick).
Check Your Ice Maker for Leaks
If none of these other quick fixes solve your problem, check your icemaker for leaks. It's a bit unusual, but sometimes the water line to the icemaker fails or comes loose, letting water into your freezer. Try tightening all connections, and if necessary, replacing the line that feeds the icemaker.
Hope this helpout....
Aug 13, 2010 | Refrigerators
I found a water pool on the floor...
a coupltle thinges ,ur het plate to evaporate condensation it out, ur low on collant, or door sel is not sealing
May 30, 2010 | Magic Chef CTB2125 Top Freezer...
Water on floor at front right of refrigerator
Yep got a wood floor 1/2 way up do to water leak.
First lets decide where your leak actually is.
Fact: If the drain pan is dry does not mean that the water being disposed of during defrost is not getting to the pan, It could also mean that the water that is reaching the pan is being evaporated like it is suppose to be. So we have to find your source of the water first then decide on what is causing it.
Areas to consider:
1"Inside" coming out the front from under the door? This is most likely a stopped up drain pan. A cold area that is not suppose to be cold like when you have a freezer coil that is suppose to be defrosting and is not... See below for a more complete ideas list of things to check under Possibility.
2"Outside not underneath" The corner of the door also could indicate (if you have water in the door) a worn out water line or a kink in it that has finally started to leak. Turn off the water to the refrigerator for 2 or 3 days and see if the problem disappears. If so you know whats going on and can approach it from the door area.
3"Outside underneath" The corner could also be where the water is running to from someplace under the fridge. The drain pan drain line is the most common. Inspect it and repair as needed, maybe its just not over the pan. A new house keeper not acquainted with this box may have knocked it out during vacuuming just put it back over the pan. IF The sealed system has had refrigerant added it could be from an over charge and frost on the suction line defrosting during a shutdown.
Possibility's:
1 There is a drain that carries away the water under the cooling coils. These coils are in the freezer section.
2 The damper going to the crisper( s) is open too far allowing cold air to cause condensate on the fridge wall or bottom.
3 The freezer section is not defrosting and there is a spot where the ice buildup is allowing conductive cooling into the refrigerator section and therefore is allowing condensation on the refrigerator wall or ceiling.
4 The refg section has a heater (possibly not positive) in the area of the door frame, or it may have a "power saver" switch. This switch and the heater (if it has a heater it may not have a switch) are designed to stop condensation on the refridg while running. I fit is placed in the "power save" mode it turns off the heater. But, if you live in extream humidity (Great lakes east side or Gulf coats Houstion...) the humid air will condensate water out and it will collect and settle on the floor.
5 Door gaskets are not sealing especially on the bottom of the door. This allows warmer air into the fridge section and it is condensation on floor under the crisper.
If you check all of these items and still cant find it please post back and tell me what you did find. So I can help you more. Please rate me as much as possible as Im trying to keep my average up and do the things that will actually educate and help people.
THANK you for using fixya and good luck..
Mar 22, 2009 | Frigidaire FRS26R4A Side by Side...
Water leaking from fridge
Hello I had a problem close to this, at the back of the fridge on the bottom you should find the motor ,sitting on top of the motor there should be a small cream plastic catch tray if you dont have one this may be the problem as the motor evaporates the excess water, Hope this helped. djdizzys
Feb 14, 2008 | Refrigerators
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
