Question about JVC AV-27D302 27" TV
Jvc 27" tv flashing timer
What can I do i had direct tv installed today tv was fine now will not come on flashing timer help
  • JVC Master
  • 19,396 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
You can find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on May 06, 2009
Av27120 jvc tv on timer lamp flashing. cannot turn on tv.
I need a solution for this problem..I can't get the tv to come on to go into the menu and clear the timer...Someone have any helpful info...I have the comcast box on the tv..I took everything off the tv
and plugged it in thinking atleast the snowy screenwill come up and then I could see the menue and fix the timer but that didn't happen. Left tv plugged in and cable hook ups on figured eventually the timer would clik off and tv would come back on..No such luck....Can anyone help me with this problem
Dec 12, 2010 | JVC AV-27120 27" TV
Tv won't turn on
You can try checkin the fuses I had a problem like that with my stereo receiver took it apart changed the fuses works great
May 06, 2009 | JVC AV-27530 27" TV
How do i shut off the timer on my jvc tv
HI...I have the same problem and I am trying this today (Expert advice on forum) ... Hope it works!
Try unplugging the power cord of your T.V. for 1-4 hours for a "HARD RE-SET".
If T.V. does not work normally after this, then you'll need parts/repiars. (Internal circuit/voltage problem).
Best of Luck!
I will know if it works for me in about 2 hours!
Ciao!
Mar 22, 2009 | JVC AV-27530 27" TV
Cable went out yesterday, when came back their was no picture or sound. green light flashing on timer. jvc av 27230 27" tv
did the input line still work, for the cable input do an auto search channel to reset your tuner, if it didn't work stop right there your tuner is mabye out
Feb 20, 2009 | JVC AV-27230 27" TV
JVC TV AV-32870 will not turn on. blinking timer light
Worth taking it in since it is hard to find a new TV for less than $300. I have a 32 inch JVC iart that for about 2 years would turn itself off and the timer light would blink. Only thing that worked would be to disconnect and turn back on. Eventually, the tv "popped" I could smell something that burned out and within 3 weeks tv went "dead" Took it to a tv repair place and replaced power unit for $150. I had similar problem with a 19 inch Philips and that tv has been going strong for 4 years since repair.
Good Luck
Oct 17, 2008 | JVC AV-32820 32" TV
Av-32d302 tv
The set is shutting down because a problem has been detected. Replacing the remote will not help. Count the flashes and call a JVC servicer to get an idea about what the specific problem may be.
Dan
Jul 29, 2008 | JVC AV-32D302 TV
JVC 27" D series
there is another problem that requires a tv repairmans expertise when the timer light flashes continuosly ,and the power is not restored.
Apr 21, 2008 | JVC AV-27D502 27" TV
My TV turns off by itself. How do I correct this? JVC TV TURNS OFF IN 2 SEC. AFTER TURNED ON SLEEP TIMER LIGHT FLASHES. BYPASS POWER RELAY
it could be a memory error or a main power supply malfunction.please contact the nearest repair shop.
Jan 07, 2008 | JVC AV-27230 27" TV
Television want turn on
In a large number of failures with these symptoms it's usually the HOT (horiz. output trans. Q522, which is a 2sd2499) and the regulator (Str30134), together with fuse F902 (Gma 1.25a). Not an expensive repair or that complicated if you're fairly good with electronics and know how to solder correctly. Otherwise take it in and have it repaired professionally - it's worth it...
Bill
Nov 15, 2007 | JVC AV-27230 27" TV
On Timer light flashing on my TV
If you're NOT still under warranty you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. good luck!
Nov 30, 2005 | JVC AV-27120 27" TV
JVC AV-27D302 27" TV Logo
85 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
