Question about Acer eMachines eM2501162 Netbook
I have tryed to boot my notebook and got new hard drive and tryed to format with usb i have tryed the memory card to but just gos back to blue screen how do i try to fix now
  • 139 Answers
There must be problem in RAM. the blue screen may also occur due to bad sectors in RAM. Try using re-seating the RAM and then if there are 2 chips of RAM then try using them one by one and if there is just 1 then try replacing it.
Posted on Jan 02, 2011
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have a problem that my pc is showing blue screen while iam starting to format
Blue screen error can only be one of two things 1 hard drive is is gone or one or more of your memory card are gone if you have more than one memory card take out one and test the machine then change it and test again if the screen is still blue get a card that cames from a machine that works if it still don't work.
try to format the hard drive in other machine if ypu cannot format replace the hard drive
Aug 02, 2011 | Toshiba Satellite L305D-S5881 Notebook
MY MEMORY CARD HAVE BEEN LOCKED BY SOME PASSWORD I WANT TO BREAK IT WITHOUT FORMATING MY DATA WHEN I PUT IT INTO ANY MOBILE IT DOESNT READ & WHEN I PUT IT IN MY COMPUTER IT DOESNT SUPPORT BUT WHEN I...
are you familior with linux?
any way you dnt have to be, you can try the folowing:
downlaod puppy linux live cd, burn it to a cd.
plug the usb memmory card, and boot the cd, hit enter to the given questions.
when the destope is loaded, click on the first icon that looks like a hard drive, a list of drives will appear, mount your usb , a new windows will apear, if it did appeared than u can mount your internal drive, copy the files, and format the usb, then go back to windows or mac and recopy the files, or even more better, plug it in your fone after the format, then back to the computer......
May 12, 2010 | Kingston 2GB Secure Digital Memory Card
My laptop won't boot! What should I do?
No power? Blue Screen Of Death? Blinking cursor? Black screen?
Need more info.
For anything other than a BSOD or error message:
Try unplugging from power, remove the battery, hold the power button 30 seconds. Then reinstall battery, plug in, and turn on.
If you are getting something like 'NTLDR not found' or 'Boot Sector not found', Hard disk blah blah blah etc. you might need a new hard drive or to repair errors on your existing one.
For BSOD, try starting in safe mode. If that fails, try using a bootable antivirus disk to remove any viruses or other junk and reboot.
Reply back with more info or results!
Apr 24, 2010 | Compaq Presario 700 470024-192 Notebook
Often when turning on my computer it would boot up but then go into the blue screen which indicates that there is problem with hardware or software. (XP) It would then usually reboot without any problem....
Hello:
just make new format for your hard drives . but before that you need to back up your data on an external hard drive .
after formatting just install fresh copy of your OS.
good luck
Feb 12, 2010 | Fujitsu S6210 Notebook
I reciently installed a bigger HD and now I get the"blue screen from hell"!! How can I get it to boot on the new HD?,Ray
did you format the hard drive first?
typically you need to format the hard drive using the NTFS file system before you install your operating system.
does your bios recognize the hard drive?
make sure your bios detects the hard drive.
can you boot your computer in Safe Mode? If so, do that and use your error log to find the specific cause of the blue screen,
lastly post the blue screen error message on here to get a better answer.
Nov 26, 2009 | HP EliteBook 6930p Notebook
Cloudbook will boot up and it will show GOS green screen
try to bot from a usb device, try an external cd/dvd rom and from there you could re-install the OS, change your boot order to boot from usb
Sep 12, 2009 | Everex CloudBook CE1201V Netbook
Blue screen error
check the ram memory ...and after remove and put it back in ...with care ...remove the bios battery to restore optimal defaults ...also try to format ntfs quick ..cause if the hard drive has some issues it will block during the normal installing ..but ussualy those 00000000 on blue screen are from ram memory issues...
Sep 09, 2009 | Acer Aspire 4530-5889 Notebook PC
Boot up problem
youre hd needs an os installing on it.first partition,then format ,then install os(windows)
the system is looking for a os not a hd ;the beeps indicate no os found(no drive by default)
if there is no hd,memory,or video card or stuck key the pc will beep.also with video card not connected the screen will be blank also with many models no memory will result blank screen.In ur case its only the hd.make sure all items are fitted insert os disk in cd drive start pc and boot from cd,to create partition,format and install
Mar 04, 2008 | HP Pavilion dv6000z Notebook
Acer eMachines eM2501162 Netbook Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
