Question about Mitsubishi WD-73827 73" HDTV DLP TV
What is the cost to repair the light engine on a wd7383tv
    Brigadier General:
  • 8,909 Answers
It depends on the extent of any damage that needs to be repaired.
Browse a Mitsubishi agent for advice, they may supply a refurbished price.
Posted on Jan 02, 2011
How do I get the service engine soon light to go out
The "Service Engine Soon" comes on when the ECM receives information from the engines sensors that exceeds normal acceptable operating parameters. The ECM will store a code (or codes) indicating which system(s) are out of tolerance and light the "Service Engine Soon" lamp. The technician will read the codes, diagnose and repair the condition(s), and reset the "Service Engine Soon" lamp. The lamp does NOT go out on its own (in most cases), once repairs are made. There is a scan tool that is used to clear the stored codes that allows the lamp to go out. It is therefore possible that you may already have fixed the condition that set your light to on. Or not. The whole purpose of the lamp was to help avoid the kind of "hit and miss" repair methodology that you have employed so far. Many feel the need to try this as they fear the costs of a professional mechanic reading the codes and the cost of repairs. Fortunately, there are less costly options available. Many of the large auto parts chains will read the "Service Engine Soon" codes for you at no cost. They will tell you what codes are present and you can decide if you (or someone you know) can perform repairs or if you need a pro to check things out. They do NOT, normally, perform resets of the lamp as this has potential liability issues for them. If you need the lamp reset after repairs are made, you have two options; pay the pro, or buy a scan tool that has the ability to reset the light. Not all do. The cheaper units are only code READERS. Be careful when you buy. But if you watch for sales, you can usually get a low-cost scan tools that can read and reset codes for around $40.00. Good luck.
Sep 16, 2014 | 2001 Pontiac Grand Prix
Can I drive my 2005 honda crv with the blinking drive light
Blinking "D" indicates an internal transmission issue, continuing to drive it may cause further , more expensive repairs.
Feb 22, 2014 | Cars & Trucks
I have a 2001 Acura 3.5Rl and I want to know why my check engine light stats on after it's been reset? And is the idle sensor engine related? How much does it cost approx to repair idle sensor? Is it...
The check engine light comes on when there is a failure. If the failure is not fixed before clearing the codes than the computer turns the light back on because there is still a failure! In order for the light to stay off what ever is not working needs to be repaired. Then the codes can be cleared and the light will stay off. What code specifically do you have. It should be a P followed by four digits (P0128).
Apr 10, 2013 | Cars & Trucks
Yellow blob on the screen - cost to replace light engine on 42" LCD?
Light engines cost around 400 dollars. Take it to a repair shop and it'll run you 600-799 dollars for this repair.
Jun 16, 2011 | Hitachi Televison & Video
Solutions for White spots on TV screen
The solution very exspensive repair,the tv have problems,with it IC on light projection engine block.By replacing the light projection engine block,will cost more than half of cost of the new tv.Tries talk to Toshiba for some kind of solution,these tvs are design problems,the IC they put on the engine block have problems.
Feb 14, 2011 | Toshiba 57HM167 57" HDTV
Tech tells me that my light engine (optical engine) needs to be replaced in my Hitachi 50V500A TV. Sounds like it's going to cost a fortune. ($600 or more). Do you recommend fixing this 7 year old TV or...
No I do not. There is no lower cost, I wish there was. I repair DLP sets and have yet to have a customer replace the Light Engine due to the cost. That is why mfg stopped making them and also due to better technology. LED set is the way to go with 240hz.
Dec 09, 2010 | Televison & Video
White and black dots on the screen, started as a few and now they are multiplying
This problems is the causes by the tv Light Projection Engine.This repair is an expensive repair.The whole Light Engine must be replaced to solved this problems.Talk to Mitsubishi tv corp.might have some help with the cost of the repair.There is a design flaw on these tv the Light Egine the IC chip controller to the projection light causes problems over again and again.
Nov 16, 2010 | Mitsubishi WD-57733 57" HDTV
Sony model kdf-70xbr950 , screen has blue streaks and blue dots. app. repair cost ,tv is 7 years old
Hi,what you are experimenting it's a faulty light engine problem,this is a common failure on Sony tvs.What's happening Is that your tv carries 3 chips blue,green and red, those chips are in charge of creating the colors on your tv .When these chips start to melt you will get color discoloration.Repair cost will be very highly around $400-$600 The part you need it's called the light engine or optical block ,some people are getting sony to repair their tv at no cost,I suggest to contact them to see if you qualify.God bless you!
Sep 30, 2009 | Televison & Video
Light engine
where are you getting your parts from? sounds like someone may be selling you used parts to get more business.
Apr 15, 2008 | Toshiba 62HM95 62" HDTV
Lower left quadrant has shadow
By knocking into the tv you have shifted the light tunnel in the light engine. The repair for this is to replace the light engine the part number is BP96-01198B you can order it from Samsung parts.com The cost for the part is 985 dollars but if you return the one the repair man takes out you get a core credit of 350 making the light engine only 630 dollars or so...You should be able to find a repair shop to put this in for labor of less than 300 maybe even 250...our shop does a Samsung for 190 Labor. Hope this helps.
Feb 04, 2008 | Samsung HL-R5078W 50" HDTV
Mitsubishi WD-73827 73" HDTV DLP TV Logo
126 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
