Question about Smeg A1A.1 Gas Kitchen Range
I have a Smeg A1.1 2FA Single Oven. The oven fan is working but the oven does not heat up. Any ideas? Thanks
  • 1462 Answers
SOURCE: Smeg main oven failure
problem is almost certainly the circular element. these sometimes fail with obvious damage but not always. check continuity across the element to be sure. you are right about element fixing. there is no reason why the design should'nt allow removal from the front as many do but i suppose the guys who make these things don't have to fix them.
Posted on Apr 01, 2007
hongster
  • 6 Answers
SOURCE: Smeg SNZ91MFX1 Fan heating not working
It could be that the element around the fan (which is obscured by metal plate) has gone. Remove the metal plate in front of the fan, and test with a multimeter to see if a current gets through it...
Easy to order and replace yourself
Posted on Jan 24, 2008
ronaldo1
SOURCE: cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Posted on Feb 15, 2008
  • 409 Answers
SOURCE: Smeg Oven blowing
do you mean it's popping the breaker? sounds like you need to check the electrical circuit for a TOD. it needs to be replaced.
Posted on Sep 13, 2008
  • 409 Answers
SOURCE: SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Smeg linear oven is displaying sho (showroom mode) and will not heat up. I have held down function knob for 5 seconds which clears SHO from display but within seconds it comes back. Any ideas
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 28, 2013 | Smeg Linear Pyrolitic Single Oven Electric
I have a Smeg SA 398x model. firstly, I would like to know the year of manufacture please. Secondly, for some reason the fan element options do not heat up. The fan in the back of the oven works but no...
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
Jul 19, 2011 | Smeg Linear Pyrolitic Single Oven Electric
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
The light and fan works but no heat comes on in oven.
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Jul 08, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Fan but no heat
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
No heat when i switch oven on
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
Jan 01, 2009 | Smeg SE250XUK Stainless Steel Electric...
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg oven
If this helped like us on facebook please
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
Jan 01, 2008 | Smeg SE250XUK Stainless Steel Electric...
Oven light always on, no heat
probably the clock not set properly - you have the oven on automatic. switch off at mains, wait 5 mins and set the clock according to the manual. if the over-temp stat has operated, the oven goes dead
May 05, 2007 | Smeg S351X/5 Electric Single Oven
Smeg A1A.1 Gas Kitchen Range Logo
119 people viewed this question
Top Smeg Kitchen Ranges Experts
Richard Ballard
Richard Ballard
Level 1 Expert
Joseph Mueller
Joseph Mueller
ashburton
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
