I have a whilpool DWH B00 dishwasher, which has started beeping when I try to wash. It happens after a few minutes and then the error lamp blinks. I have cleaned the filters inside and also the draintube going to the sink.
What can be the problem? Can the drain tube be too long? It is about 5 meter and elevates about 20-30 cm into the sinks drain. /Henrik
I couldn’t find any error code 2H but I did find an error code H2O. This code means insufficient water pressure. If the display reads 2H, it usually means the start delay function is turned on. The dishwasher will turn on in 2 hours if door is closed. This dishwasher is advanced. To understand all operations you should read the user guide or manual.
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Hello, Thank You for using FixYa. I will be helping you today.Start by running a bottle of dishwasher magic through it and make sure the drain line is clear.
Thank You and please rate my answer if it was helpful..
Is the washing machine spinning well enough to wring out clothes?
Move the dryer away from the wall, pull the hose off of the back, activate the dryer and form an opinion about the volume of air flow....Connect back up, activate again, go outside the building and verify VERY SIMILAR air flow outside the building. Often screens block up and restricted air flow diminishes drying ability.
Hunca, We would like to inquire further about your post with you. Please respond back to this email address [email protected] with your name, user id (Hunca), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Raise temperature of your water supply. Open door and press hi-temp srub,then energy saver, then reapeat this within 3 seconds. Close door and hit cancell.
