Question about HP PSC 2355 All-In-One InkJet Printer
Reads carriage jam open door - HP PSC 2355 All-In-One InkJet Printer
SOURCE: Carriage Jam error always - how do I fix it?
Try resetting the printer (pressing the cancel button and connecting the power supply, check in the HP website if this is correct for your printer model) , after the reset the printer will clear any errors and will recalibrate the mechanism including the paper feed mechanism and the carriage.
Also check if the carriage is moving freely by disconnecting the power and moving it by hand.
Posted on Feb 04, 2008
Khalsa007
  • 79 Answers
SOURCE: Carriage jam error
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7 Allow the all-in-one to re-initialize. This may take a minute or two.
8 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information
Thanks
Posted on Jun 04, 2008
My solution was to simply unplug the unit, with leaving it off for several moments. Voila! It worked!! I had to reset the time and date settings, though. A small price to pay.
Posted on Jul 07, 2008
adonscott
  • 106 Answers
SOURCE: carriage jam error
Here is the document that i want you to follow exactly in order to resolve your issue.
CLICK HERE TO VIEW THE DOCUMENT.==>> DOCUMENT
Please let me know the result after following the document.
Thank you so much. I remain.
adonscott
Posted on Jul 24, 2008
  • 24 Answers
SOURCE: Printer keeps saying ''carriage jam error''...
Friends,
The encoder strip may also be dirty, this causes the printer to believe that the carriage moves less than it actually does and tries to compensate by moving the carriage even further - slamming into the left side of the printer as a result.
Carefully leaning the encoder strip with a lint-free cloth wetted with luke warm water (it should not drip!) can fix this problem.
If the carriage stays in the middle of the printer and doesn't move, the carriage drive belt may be broken. Usually this is not replaced so the printer unfortunately has to be scrapped. But contact your local HP support for further advice.
//Al
Posted on Mar 08, 2009
Carriage jam
Hi
The carriage door is the cartridges access door.Access the cartridges and make sure they're properly installed.To open:
  • Turn the machine on.
  • Open the cartridges door by lifting from the front center of the device until the door locks into place on its own.
Feb 27, 2012 | HP C6250 InkJet Printer
I get a message carriage jam and told to clear jam. However there is no paper jam. It tells me door open and it is not open. It seem the door does not go all the way up. I keep getting the message that...
It seems you mistook Carriage Jam as Paper Jam, but they are different issues. Carriage jam means the carriage that carries the cartridges is jammed which needs to be moved or be cleared manually after opening the door.
Please follow the instructions mentioned here (Click Here) [source HP Support].
Good Luck.
Let me know if you need further help.
Thanks for using FixYa.
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
False paper jam reading.keeps say to clear paperjam. called HP and they said its a common problem,too expensive to fix,buya new one from us for 300 bucks
Check the following Steps for fix HP printer carriage Jam :
  • Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
  • Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
  • Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Sep 14, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Carriage Jam
Look slike that the printer needs to be cleaned...
Maybe some small paper is near a sensor and once in a while it gives paper jam.
Regards
Jun 24, 2009 | Office Equipment & Supplies
Hp officejet 6210 all-in-one
open that door, clear the jam , mostly paper trapped
close door and acknowledge with pressing button next to okay.
Should disappeasr.
If not still jammed.
If not, reset the printer.
Apr 11, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Can not get by carriage jam message
I had an old HP printer and it would say the door was open or the cartridge jam. It turned out the cartridge was too far to the end of its belt cycle. It is weird, but I put a finger space width between the cartridge and the wall of the printer and then it read it correctly. Go figure. It would get off cycle whenever I replaced the ink cartridge.
Jun 04, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
HP PSC 2355 All-In-One InkJet Printer Logo
87 people viewed this question
Seeker5211
Seeker5211
