Question about LG Heating & Cooling
Red light flashing 4 times repeated on ceiling unit and not working
  • 2,133 Answers
RAC Product = Heat Sink Sensor Error, Open/Short Cct or over 95C. Commercial Product = Condensate pump float switch risen. Check drain pan is empty,
check pump is working OK. If no pump check blue jumper plug is inserted in socket CN Float.
Posted on Jan 03, 2011
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
How do i reset the service light on a bhm (voyager) v4 ceiling hoist?
To turn off the service light that is flashing red on your V4 BHM ceiling lift, you have to proceed this way:
1- Power off the lift with the red cord
2- On the hand controller, push on the PROG + RETURN button at the same time and maintaint it
3- Power on the lift
4- Keep pushing on both buttons, and push in order: UP, DOWN, LEFT, RIGHT.
5-The green light will flash and the buzzer will beep 5 times
6- Release all buttons on the hand controller.
7-Push on the UP button many times, till your hear 4 beeps
8-Push the PROG button once.
9-Push on the LEFT button many times, till your hear 3 beeps
10- Push the PROG button once.
11-Power off the lift with the red cord, then back on.
The service light should be off.
May 25, 2011 | Health & Beauty
Thomson scenium LED error code 45
When i turn it on red light flashes 3 times then 1 time, this keeps on repeading, no sound, no light
Sep 30, 2009 | Televison & Video
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Battery light flashes red 4 times
Check your users manual. Normally if it is blinking it is powering up, but may be different depending on model.
Jan 01, 2009 | Dell Inspiron E1505 Notebook
Heating & Cooling Logo
311 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
